September 17, 2026, 03:16:01 pm
Hoffman Amps Forum image Author Topic: Hoffman AB763 Tremolo working on both channels??  (Read 4724 times)
Offline ACHIEVEIT
« on: July 31, 2012, 01:58:41 pm »
Hi guys,
a few months ago i finished retrofitting my DRRI with a Hoffman AB763 from the Airtight Garage. By the way, I added a switched pot in the tremolo 'intensity' to disconnect the tremolo circuit and add some gain when necessary as per the instructions found here: http://www.el34world.com/Forum/index.php?topic=13453
What i noticed while playing yesterday: the tremolo circuit is actually working on both channels. The reverb only works on the second channel. Is this deliberate or have i screwed anything? Thanks a lot!
Re: Hoffman AB763 Tremolo working on both channels??
« Reply #1 on: July 31, 2012, 04:52:16 pm »
You are perfectly fine.
The tremolo on the Hoffman-style boards is applied to the output tubes, rather than on the reverb channel only (as in the original blackface amps). Therefore, you will hear the trem on both channels.
Offline ACHIEVEIT
« Reply #2 on: August 01, 2012, 12:15:02 pm »
That's a relief, thanks a lot HotBluePlates!
