September 17, 2026, 02:09:00 am
Hoffman Amps Forum image Author Topic: Power control with a VVR on G2 - what do you think about ?  (Read 7960 times)
« on: August 24, 2012, 05:04:03 am »
I was looking for a PT at TubeTown and I've seen this circuit (only for cathode bias amps)
a VVR to be used as to control power
regulating G2 voltage instead of plate voltage
http://www.tube-town.net/diy/tt-needfull/03-ttvoco.html
http://www.tube-town.net/ttstore/product_info.php/info/p5651_Kit-TT-VoCoM---Variabler-Spannungsregler.html
that is new for me
what do you think about this way of power regulation ?
Re: Power control with a VVR on G2 - what do you think about ?
« Reply #1 on: August 24, 2012, 05:45:28 am »
seems like it would work...
something similar - just not setup for variable power output control.
http://www.el34world.com/Forum/index.php?topic=13634.0
« Reply #2 on: August 24, 2012, 08:15:21 am »
They say it's good to up to 600 dcv. I wouldn't trust putting 600dcv on that circuit kit/mod.
IIRC, an alpha pot has a 350dcv rating for the resistive track and a 500dcv ark over from track to case? I know the current is very low but still 350dcv to 600dcv is a pretty big leap. They also talk about using their kit for the power tubes plates.
If more heat has to be dissipated; for example, if the plate voltage of the power tubes is to be regulated, then the BUZ90 could get quite hot, and the small heat sink.
A PEC (2w mil. spec.) pot has a 500dcv rating for the resistive track and a 900dcv ark over from track to case. Which is why KOC used them on the early Power Scale kits (VVR), with a PSU limit of 500dcv. Later PS kits have a different circuit and can use any style/rating of pot.
                                  Brad       :icon_biggrin:
« Last Edit: August 24, 2012, 10:21:46 am by Willabe »
« Reply #3 on: August 24, 2012, 01:01:43 pm »
DummyLoad
Thanks for the info
Willabe
I can agree with you about voltage excess on the pot
about the use for plate regulations, instruction report to connect the BUZ90 to the chassis as you can see also on the photo
About this way of regulation (G2 voltage regulation) it will be interesting to know tone response
if this way of regulation give good results I think it will be interesting to be used in high power amps (100W or more) as if we want to regulate plates voltage we need a high spec mosfet
however the fact that the most part of high power amps use fixed bias instead of cathode bias will be a problem
« Reply #4 on: August 24, 2012, 01:25:02 pm »
about the use for plate regulations, instruction report to connect the BUZ90 to the chassis as you can see also on the photo.
I sorry, I was not very clear, I was trying to say some would say you can get away with using that pot with 600dcv on it with only the screens 5 to 10mA's of current. But they also seem to be saying you can run 600dcv on the pot with the full PP output tubes plate current which is around 10X the screen current.      :w2:    All you have to do is use the chassis as a heat sink. But that has to do with the mosfets raitings, not the pot.
                          Brad
« Reply #5 on: August 24, 2012, 03:09:57 pm »
yes, I agree with you about voltage excess on the pot
« Reply #6 on: August 24, 2012, 09:16:16 pm »
In a cathode-bias amp, varying G2 voltage does change max-power 100% to about 10% without large change of gain or distortion shapes.
I don't think it is "The Same" as dropping plate voltage, reducing OT size, etc; but it sure is simpler than carrying all different size amps.
« Reply #7 on: August 24, 2012, 09:47:57 pm »
                                  Brad       :icon_biggrin:
use a high quality multi-turn this one has a 1000V rating and is a 3 turn...
http://www.bourns.com/data/global/pdfs/3547.pdf
--DL
« Reply #8 on: August 24, 2012, 09:50:38 pm »
this one is single turn with a 900V rating.
--DL
« Reply #9 on: August 25, 2012, 03:39:10 am »
PRR
..... without large change of gain or distortion shapes ..... I don't think it is "The Same" as dropping plate voltage ....
do you mean that probably the use as to reduce power will have good results but we must not expect to have the sound of a cranked amp at low power levels ?
DummyLoad
Both are interesting components, the second also has 1/3 of the price or the first one
thanks to both friends
