September 15, 2026, 06:51:44 am
Hoffman Amps Forum image Author Topic: Is this stuff only for HiFi guy ?  (Read 6566 times)
« on: September 23, 2012, 05:57:45 am »
I've just seen that is possible to find 6L6GC to 807 converters
I've done a bit of research and find some example of the use of this converters
all about HiFi use
Is this kind of adapter useful also in standard 6L6GC devoted guitar amps ?
Offline darryl
    • ValveTone Amplification
Re: Is this stuff only for HiFi guy ?
« Reply #1 on: September 23, 2012, 06:22:33 am »
One potential problem is the 807's 300-volt screen rating, which would likely be exceeded in most amplifiers using 6L6GC's.
Another possible problem is the overall height of the adapter + 807 + insulated top cap.
Other than those issues, it should work fine . . .  :icon_biggrin:
Offline ernie_jr
  • gimme a banana
« Reply #2 on: September 23, 2012, 07:14:03 am »
I have used 807's in a bassman clone and in an ampeg clone. They sound great and never give any problems. One amp is running 500+ volts on the plates and close to the on the screens. They work well.
Ernie
« Reply #3 on: September 23, 2012, 10:34:01 am »
They look like someone's home-brewed piece of t-rubble
« Reply #4 on: September 23, 2012, 12:34:18 pm »
That one were just on the first photo I was able to link
There are others that are more or less professionally build
« Reply #5 on: September 23, 2012, 10:26:27 pm »
The 807 is taller than most 6L6GC's, even more so once you add the converter base and top-cap.
I'd worry about having room to clear the speaker in some amps, and I definitely wouldn't want to mount them upside-down, as in most Fender amps.
« Reply #6 on: September 23, 2012, 11:20:11 pm »
807 is rated 25W Pdiss, significantly less than 6L6GC's claim of 35W.
« Reply #7 on: September 23, 2012, 11:20:37 pm »
if height is problem, consider the sylvania 5933/807W - they're about 3/8" taller than a GE 6L6GC. caveat: you'll need about another 1/2" clearance for the plate cap itself.
--DL
« Reply #8 on: September 23, 2012, 11:37:49 pm »
yes, they'll melt in a 6L6GC amp in same bias conditions. tune bias to push down power dissipation? B+ rises tho when you reduce idle current... pembroke corgi chasing it's phantom tail?
IMO, the 807 adapters are a waste of time unless you're going to sub in amp equipped with 6L6G/GA/GB/WGB.
--DL
« Reply #9 on: September 24, 2012, 01:11:34 am »
Many Thanks to All for answering
