September 14, 2026, 11:17:34 pm
Hoffman Amps Forum image Author Topic: power supply filtering  (Read 5684 times)
Offline CraigB
« on: September 06, 2012, 12:22:29 pm »
Hi, All!  The weekend's almost here.  Time to get working on another amp project  :icon_biggrin:
See attached.  I don't think I've ever had the need to place e-lytic caps in series (to get the benefit of a higher voltage rating) and parallel (because I want to double the amount of filtering).  If what I'm after is a total of 100uF filtering with a voltage rating of 700v, I can't see any reason why this wouldn't be a fine way to do it.  Any disagreement with that or "why don't you do it this way instead?" is welcome.
I have the 100uF/350v radial caps on hand, they are relatively small/short, and will fit my board better than two 220uF/350v axials.
Thanks!
Craig
Re: power supply filtering
« Reply #1 on: September 06, 2012, 12:53:13 pm »
I think your "scheme" is correct and if you have those cap why don't use it ?
prefer other cap you already have, only if they are rated for a higher temperature
(700v rate must be read more as 550/600v)
I think you know that if the rectifier is a vacuum tube the first capacitor must be of a max value depending on the tube you use, no problems with SS rectify
stratele52
  • Guest
« Reply #2 on: September 06, 2012, 05:18:09 pm »
Good schematic  this is a total of 100 MFD . Could be too big for tube rectifier, ok for silicon rectifier
« Reply #3 on: September 06, 2012, 09:58:58 pm »
Also, 50uF is not much below 70uF. Old-school e-lytic tolerances were on the order of +100/-50%.
If you feel you need 100uF of main filter, your plan is perfectly acceptable.
If 50uF might work, you could save two caps. If that filtering is insufficient, a second series pair (two 100uF's for 50uF total) after a choke or small decoupling resistor might give you better filtering. Recall that the series impedance/resistance of the choke/resistor helps the cap better knock down ripple.
Then again, you might not want to spend for the choke, and may not wish to waste heat/power in the decoupling resistor.
« Reply #4 on: September 07, 2012, 12:32:30 am »
And furthermore, you could replace that lower 220k bleeder with a ~1/5th voltage divider (say 180k and 39k in series), decoupled at the knee with a 10uF 100V cap, and use that point for heater elevation. (This should give you ~1/10th* of the B+ voltage at that point)
* actually slightly less that 1/10th - but its only geetar amp math :-)
« Last Edit: September 07, 2012, 12:36:50 am by tubeswell »
« Reply #5 on: September 07, 2012, 04:43:38 am »
Tubeswell
please can you explain better
or draw a little scheme
« Reply #6 on: September 07, 2012, 07:42:49 am »
« Reply #7 on: September 07, 2012, 10:02:49 am »
Oh, now I understand  :bump1:
Thanks Sluckey
« Reply #8 on: September 07, 2012, 12:51:52 pm »
Sluckey beat me to it
Offline CraigB
« Reply #9 on: September 07, 2012, 06:08:52 pm »
Thanks very much for all the responses!  Solid state rectifier -> 100uF -> VVR where only the power tubes and PI are regulated.  I've built this same amp before, only with a tube rectifier.  This one has a little different power transformer.
I like that idea.  Thanks!
