September 14, 2026, 02:57:56 pm
Hoffman Amps Forum image Author Topic: POWER TRANSFORMER transforms too much.  (Read 7127 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: June 22, 2012, 05:00:31 pm »
Hi,
I have found this huge transformer in a TONE GENERATOR , 20 tubes or so.  I was wondering why my meter was beeping btwen two leads of the HV, with no reading. Its max is 700V AC, 1000VDC.
From one side of the HV to the center tap is 550V, so I get 1100 V !!!!
What can I build with that beast ? An electric chair ?
P.S.: call me Alvin.
Re: POWER TRANSFORMER transforms too much.
« Reply #1 on: June 22, 2012, 05:07:31 pm »
Sell it for scrap, use the money to buy what you need.  :icon_biggrin:
« Reply #2 on: June 22, 2012, 06:50:24 pm »
You can build one hell of a strobe light!
« Reply #3 on: June 22, 2012, 09:04:46 pm »
Tesla coil?
Offline terminalgs
« Reply #4 on: June 23, 2012, 11:03:57 am »
use it in a 20 tube tone generator.
  • MAKE LOVE NOT WAR
« Reply #5 on: June 23, 2012, 04:58:59 pm »
yeah, back to where it belongs, with EXACT SPECS, genius you are !
« Reply #6 on: June 23, 2012, 05:19:09 pm »
Why would you want to fool with a PT that puts out that much voltage?
I would leave it be.
                              Brad     :icon_biggrin:
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
« Reply #7 on: June 23, 2012, 11:56:41 pm »
Use it in a "Choke-Input" Circuit.  That will drop the HT secondary voltage down to a usable B+ and you can use small value capacitors.... the only problem is caps are much cheaper than the choke needed to supply a full amp.....
j.
Open Minded But Fixed Bias
« Reply #8 on: June 24, 2012, 06:45:45 am »
550v * 1.4 = 770v with SS rectify, and using a Tube Rectifier the voltage will be lower
a PP of 807 is fine with 740v DC
see the Geloso G.273a
or you can experiment with GU50 tubes
look to page 9 of the EL152 tube datasheet (same specs)
(you can use less than 6 x GU50 tubes if you don't need very much power)
the photo refers to a GU50 Bass Amp
« Last Edit: April 20, 2017, 11:42:15 am by kagliostro »
