September 16, 2026, 03:18:57 am
Hoffman Amps Forum image Author Topic: 900+ Volts on pin 3 using a NOS Hoffman 50 OT  (Read 5248 times)
Offline apolloamps
« on: May 31, 2012, 02:18:20 pm »
Just finished an amp and I'm getting 900+ volts on the plates (yet the tubes don't glow red or white hot)(and the voltmeter works fine) . I think Hoffmans Tranny is fried or hooked up wrong. Never had this problem. The rest of the amp checks out perfect. What gives?
Hep me please
 Steve
Re: 900+ Volts on pin 3 using a NOS Hoffman 50 OT
« Reply #1 on: May 31, 2012, 02:28:46 pm »
What color wires go where?
Can you post a drawing of how it's wired?
stratele52
  • Guest
« Reply #2 on: May 31, 2012, 03:14:42 pm »
900 volts each side probably, but if you mesure from ground ( there is a center tap in the middle of 900 volts winding ) , you must have 450 volts.
« Reply #3 on: May 31, 2012, 03:17:33 pm »
Man thats dangerous. I would make certain your Power Transformer CT is grounded. Do you have a pic of your amps PT wiring?
« Last Edit: May 31, 2012, 03:20:39 pm by plexi50 »
« Reply #4 on: May 31, 2012, 03:18:03 pm »
Which amp? Is this a new build? What voltage do you measure on pin 4 of the output tube(s)? If you pull the PI tube does the voltage on pin 3 look more normal?
Offline navdave
  • 559
« Reply #5 on: May 31, 2012, 05:06:05 pm »
Sounds like he hook up the PT in full wave bridged rectifier mode instead of full wave.
