September 15, 2026, 10:02:49 am
Hoffman Amps Forum image Author Topic: Filter Cap Resistors  (Read 5243 times)
Offline bakerlite
  • Don't forget to play it...
« on: July 10, 2012, 08:02:50 pm »
Just finishing off a blackface conversion (AA270 - AB763) and I am looking at the Dog house where the balancing resistors between the filter caps looks to have been stressed at some point
I hadn't planned on doing anything to the filter caps or said resistors as part of the conversion but now that I see the resistor damage I must.
The AA270 stock resistors are  10k and 2.2K between the 3 x  20uf caps - Ab763 schematic specifies 4.7k and 1k - this seems quite a difference in value from the silver face stock setup.
I am just double checking this will be ok.
Cheers,
Bakerlite
Re: Filter Cap Resistors
« Reply #1 on: July 10, 2012, 08:19:38 pm »
That should be fine.
Offline bakerlite
« Reply #2 on: July 10, 2012, 08:36:48 pm »
Thanks!
doh! Just after realizing my capacitor stock is a bit low :(
I am meant to have 2x 70uf caps to give 35uf capacitance at 700v rating before the standby switch.
All i have is 2 x 220uf - 6 x 16uf - 1 x 40uf  - 1 x 8uf
I am torn between using the 2 220ufs which would give me the safe voltage rating but a massive 110uf of capaciance
or the single 40uf at 500v which is a bit tight considering it runs 450v
Am i out of luck?
Cheers,
Bakerlite
Offline jim
« Reply #3 on: July 10, 2012, 10:06:04 pm »
Pt the 220's on the hot side of the standby switch like you would see on a Super Reverb (which would have 70's there).  Yes, the good book says no -- but it works perfectly well and it tightens bass response at high volume.   You can use the 16mf caps in place of the 20's and likely not notice any difference.
« Reply #4 on: July 11, 2012, 10:18:33 pm »
Which specific amp is it? Tube rectifier? If so, I might not want to step up to the 220's.
If it is a solid-state rectifier, yes go ahead. Make sure they fit under the cover first though.
