September 16, 2026, 07:27:07 pm
Hoffman Amps Forum image Author Topic: How 2 determine origin of buzz?  (Read 13972 times)
Offline 12AX7
« on: November 10, 2012, 09:33:12 am »
I have troubleshot this home brew marshall style MV amp in the past and been thru a lot. So most obvious things have been eliminated. I'm about to embark on yet another and likely torturous bout of troubleshooting to see if i can get rid of this. The amp has a buzz like single coil noise which happens with all my guitar or cables regardless of whether i use HB or SC p/u's, tho of course much worse with SC. The only question i have right now is how to determine the origin. The buzz decreases as any form of gain reduction takes place either with the guitar vol or amp gain. It's not a hyper gain amp but it does have 3 gain stages. It buzzes way too much even at reasonably low drive.  So I'm not interested right now in ideas on how to fix it, more on ways to  determine as close as possible where this noise is originating?
Offline jim
Re: How 2 determine origin of buzz?
« Reply #1 on: November 10, 2012, 04:33:34 pm »
High gain noise can have many causes.  You should post a photo of the preamp section.  Also be aware of
extrinsic electrical noise from light fixtures etc.  Does the noise abate somewhat when you move your guitar away from the chassis?  Are you using shielded wire to the grids?  Have you pushed around the grids with chopstick and listened?  It could simply be the layout. The most sensitive run is from the input jack itself to the first grid--suspect if the buzz sounds like an open ended guitar cable lying on the floor with no guitar. There are tricks--post a layout photo.   Jim
stratele52
  • Guest
« Reply #2 on: November 11, 2012, 04:08:36 am »
Remove first tube , listen the amp ,if no noise problem is in this circuit ( around tube ) or before the tube.
If noise is there , remove second tube.........
Probably your noise is comming from bad wiring . All tube's grid should have a very very shorter wire , If not they act like antenna .
You could have to install shield wire at each tube 's grid or solder the capacitor or resistor directly on tube's socket.
« Reply #3 on: November 11, 2012, 09:51:34 am »
A picture speaks a thousand words and saves 50 posts!  :l2:
It could be heater related or even the way the trannies are positioned and placed. Grasping at straws until you provide all information possible. I will say again, you don't ever get treated by a doctor w/out making a visit to the office. Same rule applies here and wasting everyone's time until you do so.
Offline 12AX7
« Reply #4 on: November 11, 2012, 10:00:35 am »
Removing any of the 3 AX7's stops the noise. But it's not a long or unshielded grid wire. The reason i said the only question was that i wanted ideas on how to find it, not suggestions as to what it might be, is that i've been thru this on another forum before long ago and posted schematics and tried everything that was suggested and then some. So it's not likely anyone will suggest anything i haven't tried unless it's something quite unique. I spent endless hours trying to find it at this point. So really i was just hoping for any ideas on how to narrow it. Everything suggested so far has been long eliminated. So all i need are ideas on what to do to look for it. I realize there are only so many things and theres probably no further answers, but i'm just hoping someone might have a idea on how to go about it differently. A last desperate effort but worth a shot.
« Reply #5 on: November 11, 2012, 10:43:45 am »
Removing any of the 3 AX7's stops the noise. ... i wanted ideas on how to find it ...
Very valid point.
If you remove a preamp tube of a given channel, you break the signal at the point of that preamp tube. If the signal path is broken, but the noise persists, then the noise has to be happening after the removed tube but before the speaker.
The general technique is to remove the phase inverter tube first (or whatever is the halfway point of the circuit). If the noise stops, it is before the break, and you just ruled out the other half of the amp, greatly saving time.
If this were a very big, complicated circuit, you'd find the halfway point of the remaining-suspect section, and break the signal there; moving to half-of-half-of-half zeros in on the problem in the fastest manner.
However, guitar amps are generally simple enough that this is needlessly complicated. If the noise stops when the phase inverter is removed, replace the phase inverter (some folks overlook that!) then pull the next tube, working back towards the input.
I am assuming you did the pull-replace-pull properly, so that would indicate the buzz stopped when the input tube was the only tube pulled from the chassis. Since this is probably a dual-triode in your case, the buzz originates from somewhere between your guitar and the plate circuit of the latter-half of the input tube.
Now, you could proceed without the quick-n-easy tube-pulling exercise (which is really to help you zero-in before you even remove the chassis from the cabinet), and pick a halfway-point in what you have left, where you will unsolder something to break the circuit. Again, assuming the input tube has 2 cascaded gain stages in your amp's circuit, unsolder one leg of the coupling cap passing signal from the frist stage plate to the second stage grid. Noise stopped? Then it is originating between the guitar and the plate of the 1st tube stage. Noise still there? Then the problem is in the 2nd gain stage.
Again, you could re-solder that coupling cap and unsolder the wire from the input jack to the 1st tube grid to break the circuit in half again. Hopefully, you see the wisdom of cutting the circuit in half to check for problems, then in half again, and so forth so you don't have to work through checking every single element of the amp's circuit.
ALTERNATIVE METHOD: Use an existing small amp and make a "probe" to create the Listening Amp (bottom of this page). You use this in the same manner as breaking the circuit (half of half of half), but you listen for where in the amp the noise does not exist (or in some scenarios, where it does exist). When you find 2 adjacent circuit points where the noise is in one but not in the preceding one, you've localized the area of the problem.
For both these methods, you are finding where in the amp the noise is happening. Once you know where, it's up to your electronic/troubleshooting knowledge to figure out why there's noise and how to fix it.
Note that in some modern amps, there are built-in flaws that mean you'll never be able to get rid of the noise. Such a "flaw" may even be too much gain, which is the amp's character, so there's no way to reduce noise without reducing gain and changing what the amp is. Be aware that silly hi-gain and low background noise in recordings can be obtained through the use of much outboard recording gear and/or heavy editing in a digital environment. You likely can't duplicate some of these results in person, and there was probably tons of noise present during the recording.
Offline Davidg
« Reply #6 on: November 11, 2012, 10:53:53 am »
I dont mean to ruffle your feathers but from what I gather u basically just said you have already recieved help from another forum and the people on this forum couldnt possibly be of help unless they have the silver bullet to kill your "buzz" and it sounds rather insulting.I have found the members of this forum to be the most knowledgeable most helpful on the net and is where I always come if stumped or something I need help with.To say everything has been tried and nothong more can be done unless its an "outside the box idea" is crazy and counterproductive.Troubleshooting os a very frustrating and annoying proccess itself and can understand the feeling of being at the end of the rope with it as I have been there myself.Please if asking for help be corteus enough to post a pic or schem or what these guys ask for.All they are asking for is info so they can help- this is a forum for sharing knowledge and learning about tube amplifiers which requires some effort and a will 2 learn on your part.If you want help do as they ask-if u want someone to fix your amp for u take it to a tech.I dont mean this as a personal attack and understand your frustration but give these guys a chance and u will find your problem.Good Luck and Hang In There!
stratele52
  • Guest
« Reply #7 on: November 11, 2012, 02:01:57 pm »
Don't need to remove the second and third 12AX7 if noise stop after removing the first one.
Trouble IS at the first 12AX7 or before ; from input jack to 12AX7.
A photos of this circuit would help us ,
Offline 12AX7
« Reply #8 on: November 11, 2012, 05:30:29 pm »
Actually, i have long believed it's somewhere at the input, but i have done everything imaginable including replacing every component even the tube socket ! Anyways, one of you said something thats long been on my mind and i have tried to rectify it in the past.....too much gain. In the past i think i was too deep into it and when i tried to reduce gain in various ways it seemed like the tone always changed too much. After someone mentioned it i decided to try it again, and i guess it's because i haven't changed the amp in so long my mind and ears were clearer and i reduced the gain before the master and in the gain stages with great success tonally this time. It also reduced the noise to a very acceptable level. And this house makes all amps noisier than they typically are. So I believe that was probably the real problem. So while still a bit noisy it's much better, and the tone is better to boot. Played it loud last nite in a mix (not a gig, just cranked stereo) and the way it fit in the mix was vastly improved as is the clarity during fast runs.
So thanks for all the replies. That one thing got me to work on what i thought was a unrelated issue till now and it turned out to improve the amp in more ways than just noise. 'Preciate it.....
« Reply #9 on: November 11, 2012, 07:07:44 pm »
There might be a middle ground; i.e., something that is causing buzz which is not resolved, but is apparently reduced with less amplification.
This situation is one where there is a fault making a noise, but you are reducing the amount of gain and thereby making the noise appear less.
The problem for me is I have trouble figuring out where "odd noises" occur without having the amp in front of me. I described probably the best methodology to trace the source of the noise, but I'll admit there's some level of intuition that kicks in when I'm hunting noise myself.
In the last amp I made, I included a ground-lift switch which keeps the chassis bonded to the power cord ground wire, but isolates it from all other amp grounds (signal, tube and power supply) with a resistor and cap. When the switch connects amp grounds to the chassis, I get buzzing.
This is not to say this is the cause of your noise, but an example that it can sometimes be hard to isolate and resolve.
stratele52
  • Guest
« Reply #10 on: November 12, 2012, 04:47:42 am »
I agree and photos of the input to the first 12AX7 will help.
_____________________________________________
12AX7 you provide a good effort to repair the amplifier. Bravo. By cons, your lack of experience forces me to think that there are important details that you can not see.
It is clear to me that your problem (from what you told us) is limited to the entrance to the first 12AX7. Problem of wiring or / and ground. Problem would probably repaired by someone with more experience.
Too bad you did not show pictures, it would help a lot.
Offline 12AX7
« Reply #11 on: November 13, 2012, 08:59:35 am »
Well, i really think the issue has been resolved and the noise at this point is more a product of the house than the amp. As much more quiet as it usually is in other buildings, i imagine at this point it would be quiet anywhere else. But i don't gig anymore so it's rarely out of the house so i can't say just yet. But i have in the past literally changed every single part from input jack to tube socket and to the 2nd stage.
I do have a unrelated question tho. I was reading at another forum where someone said they had a problem where one of thier amps was less clear when the guitar was turned down then his other amps. He said he finally fixed that by replacing the cable from the jack to the first grid with regular hookup wire. The former wire was very small shielded cable and the clearer sounding amp used a piece of guitar cable. All i can think of is the small cable has the shield much closer to the signal conductor because the overall diameter is so small, about 1/3-1/4 as small as a guitar cable. The reason i mention this is the input cable on mine is that very small shielded cable. It's teflon and maybe 1/16" diameter. Could i be losing clarity from this and therefore be better off using guitar cable? (and yes, it's grounded only at one end)
stratele52
  • Guest
« Reply #12 on: November 13, 2012, 10:10:58 am »
if you use an audio cable , not RF cable , there is no problem for small cable the lenght is so short.
What you read about a guy who replace is shieded cable with a regular hookup wire an since that no noise.
Sometimes he make a mistake or bad solder with is shieded wire and when he put another wire he do not repeat the mistake.
Offline 12AX7
« Reply #13 on: November 13, 2012, 10:59:34 am »
No, he wasn't even talking about noise. He was saying when he turned down the guitar volume it would get too muddy on that amp, but the SAME guitar on the other amp would not get so muddy when turned down. he said the amp that stayed clearer sounding had the guitar type shielded cable from the input jack to the 1st grid,  and the amp that got muddy had a very small shielded cable which when changed to unshielded hookup wire then no longer got muddy when the guitar was turned down. Someone suggested that small shielded cable was the reason.
« Reply #14 on: November 13, 2012, 11:49:37 am »
I don't know why it only seemed to be noticeable when he turned down the volume on his guitar, but....
All shielded cable has some high end loss due to capacitance loss. A capictor is 2 conductors seperated by an insulator. The center wire and shield are the conductors seperated by the inner wires insulator. Any high end leakage from the inner wire through the insulator to the shield gets bleed off to ground.
Wire companys post specs for capacitance leakage for each shieled wire type they make. Best to use the lowest leakage type you can afford/get a hold of.
I've used George L shielded cable that I bought from Doug for input jack to 1'st preamp tubs grid. Worked great. I forget who here said they use it, it was a good tip.
                 Brad        :icon_biggrin:
« Last Edit: November 13, 2012, 12:42:48 pm by Willabe »
stratele52
  • Guest
« Reply #15 on: November 13, 2012, 01:44:45 pm »
Thank's 12AX7
Offline 12AX7
« Reply #16 on: November 13, 2012, 07:17:34 pm »
Well, this is really bizarre. I tried removing the shielded cable from the input to the first grid and a second shielded cable from the gain pot to the 2nd grid and replaced them with 18 gauge teflon hookup wire like i used on the whole amp. (cept for the heaters which are 18) The tone was improved in that it sorta lifted the proverbial blanket on the speaker a bit and theres more detail. Just more high end maybe, but in any case it's good. But whats weird is i think the amp is quieter. Certainly at the very least it's AS quiet. I can't for the life of me figure out why that is. But the tone is better so i'm it's staying even if the noise is the same.
« Reply #17 on: November 13, 2012, 07:50:14 pm »
What was the brand of shielded wire was in there?
                   Brad     :icon_biggrin:
Offline 12AX7
« Reply #18 on: November 13, 2012, 08:16:29 pm »
No idea, but it was very high quality teflon with real nice silvered conductor. Very small tho.
« Reply #19 on: November 14, 2012, 07:02:24 pm »
I don't typically use shielded cable in my amps. Why? Because I don't need to; they're plenty quiet with regular hookup wire.
Many folks read the "cures" for various problems; but those cures are suggested for one of many causes for, say, hum. The cure they select may not apply to their particular problem.
Shielded input wire for instance. Most of the time you don't need it. Often, there are other errors you're making when it does resolve a problem. But, of course, when you do need it, nothing else will work.
What the world really needs is a good illustrated book that shows outstanding build practices, layout and lead dress, and also the less-than-ideal ways that still work and why they work. It would also be good to include the tradeoffs you make to accommodate a less-than-ideal layout/lead dress that you're forced to do due to circumstances.
That's because a shielded wire fits the definition of a capacitor: it is two conductors (hot, shield) separated by an insulator.
All wire has some amount of effective capacitance when used in an amp circuit; shielded wire has more capacitance than plain hook-up wire because of its construction.
However, there are some shielded wires with more capacitance than others. It shouldn't make a huge difference in a guitar amp, but could be audible. That said, having a ton of series resistance leading up to a tube grid will also shave highs. The total effective capacitance from the tube grid to ground (with includes tube input and Miller capacitance, as well as wiring capacitance) interacts with resistance in the circuit to define a Hi-cut filter. Same way a grid stopper does its job to stop oscillation at RF.
So if either capacitance or resistance get too big, the treble reduction may become audible. You can attack either element to bring highs back; like reducing grid stopper resistance if you absolutely had to keep the shielded cable.
stratele52
  • Guest
« Reply #20 on: November 15, 2012, 03:36:31 am »
+1 HotBluePlate.
What you say need a serious study and reading . Most of the people here want just to built an amp and shield wires do a good job for their need.
