September 17, 2026, 01:38:04 pm
Hoffman Amps Forum image Author Topic: Two rectifiers  (Read 8085 times)
Offline Leevi
    • Rikstone
Two rectifiers
« on: October 04, 2012, 01:54:31 pm »
I added an SS rectifier and a rectifier switch to a 50W Plexi clone and wonder
the huge difference between the cathode currents depending on which
rectifier SS or tube (GZ34) has been selected.
Measured values:
Tube rectifier: 25mA/tube on 482v B+
SS rectifier: 33mA/tube on 466v B+
/Leevi
Offline phsyconoodler
Re: Two rectifiers
« Reply #1 on: October 04, 2012, 02:01:05 pm »
Sure you don't have those mixed up?The tube rectifier should have lower voltage.
Offline Leevi
    • Rikstone
Re: Two rectifiers
« Reply #2 on: October 04, 2012, 03:19:26 pm »
Thanks phsyconoodler, you are right, the voltages have been mixed.
Corrected values:
Tube rectifier: 25mA/tube on 466v B+
SS rectifier: 33mA/tube on 482v B+
/Leevi
Re: Two rectifiers
« Reply #3 on: October 04, 2012, 03:34:19 pm »
The 'internal' plate resistance of the tube rectifier means that it will drop some voltage and lose some current. Is that what you were thinking about?
Re: Two rectifiers
« Reply #4 on: October 04, 2012, 05:05:03 pm »
That doesn't look right. What happens to G1 and G2 voltages?
Offline Leevi
    • Rikstone
Re: Two rectifiers
« Reply #5 on: October 05, 2012, 02:53:02 am »
I wonder the big difference in the cathode current.
The negative voltage on G1 is same in both cases. There is on PT an own tap from which
the voltage is generated. G2 drops of course in the case of tube rectifier since the overall voltage level drops. Maybe I should mention that I'm using 10 Ohm resistors on the cathode.
/Leevi
Offline Leevi
    • Rikstone
Re: Two rectifiers
« Reply #6 on: October 05, 2012, 11:09:06 am »
I solved the problem by changing bias setting circuit.
I'm using a DPDT switch for the rectifier selection and utilized it also for the
individual voltage setting for both cases. Hopefully this is a generic solution i.e.
it's valid even with other power/rectifier tubes?
/Leevi
Offline clyde
Re: Two rectifiers
« Reply #7 on: October 05, 2012, 11:41:05 am »
The DPDT switch is the solution.  I use it switch between a 5Y3 and a 5AR4 and plug in the correct resistor values to set bias for each rectifier.  Well done.
Offline jeff
  • Need input
Re: Two rectifiers
« Reply #8 on: October 06, 2012, 01:24:31 pm »
Do you just switch between SS and tube or just short the tube rect with the diodes? (A or C)
Do you use seperate filter caps for each rect before the switch or switch between tube or SS before the first cap? (B)
Why are you using 10 ohm resistors on the cathode?
« Last Edit: October 06, 2012, 01:41:18 pm by jeff »
Offline Leevi
    • Rikstone
Re: Two rectifiers
« Reply #9 on: October 06, 2012, 05:09:43 pm »
I'm using the switch like in alternative A. The cap is the first filter cap.
In order to make the bias setting easier. Normally I use 1 Ohm resistor but
I didn't find any. The cathode current = voltage over the resistor/10.
/leevi
Re: Two rectifiers
« Reply #10 on: October 06, 2012, 10:09:33 pm »
In the old days, a 10Ω resistor would have been most-typical instead of 1Ω.
Why?
The average tech might have a consumer- or service-grade VTVM, like an RCA VoltOhmyst. The lowest range on many of those meters was 1-1.5v full-scale. 40mV is barely budging the needle off the bottom of the scale on a 1.5v range, where 400mV (40mA through 10Ω) is low on the range but easily readable.
Even if your meter goes lower, the bigger voltage is easier to read accurately. The only trade-off is you mentally shift the decimal point knowing that this is the voltage across a 10Ω resistor.
Offline jeff
  • Need input
Re: Two rectifiers
« Reply #11 on: October 07, 2012, 01:33:52 am »
Cool thanks.
How about the switch? Should you use A,B or C?
Re: Two rectifiers
« Reply #12 on: October 07, 2012, 10:36:06 am »
Sometime ago I was asking about SS to tube rectify switching
(I found a schematic and asked an opinion on this forum)
Mr. Merlin confirmed that this circuit will work fine, only move the standby switch after the reservoir capacitor as to prevent inrush currents that can demage the tube rectifier
Offline Leevi
    • Rikstone
Re: Two rectifiers
« Reply #13 on: October 07, 2012, 10:55:13 am »
I have successfully used this in my 5e3 clones.
/Leevi
Offline jeff
  • Need input
Re: Two rectifiers
« Reply #14 on: October 07, 2012, 11:18:42 pm »
Kagliostro, for some reason I can see your schematic, just a red X in a white box.
Re: Two rectifiers
« Reply #15 on: October 08, 2012, 02:28:13 am »
Hi Jeff
Now can you see the schematic ?
Offline jeff
  • Need input
Re: Two rectifiers
« Reply #16 on: October 08, 2012, 11:11:27 am »
Yes, Thanks.
Why are we disconnecting the heater? Doesn't that mean when we switch we have to wait for the rect tube to heat up? Does this protect the tube?
Re: Two rectifiers
« Reply #17 on: October 09, 2012, 08:19:19 am »
I found that schematic sometime ago and asked about its reliability
Merlin answer is here
That method works fine. There is also no harm in turning off the heater when not in use (except having to wait for it to warm up). In fact, you have the benefit that the valve will last longer!
But: Don't put the standby switch BEFORE the reservoir capacitor. Most recto's do not like that.
