September 18, 2026, 08:43:16 am
Hoffman Amps Forum image Author Topic: Safely lower B+  (Read 5853 times)
Offline gtrbryan
Safely lower B+
« on: September 01, 2012, 11:49:49 pm »
I have an old PA that I converted into a champ with lots of bells, whistles and switches. The PT is 360 secondary for 110v. I'm getting about 485.  I am using a 5Y3 and am getting more volts out of it than I would expect. I'm going to try another 5y3 and see if it brings it down.
If I need to knock it down further, I have a 200 ohm 25 watt resistor.  Anyone see any problems in putting that  between the 5y3 and the first filter cap?
stratele52
  • Guest
Re: Safely lower B+
« Reply #1 on: September 02, 2012, 04:30:37 am »
Resistor will give too much sagg and voltage will vary with power output. Better use some Zener diodes ( 10 volts , 5 watts at $0.50 each ) .
You put some in series with the center tap ( B + ) on your power transformer,
Re: Safely lower B+
« Reply #2 on: September 02, 2012, 04:38:49 am »
If the amp is an SE, no much worry about SAG
stratele52
  • Guest
Re: Safely lower B+
« Reply #3 on: September 02, 2012, 05:25:16 am »
Yes , but only  if the amp work in ( real ) class A.
Re: Safely lower B+
« Reply #4 on: September 02, 2012, 09:21:56 am »
His amp is SE Champ type, it has to work in real class A.
              Brad     :icon_biggrin:
Re: Safely lower B+
« Reply #5 on: September 02, 2012, 10:03:04 am »
Nevertheless, if you can't lower it with a proper 5Y3GT rectifier, then some reverse-biased zeners in series with the HT winding's CT and the ground are the simplest way to go. Use 9V, 12V, or 15V zeners with a 5W rating, and put them in series (banded end(s) pointing to ground)
stratele52
  • Guest
Re: Safely lower B+
« Reply #6 on: September 02, 2012, 02:52:29 pm »
              Brad     :icon_biggrin:
No , We have to check bias to say . Class A is not only a cathode with a resitor . Tube should operate at a very high current too. Resitor and tube must be matched.
That 's why I write " a real Class "
stratele52
  • Guest
Re: Safely lower B+
« Reply #7 on: September 02, 2012, 02:53:35 pm »
This is my opinion too : ......the simplest way
