September 16, 2026, 01:44:23 pm
Hoffman Amps Forum image Author Topic: VVR and SS inductors  (Read 11574 times)
Offline rzenc
  • TUBES RULE
« on: September 08, 2012, 12:43:00 pm »
Hi,
I’m building a stand alone all tube guitar preamp for metal purposes... I would like to experiment with VVR and SS inductors.
SS inductor is as presented in Merlin second book, pg.83, fig.4.18. Is there benefits regarding lowering noise floor by employing multiple cascaded stages? would it be worthy the trouble?
VVR is duplicated from Tubenit’s 56T. It’s 3x12AX7 and 1x12AU7. I will scale the whole preamp B+.
Do you guys think it could work?
Thanks in advance!!!
Best Regards,
R.
Offline rzenc
  • TUBES RULE
Re: VVR and SS inductors
« Reply #1 on: September 10, 2012, 08:28:38 am »
Howdy guys!
Mouser listed NTE2973 as not recommended for new designs... :w2: Is there a substitution part avaiable?
Or, could we use IRF820??
Thanks in advance
Best Regards
R.
Offline zendragon63
  • Vacuum Packed Tone
« Reply #2 on: September 10, 2012, 09:13:33 pm »
Hey rzenc, I have used the STP2NK90Z instead of the NTE2973 though the specs as I understand them look like overkill for your application. I haved used it successfully in several VVR applications from 10W to 40W amps. Compared to the 2973, its pretty cheep cheep at $1.18 each at Mouser here in the US. It also has zener protection built in so you can dispense with the 10R 3W and the 12V zener. Still needs to be heat sinked.
 http://www.mouser.com/ProductDetail/STMicroelectronics/STP2NK90Z/?qs=sGAEpiMZZMvAvBNgSS9LqkIU81bJj8Iw
If you want to compare specs, there is a data sheet link in the above you can reference. I am no expert on power MOSFETS but I suspect that there are probably dozens that could be used to vary the higher voltage feeds.
Others may chime in as to what they are using. Regards
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
Offline jazbo8
« Reply #3 on: September 11, 2012, 01:11:36 am »
Hi,
Best Regards,
R.
I think they will work, but just curious, why scale the preamp and use a SS choke for low power app? Usually the VVR is used to scale the PA, sometimes the PI, and yes the whole amp sometimes, although that's not as common. Since the current requirement is low, a small choke should be pretty cheap, so you are not saving that much with a SS choke. Then again, there is nothing wrong with experimenting.  :guitar1
Jaz
Offline FYL
« Reply #4 on: September 11, 2012, 08:11:04 am »
Most mosfets are designed for switching applications. They use a very small die with quite poor thermal coupling to the case/tab/... and behave quite badly with steady state B+ in the 200 mA+ range, even if they are rated at 2 A or more.
Offline rzenc
  • TUBES RULE
« Reply #5 on: September 19, 2012, 03:54:39 pm »
Thanks for the answers guys!!
Since it's a preamp stand alone unit, I calc around 30mA at most...
SS electronics are new ground to me...I would like to experiment with these ideas...
I checked IRF820 specs and it suggests 50W of power handling...Current consumption will be greater with higher B+, which I plan to be around 400V. I would like to be able to drop it to 1/3B+ if possible, which is around 130V. I also believe it will be necessary to try and adjust it to taste or to feel it's effect.
I got this idea after studying some high gain preamps and noting how B+ changes from one design to another...
The idea of SS choke comes from building a lighter unit and also to try to understand how and why it works like it's supposed...theory madman!! :think1:
But I also think you guys are right, a 30-40mA choke would be cheap.
What called my attention is the fact that this SS choke Simulates a 47H choke..which would be expensive to get made...and also the possibility to cascade multiple stages and drop noise floor considerably... This preamp is going to a recording studio...
So I have multiple goals in mind:
a) be able to vary B+ and so headroom;
b) lowest noise floor I can manage to get;
c) light unit;
d) keep cost down.
I will keep posting results since I will start building it next week.
All thoughts are welcome and greatly appreciated!!
Thanks guys!!
R.
Offline jazbo8
« Reply #6 on: September 20, 2012, 02:45:34 am »
Since the current requirement is so low, I think a VVR for B+ will do, not sure you will even need a choke, electronic or otherwise - less parts, less cost, etc. Of course, you can also just change the Rk's to play with the headroom and the clipping level and leave the B+ alone...
Jaz
Offline rzenc
  • TUBES RULE
« Reply #7 on: September 20, 2012, 07:57:31 pm »
After some more reading and brain-cooking, I decided to try on thing at a time. I will start by trying VVR.
Does this drawing looks alright to you?
Thanks in advance!
Best Regards,
R.
Offline rzenc
  • TUBES RULE
« Reply #8 on: October 10, 2012, 05:22:12 pm »
Regarding the installation of STP2NK90Z or any other type of mosfet for VVR application, do I need additional protection like mica insulation to employ heat sink?
Thanks in advance
Best Regards
R.
« Reply #9 on: October 11, 2012, 01:39:52 am »
Without the use of an insulator the heat transfer is better, however you will have voltage on the heat sink
I've seen montages without the heat sink, but only on low voltage projects
with voltages on the order of hundreds volts (like in guitar amp) I think you must use an insulator also if the heat sink in inside the chassis, an  unaware technician might suffer the consequences
Offline rzenc
  • TUBES RULE
« Reply #10 on: October 11, 2012, 05:53:23 am »
What you guys suggest?
Offline rzenc
  • TUBES RULE
« Reply #11 on: October 11, 2012, 06:50:43 am »
« Reply #12 on: October 11, 2012, 04:36:24 pm »
I like the thermal pads, not the mica. Mouser and Digikey both have them.
Mica can crack and short to the chassis.
              Brad     :icon_biggrin:
