August 29, 2026, 11:29:21 am
Hoffman Amps Forum image Author Topic: High current low voltage / low current high voltage ?  (Read 9026 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: July 01, 2012, 05:01:39 pm »
Hi. I'd like to know what do you guys prefer from a power tube : high I , low E or the opposite ? What tonal characteristic you prefer from both ?
The reason is that I am working on a SE amplifier, design of my own with 2 X EL34 in parallel and I hesitate between 250V/100mA and 350V/70mA. ( the trannies are fine with both ).
Regards
Colas
P.S.: call me Alvin.
Offline Leevi
    • Rikstone
Re: High current low voltage / low current high voltage ?
« Reply #1 on: July 02, 2012, 01:58:45 am »
I prefer 250V. The higher secondary gives too high B+, more than 450V (after rectifier)
which makes the sound too clean and cold. Of course it's depending on what kind of sound
you are looking for.
/Leevi
« Last Edit: July 02, 2012, 09:44:33 am by Leevi »
stratele52
  • Guest
« Reply #2 on: July 02, 2012, 04:28:43 am »
Yes  for 250 volts .
« Reply #3 on: July 02, 2012, 05:45:46 am »
IF I am understanding your post correctly,  I don't think you will have enough ma current capability for paralleled EL34 tubes if you PT options only allow 70-100ma of current.
Please look at this tube data cheat sheet.
  • MAKE LOVE NOT WAR
« Reply #4 on: July 02, 2012, 07:20:14 am »
Jeff, my PT can supply .5 A, so no prob about it. From a tone point of you, what do you prefer ?
regards
Colas
  • MAKE LOVE NOT WAR
« Reply #5 on: July 02, 2012, 07:22:18 am »
what I meant was 250V / 100 mA for each tube, 200mA total.
« Reply #6 on: July 02, 2012, 08:49:18 am »
350V is close to the max (375) for self-bias.  Theoretically, the lower 250V will be more in keeping, tone-wise, with the SE design.  But there may not be an objectively true answer.  The tonal result may be purely subjective.  Or you may get earlier / later break-up (headroom) with tone otherwise being the same.  The only way to know is to try.  Hence I suggest you should A/B both voltages.
  • MAKE LOVE NOT WAR
« Reply #7 on: July 02, 2012, 10:00:04 am »
yeah it is often a question of taste, but objectively, we can hear clearly the difference between a clean tone and a distorted one. I have already tried 350V, but now to get the HV down to 250V, I have to hook up a VVR and I just thought I could save me this mod :icon_biggrin: but now that you have spoken 'bout an eventual better tone at 250V, I gotta try it  , maybe I'll find the right balance at 300V.
Colas
« Reply #8 on: July 02, 2012, 10:08:25 am »
Hi Jeff
There's a typing error in the heater current draw for the EL34 part of the cheat sheet you loaded.
Pete
« Reply #9 on: July 02, 2012, 10:47:10 am »
Colas
Vintage amps tended to be run at moderate voltages. Modern amps are often run at max or over-spec voltages.  (there are exceptions such as Traynor who ran vintage amps at over-spec voltages).  I think the different voltages treat harmonics differently.  Maybe sag changes also, but your amp is SE anyway.  Nevertheless, it's possible that EL34's might not notice that much of a difference between 250 - 350V.
The easiest way to A/B test different voltages for design & development is with a variac.  Other alternatives:  bucking transformer; variable bench power supply.
« Reply #10 on: July 02, 2012, 11:07:58 am »
A pair of EL34's will require 1.0A heater per the data sheet which is twice as much as what you are saying your PT can supply.
I apologize if I am not understanding how you're reporting the PT's specs? Just trying to help you be on the safe side.
Having said that, everytime I have used a VVR ........ I have preferred lower voltages on the plates of the power tubes (tone wise).
« Reply #11 on: July 02, 2012, 11:24:42 am »
That would be 3A per pair
  • MAKE LOVE NOT WAR
« Reply #12 on: July 02, 2012, 11:54:51 am »
OK, I am sorry if I don't make things clear about my PT specs, but that ain't the subject of my post anyway that concerns the tone of power tubes at a given voltage. For those who cares, the power transformer can handle easily 4 X EL34 @ 100mA each,  the heaters tap can supply around 6A. It was first ordered for a 100 w amplifier from Avel Lindbergh ( toroïdal ).
sorry for the confusion
Colas
  • MAKE LOVE NOT WAR
« Reply #13 on: July 02, 2012, 02:52:22 pm »
Just came back from my shop after modifying the voltage on my 2 X EL34 : with 250V on the plates and 100mA each tube I get a high squeal, like when  the plates lead are reversed on a PP amplifier ( not so loud, though ). Does that mean my OPT can't handle a I of  200mA , or is there another issue ? I am to the point of swapping the OPT but I am running out of time, too many rehearsals and gigs and that damn amp doesn't do what I want to :cussing:
Thanks for ideas
Colas
« Reply #14 on: July 02, 2012, 03:08:17 pm »
Can you be certain the way you incorporated the modification didn't cause the squeal? That is, wiring, lead dress, etc.
  • MAKE LOVE NOT WAR
« Reply #15 on: July 02, 2012, 03:15:41 pm »
All I did is swapping the 2 X 360 Ohm for 2 X 100 Ohm and lowering the B+ on the VVR to 250V, nothing else. Maybe the OPT can't stand the higher current ?
  • MAKE LOVE NOT WAR
« Reply #16 on: July 02, 2012, 03:18:35 pm »
oh , just remembered, I did not put back the cathode resistor bypass cap...........but this is not the cause, is it ?
  • MAKE LOVE NOT WAR
« Reply #17 on: July 03, 2012, 08:17:50 am »
problem solved: OPT too weak for 200mA, replaced OPT and everything is just fine at 250V / 110 mA each tube, but I prefer the tone at 350V / 70mA
thanks for your help once again
Colas
« Reply #18 on: July 03, 2012, 08:38:01 am »
Why/how does it sound better?
Brighter, darker, cleaner, more head room?
Would be good to know what changed.
                            Brad      :think1:
« Last Edit: July 03, 2012, 08:42:05 am by Willabe »
« Reply #19 on: July 03, 2012, 08:58:51 am »
Why/how does it sound better?  Brighter, darker, cleaner, more head room?  Would be good to know what changed.
                            Brad      :think1:
Ditto! Same question.
  • MAKE LOVE NOT WAR
« Reply #20 on: July 03, 2012, 05:17:10 pm »
more defined tone at 350V, a bit of headroom more, more biting highs. At 250V, browner tone , like if AC signal had a hard time surfing on too much dc current !
Colas
« Reply #21 on: July 03, 2012, 09:53:06 pm »
Alrighty then, thanks for the good info Colas. You've done enough builds/repairs to have developed a good set of ears.
Helps all of us get a grip on our builds.
             Brad     :icon_biggrin:
« Last Edit: July 03, 2012, 09:55:49 pm by Willabe »
