July 25, 2026, 05:12:44 am
Hoffman Amps Forum image Author Topic: Vox AC15 layouts  (Read 136410 times)
Offline bnwitt
  • Crankin' out the tone.
Re: Vox AC15 layouts
« Reply #50 on: August 06, 2012, 11:50:29 am »
HBP,
I'm reaching the limit of what I can squeeze into this chassis.  It is 20" W x 6.5" H x 2.5"D.  As far as the Top Boost is concerned, there may be a way to add it as originally it was an external add on kit before it was integrated into the AC30/6.  It basically needs an additional set of input jacks bass and treble controls and an extra ECC83 tube.  I do have room for those components.  What is tight is adding the additional support components.  I could probably add the inputs and controls and put everthing else in a box on the interior cabinet wall or do it just like it was done to the AC30/6.  See link below:
http://www.marshallforum.com/419422-post355.html
Barry
« Last Edit: August 06, 2012, 12:21:39 pm by bnwitt »
Offline bnwitt
« Reply #51 on: August 07, 2012, 06:40:07 pm »
Thanks for the heads up.  Evidently my virus protection is protecting me well.  I replaced the link in my post with the one from Doug's library.  On the virus front, I was searching for a website called guitaramplifierpcbs.com the other day and the actual website wasn't coming up in Google.  So I typed it in the url bar and bam!  Instant malware download which bypassed my virus protection and put my machine into a restart.  It took me 3 hours to get rid of it.  I've never seen anything that powerful before.
« Last Edit: August 08, 2012, 10:43:50 am by bnwitt »
« Reply #52 on: August 09, 2012, 10:59:00 am »
     :w2:
Glad you where able to fix it. I'm not sure I'd be able to figure out how to get ride of it.
I've always been dumbfounded at how people with the brains/gifting to do so much with a computer would use it just to hurt someone else, really as many as they can.       :BangHead:       :cussing:
                          Brad     :w2:
« Last Edit: August 09, 2012, 11:01:14 am by Willabe »
Offline bnwitt
« Reply #53 on: August 14, 2012, 05:11:32 pm »
After doing some research on the different Vox AC series amplifiers I found the following:
1. The AC 15 was used by numerous British players with great satisfaction.  It was a great sounding amp but as venues got bigger more power was needed.  Two more power tubes were added hence the AC30/4
2. The EF86 versions of the AC15 and AC30/4 were altered to an ECC83 after "Bass" players complained about microphonics due to their bass frequencies.  This was not a guitarist complaint.
3. Along with this preamp tube change a third channel (Brilliance channel) was added since the dual triode allowed it hence the AC30/6.
4. After the preamp tube change, players noticed a change in tone.  There wasn't as much gain and clear tone in the new AC30/6
5. To satisfy the complaints on the AC30/6, the treble models were introduced (which had a treble boosting RC at each volume controll)
6. Shortly after that the Top Boost add on kit came out.  Eventually the Top boost circuit was made stock in AC30s.
6.  Most players of the AC30 amps consider the original circuit with the EF86 to be the best of the series in tone.
After reading all of this, I have decided not to add the top boost components or the 3rd channel to this amp layout  It seems to me that the original AC15 and AC30/4 with EF86 were the British gutarists' favorite of all models issued.  Of course it was common for guitarists and bass players to share an amp in those days and if the bass players had just had their own amp I wonder if good enough might have been left alone.  And of course if Public Address systems had existed back then I doubt there would have been a call for the AC30 at all.  So bottom line, I will be building the 1960 EF86 AC15 amp as it was originally issued and the layouts will be in both a combo and head style chassis.
« Last Edit: August 14, 2012, 06:20:39 pm by bnwitt »
« Reply #54 on: August 14, 2012, 07:26:48 pm »
Why not design the layout so that you can easily incorporate a top boost later if you change your mind? (I'm always fiddling with my builds down the line). Besides, in a gig/jam situation you'll probably be thankful for some mid-high freq boost - either that or some kind of rangemaster cloney thing in front. JM2CW
Offline bnwitt
« Reply #55 on: August 14, 2012, 08:13:43 pm »
Tubeswell,
Putting in a Top Boost circuit later would be no problem, just like the original.  But, I'm after the orginal EF86 AC15-AC30/4 tone which is reported to have had excellent highs, great overall tone and great gain.  The Top Boost circuit came along after Denny changed the original circuit (which was considered awesome by guitarists) to try and bring the AC30/6 back toward the original tone.  Unfortunately not many of the original AC15-AC30/4 amps are still around since fewer were made than subsequent models.  There is a fellow out there who converts AC30/6 amps to the original AC30/4 circuit:
http://members.optusnet.com.au/~glen325/AC30convert.html
Evidently there is a market for that which is surprising.  To think that someone would do that to a valuable amplifier worth lots of moolah to achieve the tone of the very first original circuit tells me that the tone is worth it.  The oldest AC30 I have every played was a 90s reissue and I wasn't impressed.  I really want to hear for myself what the original circuit sounds like.  The way this is going I am going to be pretty darn close to the original layout and exactly on the circuit so I think it will be very close.  I've even got a UK made "Blue" speaker to put in the cabinet.
Offline moonbird
« Reply #56 on: August 15, 2012, 06:29:35 pm »
Very interesting info -- sounds GREAT to me!!
« Reply #57 on: August 15, 2012, 07:42:10 pm »
Yikes!
Offline bnwitt
« Reply #58 on: August 15, 2012, 09:31:43 pm »
Yikes!
Yeah!  That's what I thought.
Offline carausius
« Reply #59 on: August 21, 2012, 07:30:45 pm »
http://livinginthepast-audioweb.co.uk/index.php?p=xfrmrclassic
UK made Vintage style Vox transformers various models available.
Not sure if this link has been posted before but might be useful for European builders
Offline bnwitt
« Reply #60 on: August 22, 2012, 10:10:38 am »
 a bit pricey.  $45 for a $19 choke is a pretty heavy mark up but if it's all that's available in one's area.  I guess the OT and PT are fairly reasonable if one is after the vintage look.  Thanks Carausius
Offline carausius
« Reply #61 on: August 22, 2012, 02:41:44 pm »
As always shop around, I doubt if a choke makes a large difference compared to an output or power transformer  :icon_biggrin: Even if it's authentic  :laugh: Non EU buyers would save 20% VAT on those prices.
EDIT More interesting stuff http://charliehall.proboards.com/index.cgi?board=project&action=display&thread=593
« Last Edit: August 22, 2012, 03:01:06 pm by carausius »
« Reply #62 on: August 23, 2012, 05:12:39 am »
I've been working on a single board layout for the AC-15. It will fit in a 20 x 6.5 x 2.5 chassis with a 'Marshall' style layout...
http://home.comcast.net/~seluckey/VAC15.pdf
« Reply #63 on: August 23, 2012, 05:28:44 am »
I think these SCH schematic and layout could be easily converted into what you guys are looking for.
Offline bnwitt
« Reply #64 on: August 27, 2012, 06:30:45 pm »
Well I hope to have this preliminary layout done in the next week.  I have been slammed with PV design work and have had it back burnered.  Sluckey has been purusing the Steven Grosvenor layout and already found two mistakes so thank you thank you to him for his contributions.  I would appreciate it if after the preliminary layout is done all of you brainiacs would look at the 1960 AC15 schematic and the layout side by side to look for any other errors.  More heads are better for sure.
Offline SleepLess
« Reply #65 on: November 01, 2012, 06:13:48 pm »
Hi.
Awesome topic and exactly the thing I'm looking at for my next personal amp project... Have you finished it? How does it compare to the real one you had before? Where did you source the various parts (mainly speaking about the chassis and faceplate!)?
« Reply #66 on: November 02, 2012, 02:43:34 am »
Hi Bnwitt
I was thinking to your layout this days
Have you finish to plan it ?
Can you show us something ?
Offline SleepLess
« Reply #67 on: December 18, 2012, 02:33:54 am »
Hi bnwitt!
Have you finished this build? How has it turned out?
« Reply #68 on: December 18, 2012, 10:28:24 am »
I have been watching this as well.  Sluckey's layout says corrupted when I attempt to open it.  I am interested in building this in a Marshall chassis and make a head out of it.  Let us know how it is going.
« Reply #69 on: December 18, 2012, 12:10:03 pm »
Actually, it says...
"Sorry, the page you were looking for could not be found."
I can put the file back online if there is any interest.
Offline SleepLess
« Reply #70 on: December 18, 2012, 12:12:13 pm »
Well, I was more looking for a double chassis layout, just like on the original, but a single chassis layout would be a good start I guess... Thanks Sluckey!
« Reply #71 on: December 18, 2012, 01:11:13 pm »
Why? Their a pain. It was a big mistake on their part.
              Brad     :laugh:
« Reply #72 on: December 18, 2012, 01:12:25 pm »
My single board/chassis version of the 1960 Vox AC-15 is back online. No guarantees on how long it will remain online.
« Last Edit: December 18, 2012, 01:15:07 pm by sluckey »
Offline SleepLess
« Reply #73 on: December 18, 2012, 01:32:47 pm »
Oh my... This is totally terrific Sluckey, thanks! So all I need now is to find the guy who can make the right faceplate to make it look like the original...  :think1:
Offline SleepLess
« Reply #74 on: December 18, 2012, 02:47:32 pm »
              Brad     :laugh:
Yeah, you're probably right, although Vox and the Vox fans assert that the double chassis actually helped reduce hum because of the two different metals used for the chassis (power section in the steel chassis, preamp section in the aluminum chassis)...
The other fact is that I have finally found someone who can build the double chassis... But nevermind, I trust Sluckey more than anyone else in this world when it comes to amps...
« Reply #75 on: December 18, 2012, 03:04:25 pm »
The layout has a 12Ax7 in the normal preamp section, but the schematic has a EF86.  Excuse my ignorance, but why?
« Reply #76 on: December 18, 2012, 03:17:58 pm »
V hav other vays to kill hum you know.   :undecided:
               Brad      :laugh:
Offline SleepLess
« Reply #77 on: December 18, 2012, 03:23:57 pm »
Good point. And the rectifier (V8) in the schematic is present, but it's gone in the layout...
« Reply #78 on: December 18, 2012, 04:05:57 pm »
Because it's a labeling error on the board layout. Pins connections are correct for an EF86.
« Reply #79 on: December 18, 2012, 04:09:57 pm »
And same for transformers, filter caps, switches, fuse, etc. My layout is not a total layout. It's meant to show board construction and interconnections. You will have to refer to the schematic for any components or connections that do not interface directly with the board.
« Reply #80 on: December 18, 2012, 04:35:49 pm »
Thanks Sluckey.  I have always wanted one of these.  Do you know anyone who has built it?  I cannot see any reason why it would sound different.  This is my next project for me.
« Reply #81 on: December 18, 2012, 04:44:11 pm »
Hi Steve
I completely missed to see this layout
as always a fantastic one  :thumbsup: :thumbsup:
« Reply #82 on: December 18, 2012, 04:47:37 pm »
I've built a VAC-15 Lite. It only has the EF86 preamp. I've never built the Vibrato channel but was sure close to pulling the trigger back in early September. Then I discovered that old RCA radio. Lost focus on the Vox. But it's not completely out of mind. If I do build it, I will use this board design rather than a dual chassis design.
BTW, the labeling error has been corrected on the board layout. If you spot any more errors, let me know. Thanks...
Offline SleepLess
« Reply #83 on: December 27, 2012, 04:13:11 pm »
If one of you guys start a full VOX AC15 one-chassis build I want to see it... I'm too scared to be the first one to try it and report...
Where do you guys get the proper chassis for the one-chassis AC15 btw?
There's a model from 1960 up for sale on TGP right now, just shy of $4000 (and that's probably a good deal!)... We need clones out there, that's too darn expensive!
« Reply #84 on: December 27, 2012, 07:03:39 pm »
I start with a blank chassis. There are some members here that can make them. Or you can buy blanks from several websites.
Offline lego4040
« Reply #85 on: February 28, 2014, 05:27:52 pm »
Sluckey, what was the outcome of your single board AC15? I'm interested in building this and would like to know if there has been any revisions since. I already printed out the file and will order the turret board material and turrets. I can cut and drill press holes and press them in myself
Offline lego4040
« Reply #86 on: February 28, 2014, 06:22:39 pm »
eBay uk has vox chassis for sale FYI
« Reply #87 on: February 28, 2014, 06:50:53 pm »
That was over a year ago. Lost my website and then rebuilt it. Somehow I overlooked that file. Anyhow, I've reposted the most current file and I 'think' there are some minor revisions but I can't say for sure. I still have not built this. If you get started on it, please share with us. Here's the updated file...
Offline lego4040
« Reply #88 on: February 28, 2014, 09:13:48 pm »
 :icon_biggrin: I absolutely will. I was just about to build Hoffmans Blackface Princeton Reverb and wound up buying a Gretsch T6118. Could you recommend a chassis? I seen the size you posted and was wondering if that is a Marshall style? I have no problem using a Marshall style and making it look like a Vox. I'll Gladly post pics and what not on my build in progress. That file is what I printed out today and will use to transfer onto board. One question tho about layout, on page 4 and page 6, you show a buss ground( going from left to right) from ground 1 section all the way to ground two but on the other page you dont. I know its all grounded but should those two sections be seperated as seen in page 6 with the template above it.
« Reply #89 on: March 01, 2014, 07:56:01 am »
There were a couple inconsistencies between the pages. I've made corrections and updated the file on my website. Your concerns about the on-board ground busses were addressed. Please download the latest pdf. You may have to refresh the page to see the changes. Let me know if you spot any more discrepencies or if you have other questions. Good luck with the build. Here's the link to the updated file...
BTW, the unconventional front panel, board, and tube layout work well together to provide short, neat, and logical interconnections. If you change the front panel to look more like the original layout, wiring may no longer be neat and logical.
I've included a source for a nice blank chassis for this project on the chassis layout page.
« Reply #90 on: March 01, 2014, 01:25:39 pm »
What to say Steve .......... this thing is GREAT   :thumbsup:
Thanks for sharing
