September 14, 2026, 10:20:42 pm
Hoffman Amps Forum image Author Topic: Super Reverb AB763. Done. Sound but issues!  (Read 32390 times)
Offline SleepLess
« on: September 22, 2012, 06:16:51 am »
Hi.
I have just finished placing all the resistors and caps on the fibeboard but for one thing: the 10M resistor soldered on the lower left leg of the optoisolator. I don't have any 10M resistor, all I have is a 8M2 and some 1M and 2M2. Can I just solder the 8M2 instead or must I really place a 10M there? What would be the consequences of soldering a lower resistance there?
Gut shots will come in due time...  :icon_biggrin:
« Last Edit: September 26, 2012, 10:26:32 am by SleepLess »
Offline Raybob
    • Tube-Tone Amplifiers
Re: Super Reverb AB763
« Reply #1 on: September 22, 2012, 07:28:22 am »
Put the 8M2 in series with a 2M2, and you will be within the 10% tolerance.
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #2 on: September 22, 2012, 10:08:02 am »
or measure the 8M2, it might be close to 10, anyway a 9M would be just fine in there
P.S.: call me Alvin.
Offline SleepLess
« Reply #3 on: September 22, 2012, 10:09:44 am »
Thanks a lot guys!
Offline SleepLess
« Reply #4 on: September 23, 2012, 06:47:36 am »
One question guys... I have a brass grounding plate that I have installed and intend to use as a grounding scheme. The thing is that upon viewing 1960's models the pots are grounded to the brass plate from the left lug to the plate. But is that really necessary as the pot is already actually grounded through the mechanical connection between the pot and plate? Must I really add that extra grounding wire?
Thanks!
« Reply #5 on: September 23, 2012, 07:36:51 am »
I haven't seen the insides of many original '60s Fender amps, but I don't recall a separate ground wire for the pots. I remember the lug being bent over and soldered directly to the pot body. Then the pot nut/washer make a mechanical connection to the brass plate. That arrangement has caused a lot of booger grounding problems.
I would use a separate wire from the pot lug directly soldered to the brass plate just to avoid relying on the mechanical connection of the pot body. And I woulduse a wire to connect the brass plate directly to the filter caps rather than rely on the mechanical connection between the brass plate and chassis. Many times different metals in contact will cause a galvanic reaction that will corrode and cause a poor electrical connection. Here's a pic of a '64 DR that clearly shows Fender's grounding plate. Again, I don't recommend this method.
Offline SleepLess
« Reply #6 on: September 23, 2012, 07:47:50 am »
Look... This one has been modded (strange things going on with the bias pot there!!!) but you can see the black grounding wires going down from the pots to the plate.
I intended to ground the filter caps to a PT ground lug along with the HV CT and HT CT.
« Reply #7 on: September 23, 2012, 08:31:43 am »
That amp is a later model Silverface AB568. That bias is the stock balance type. And those big ole 150Ω/7W resistors on the output tube cathodes are also stock. Same for the 2000pF caps on the grids.
Offline SleepLess
« Reply #8 on: September 23, 2012, 08:34:29 am »
Yes, it's from 1968.
But I see the filter caps are grounded to a PT bolt and the pots to the brass plate. Can I implement this or do you recommend to get rid of the brass plate and install a floating buss bar instead?  :dontknow:
« Reply #9 on: September 23, 2012, 08:52:13 am »
I prefer the bus bar but if you build in a shallow slope faced Fender style chassis, there may not be enough room. The brass plate is fine if it is securely connected to the chassis. I don't like to rely on the pot nuts for a ground though. Too easy to loosen. This is all opinion and there are several methods that have worked well for decades.
Offline SleepLess
« Reply #10 on: September 24, 2012, 10:25:32 am »
OK guys. The amp is finished. That was a long job!!! I just need to wire the cabinet and of course recheck everything one last time before firing it up. There's just one thing I'm not totally confident about, it's my AC switch / fuse wiring.
Here's what I did with the MM PT Toneclone FBFS-P40/100-240 which as a dual primary. This made me end up with a brown wire and a white wire to use. The brown one is OV (COM) and the white one is 240V. So I soldered the brown one to the AC switch and the white 240V to the side of the fuse. Then the AC cord has its black wire to the center lug of the fuse holder and the Neutral white to the AC switch. I don't know if that's 100% correct and if I'm not missing a connection there...
Now gut shots, if you see anything strange, just say so. I plan to fire it up tomorrow.
Offline SleepLess
Re: Super Reverb AB763. Done. Gut shots!
« Reply #11 on: September 24, 2012, 11:56:55 am »
Just in case you'd need it to help me sort out that fuse /ac switch wiring here's the PT schematic, I wired it for 240V operation:
Thanks!
Offline phsyconoodler
« Reply #12 on: September 24, 2012, 11:57:49 am »
Nice work! That looks very neat and tidy.Well done!
Where did you get that thick cloth wire from?Looks cool.
Offline SleepLess
« Reply #13 on: September 24, 2012, 12:01:02 pm »
Thanks!!!
Got it from Antique Electronic. But let me tell you it's a freakin' pain in the... to work with. It doesn't pull back and the wire stripper doesn't work with this, I had to cut each wire end with a cutter...
Offline SleepLess
« Reply #14 on: September 24, 2012, 03:24:19 pm »
I have reversed the white and brown wires. Com now goes to the side of the fuse and 240V goes to the AC switch.
Switched the ON/OFF switch ON without tubes and checked the ac hot lug I have 232V. All the heaters are at 3.21 VAC.
« Reply #15 on: September 24, 2012, 03:33:13 pm »
Beautiful! Very nice twisted pairs too!
              Brad      :bravo1:
« Reply #16 on: September 24, 2012, 09:28:22 pm »
Yes, I would strongly advise to use Doug's cloth wire over the AES "cloth covered" wire. The AES product is regular PVC insulation with a non-waxed cloth cover over that.
As Sleepless mentions, you can't do the push-back technique with it. Further, the cloth cover is a lot like a shoelace, and its weave will loosen and fray where it is cut. Without a lot of care (or your own applied wax), it will give a poor-looking result. None of these problems with Doug's wire.
I've got a bunch of spools of the AES stuff, which I foolishly bought in bulk before seeing this wire in person. If I haven't already trashed it, the wire is just sitting around because it's too much of a pain to get a professional finish with it.
Offline SleepLess
« Reply #17 on: September 25, 2012, 12:06:49 am »
Absolutely... Bought it in 50ft spools too... Dang... They'll get trashed or will sit around as well...
« Reply #18 on: September 25, 2012, 01:30:18 am »
Yeah, Nice job.  :icon_biggrin:
Offline SleepLess
« Reply #19 on: September 25, 2012, 09:15:12 am »
Thanks but dang... It's not working at all... I get correct readings but no sound at all...  :BangHead:
« Reply #20 on: September 25, 2012, 10:03:03 am »
When did that happen? Wasn't it working before?
                   Brad      :w2:
Offline TubeGeek
    • Glacier Amps
« Reply #21 on: September 25, 2012, 11:07:49 am »
I did the same thing, ordered a bunch of the wire and now it sits unused.
Offline SleepLess
« Reply #22 on: September 25, 2012, 12:52:19 pm »
                   Brad      :w2:
NO, all I did before was turning it ON (left the stdby ON) without tubes just in order to check the heaters. They are good.
Today I inserted all the preamp tubes and everything went OK.
Then I inserted the 6L6GC and turned it ON. I have -60V at the bias pot, 470V B+ where it should. But I have absolutely no sound at all...  :BangHead:
Here's one thing I'm thinking about and I'd like you to tell me what you think as this is most puzzling to me... The MM OT schematic shows two different wiring possibilities which is most confusing. I love that stuff... "Wire it as such and if your OT blows, well bad luck, you had to wire it the other way..." Check this joke out, I chose the second method with black as COM and green as 2 ohms, and if that's the wrong choice what happens? Blows the OT? Or no sound at all as I'm currently experiencing? Thanks!
« Last Edit: September 25, 2012, 01:25:39 pm by SleepLess »
Offline rzenc
  • TUBES RULE
« Reply #23 on: September 25, 2012, 01:26:37 pm »
Divide and conquer....
With tubes in you are not getting any sound?
If so, try poking on control grid pin 5 of power tubes...there should be some noise...work you way towards input touching control grids from PI, rev recover, rev drive, input tube... Noise generated will be gradually louder each time you hit a previous stage on amp design.
Also, your bias point -60V seems too low...try to measure mV on 1ohm cathode resistors and write down how much current is getting thru the bottles...
Hth
Best Regards
R.
Offline SleepLess
« Reply #24 on: September 25, 2012, 01:30:57 pm »
Hth
Best Regards
R.
OK will do that. I have -66 V on the 10KL bias pot down to -47V when turned up full...
Offline SleepLess
Re: Super Reverb AB763. Done. No sound!
« Reply #25 on: September 25, 2012, 03:46:43 pm »
OK.
I reversed the black and green OT wires and I still don't have any sound...
« Reply #26 on: September 25, 2012, 04:19:03 pm »
Usually it's the input or output jacks that get miswired on builds like yours.
If ALL the voltage are right then that's where I would look.
  Reversing the OT leads is only useful in the event that the amps squeals when turned on.
What are the control grid voltages on the preamp tubes?
These wire strippers will work on that kind of wire.
« Last Edit: September 25, 2012, 04:23:57 pm by phsyconoodler »
« Reply #27 on: September 25, 2012, 05:08:57 pm »
You can try this, unplug the reverb output that goes to the verb tanks input. Hook up a 8 ohm speaker to that verb output RCA jack and see if you get any sound out of it with your guitar pluged in to the amps input jacks. If you do then you know it's after that point in the amp that's not right.
                  Brad      :icon_biggrin:
« Last Edit: September 26, 2012, 08:23:32 am by Willabe »
Offline SleepLess
« Reply #28 on: September 25, 2012, 05:11:56 pm »
Voltage chart guys.
Heater voltages are all at 3.1VAC. All measures taken in DC.
Pin            V1          V2         V3          V4         V5         V6        V7          V8          V9
1             182         273       463         289        459       266       -63         -63
2               0            0          0            0          -46        63                                   470
3             1.15        1.98      9.6          1.93        0         103       471         471
4        469         469          356VAC
5        -63         -63
6             239         288       465         291        400       253       469         469          356VAC
7             1.3           0         0.4           0          -48        69
8             1.3          2.3       9.6          1.9          0         103        0             0           470
Strange to have 0V on pins 4 and 6 of the rectifier right?
Thanks for your help guys!
« Last Edit: September 25, 2012, 05:21:50 pm by SleepLess »
« Reply #29 on: September 25, 2012, 05:17:03 pm »
Pins 4/6 on the rec. tube will be AC, did you have your meter set for AC?
               Brad      :think1:
« Reply #30 on: September 25, 2012, 05:20:13 pm »
The rectifier pins are measured in AC volts.They get rectified to DC at pin 8.
Offline SleepLess
« Reply #31 on: September 25, 2012, 05:21:09 pm »
 :BangHead:
Rectifier pins 4 and 6 are 356V AC...
I'll edit my voltage chart!
Thanks Brad, this one is making me lose my mind!
« Reply #32 on: September 25, 2012, 05:22:50 pm »
Lets see some closeups of your output jacks and input jacks.
« Reply #33 on: September 25, 2012, 05:25:56 pm »
He has -63dcv for bias.
Is that enough to bias the output tubes into full cut off?
                  Brad    :think1:
Edit; Nope I'm wrong, Fender schemo says -52dcv for bias.
« Last Edit: September 25, 2012, 05:29:20 pm by Willabe »
Offline SleepLess
« Reply #34 on: September 25, 2012, 05:30:45 pm »
I hope these will be good enough. Say so if you need other angles or anything else... And thanks already!
Offline punkykatt
« Reply #35 on: September 25, 2012, 08:00:40 pm »
Are the green and black wires from the OPT reversed on the jack? I always thought black was to go to ground?
Offline SleepLess
« Reply #36 on: September 26, 2012, 03:23:43 am »
Yes, that's what I wrote in an earlier post. I reversed them to check if I'd get any sound because of the OT's schematic which shows two possible wiring configurations (thanks MM!). I had them reversed before and didn't have any sound eitherl...
So if I understand correctly my voltage chart is good and my inputs and outputs are good... So what the hell could it be...  :cussing:
Offline SleepLess
« Reply #37 on: September 26, 2012, 06:57:13 am »
OK. One more voltage chart as I have some differences now, particularly on V1 pin 7 where I now have 0V and on V1 pin 6 where I now have 298V instead of 239V and also on pin 8 where I have 1.89 instead of 1.3. I also now have some voltage on pin 2 of V3 where I had 0V before... I set the bias hotter (tubes biased at 39mA for V8 and 34mA for V7). I have -51V on the bias pot middle lug and my B+ is 451V.
All heater voltages are still at 3.1VAC.
1             180         267       451         282        447       259       -50         -50
2               0            0        1.4            0          -46        61                                   456
3             1.15        1.95      9.7          1.88        0         100       455         4551
4        454         454          358VAC
5        -50         -50
6             298         260       450         283        387       243       454         454          358VAC
7              0            0         0.5           0          -48        68
8             1.89        1.89      9.6          1.9          0        100        0             0           457
I'm lost. I need your help...
Thanks!
Offline SleepLess
« Reply #38 on: September 26, 2012, 07:42:23 am »
Hth
Best Regards
R.
I did all this and poked everywhere with a chopstick. No sound at all. The amp is as quiet as a church mouse even with all knobs on 10...
« Reply #39 on: September 26, 2012, 08:25:54 am »
Did you try this?
It will tell you if it's pre or post of the reverb. Help you narrow down where to look.
                        Brad      :icon_biggrin:
Offline SleepLess
« Reply #40 on: September 26, 2012, 08:29:29 am »
No I didn't willabe, I don't have any RCA to 1/4" jack converter... If I understood what you said correctly... Thanks!
« Reply #41 on: September 26, 2012, 08:38:41 am »
Yes I think you understand.
You could use jumpers. You only need to see if you get any sound for a few seconds.
                   Brad       :icon_biggrin:
Offline SleepLess
« Reply #42 on: September 26, 2012, 08:59:02 am »
I can't do that test Willabe... I don't have the needed tools (jumpers). I have reversed the white and brown wires from the PT, the ones that go to the side of the fuse and the AC switch and to my surprise the amp reacts just as it does with these wires wired the opposite way.
The amp reacts on standby exactly like it reacts off standby. Except that the readings change of course. No sound...   :BangHead:
I think I'd rather have a noisy amp than a silent amp. At least a noise is easier to locate and fix... What can you do when the amp remains silent all the time. I stuck a stick on each eyelet, each pin, each wire and nothing, absolutely nothing... I'm totally stumped...
« Reply #43 on: September 26, 2012, 09:10:14 am »
Ok, 1 last thing you could try.
If you have an extra 1/4" jack you could temp it in in place of the RCA verb send jack. It's only 2 wires. You don't even have to take the RCA out of the chassis.
The guys always say "divide and conquer". This will split/divide the amps circuit in half.
I'm gonna write Santa a letter and ask him to bring you some jumpers for Christmas.
                Brad       :laugh:
Offline SleepLess
« Reply #44 on: September 26, 2012, 09:45:58 am »
OK. Now comes another big debugging phase...
The problem was the speaker jack which had a short. I used another jack to connect the amp to my 8 ohm 1X12 cabinet and the amp made a noise. I changed the speaker jack on the SUper Reverb and now I'm getting a sound. BUT:
1. The amp is far from being as loud (and good sounding) as it should. On 7 its volume is like it was on 1.5!
2. The reverb creates a massive increasing hum past 3 on the knob so I have to turn it down.
3. Tremolo works but only if the reverb pot goes past 3. Below that I don't have the effect coming out of the amp, I just hear the oscillation ticking through the speakers. This suggests a bad tremolo/reverb pots wiring but I have checked them and they are wired as they should.
4. I replaced V3 with another tube and nothing changed.
5. The Normal channel volume pot is scratchy as hell and even emits booms when I turn it up, especially between 8 and 10... Changed V1 and I have the same symptoms
At least now I have some sound..; But I still need you guys!
This freakin' amp is a nightmare...
Thanks!
« Last Edit: September 26, 2012, 10:56:50 am by SleepLess »
Offline worth
Re: Super Reverb AB763. Done. Sound but issues!
« Reply #45 on: September 26, 2012, 10:31:20 am »
Hey guys.. I LIKE the wire you're talking about from AES... send it all to me, I'll pay the postage !.. no kidding !
Offline SleepLess
« Reply #46 on: September 26, 2012, 10:34:12 am »
You must be kidding! This wire is utter crap to work with.
Oh and btw if you have any ideas about this SR issues...  :icon_biggrin:
Offline punkykatt
« Reply #47 on: September 26, 2012, 12:44:17 pm »
Try cleaning that volume pot with a good spray cleaner. If its still scratchy there is unwanted DC voltage on that pot (Leaking coupling cap).  Check your reverb cables for shorts and continuity.  Can you measure your power tube cathodes to see how much currant they are drawing?
Offline SleepLess
« Reply #48 on: September 26, 2012, 01:04:56 pm »
Thanks a lot for your help.
I have got some WD-40, can I use it to clean the pot or not? OK about the leaking cap, I'll see after cleaning the pot.
The reverb cables I have are brand new and out of the package. New style.
The 6L6 cathodes are at 0V (posted earlier in my last tube voltage chart). If you're talking about the bias they are at 39mA for V8 and 34mA for V7. I tried those tubes in another amp and they work well despite the unperfect match. Or are you talking about something else? Power tubes cathodes are pins 8 right?
Offline punkykatt
« Reply #49 on: September 26, 2012, 01:15:16 pm »
I would not use WD40. Do you have a Radio shack, Electronic Parts store or Home Depot near you? They have contact cleaner spray that is ideal for cleaning pots.  Clean all the pots while your at it.
Just because something is new does not make it perfect, QC now a days is in the toilet.
Yes, pin 8 is the cathode on a 6L6.  What did you use to get those mA readings?
« Last Edit: September 26, 2012, 01:46:41 pm by punkykatt »
