September 17, 2026, 07:22:12 am
Hoffman Amps Forum image Author Topic: Identifying components from hamfest haul  (Read 7814 times)
Offline thelonious
  • t00b n00b
« on: August 10, 2012, 10:17:44 pm »
Got a huge box full of resistors for $5---you gotta love hamfests. Any takers on identifying a few of the stranger items? I'm assuming not all of these are resistors. Some of them look more like inductors or caps. Thanks in advance!
Re: Identifying components from hamfest haul
« Reply #1 on: August 10, 2012, 10:24:43 pm »
IIRC LC had an amp come thru his shop and had some parts colored like in B and HBP explained the color coding. I thought LC's were R's, but in B it looks like a cap to me.
D is a small choke.
                        Brad     :icon_biggrin:
« Last Edit: August 10, 2012, 10:27:12 pm by Willabe »
Offline thelonious
  • t00b n00b
« Reply #2 on: August 11, 2012, 10:05:19 am »
Thanks, Willabe! I'll see if I can find that thread.
Found out that A is a resistor made by Reon. They must be precision, because they are labeled as 909R, and they test within 0.1% of that!
I think you're right that B is a cap. When I test it with my DMM, its resistance increases slowly to 1.2R, just like a cap charging and showing its ESR or something. My meter reads overload on it in capacitance mode, but it does that with anything over 150-200uF.
Like you said, D is a coil, and C is probably also a coil, or a pair of coils (tiny transformer?). C shows low DC resistance between the two leads on each side and infinite resistance between leads on opposite ends.
E and F are capacitors of some sort (47pF and 560pF), but I'd like to know what their history is. They look very different from other caps I've seen.
I think G is a Philco fuse resistor (fusible resistor? fusistor?). I found an old ebay listing where a guy was trying to sell a NOS one with original box for $70! Obviously no one bought it. :laugh:
H - no idea!
I - high value resistors, labeled as 66M. But again, they look so different from what I usually see, and I'd love to know the history and function behind some of these parts just for fun, like, "That's a flameproof resistor type that was used regularly in industrial settings..." etc...
As I figure things out (or more people chime in!), I'll edit the original post and label stuff. I don't think these things will be much actual use, but it's fun to puzzle over. :icon_biggrin:
« Last Edit: August 11, 2012, 10:28:41 am by thelonious »
« Reply #3 on: August 11, 2012, 10:53:00 am »
PRR, Sluckey and HBP will know what those parts are and there use.
                 Brad      :icon_biggrin:
Offline cbass
  • I like stuff
« Reply #4 on: August 13, 2012, 11:55:38 am »
E and F look like Polystyrene caps.
« Last Edit: August 13, 2012, 12:03:45 pm by cbass »
We are all criminals here.
