September 15, 2026, 10:14:44 pm
Hoffman Amps Forum image Author Topic: disguise the obvious  (Read 7194 times)
Offline worth
« on: November 21, 2012, 04:39:36 pm »
I need to disguise my tweed tremolux build components, like Louis Amps does , ( all values are artfully obscured ) so no one will know he's just copying Fender ...  any tips on deception ? What IS that material that covers the resistors and capacitors ?
« Last Edit: November 21, 2012, 04:43:03 pm by worth »
Offline TubeGeek
    • Glacier Amps
Re: disguise the obvious
« Reply #1 on: November 21, 2012, 04:46:38 pm »
What happens when the amp needs servicing and it can't go back to the original builder?  Say a cap blows or resistor burns up, no indication or way of measuring with a meter?
This seems silly to me.
Personally I'd never purchase an amp that is clearly trying to hide something.
It's pretty easy to see what is going on there even with the cover up.
To me it looks like some kind of paint or liquid electrical tape kind of coating.
« Last Edit: November 21, 2012, 05:15:36 pm by TubeGeek »
Offline worth
« Reply #2 on: November 21, 2012, 05:07:27 pm »
Personally I'd never purchase an amp that is clearly trying to hide something.'
To me it looks like some kind of paint or liquid electrical type kind of coating.
Well .. you would just look at the original schematic, and then the mods of this circuit .. and size of obscured caps , to see he's just done the same ole 5E3 mods , and used a  PT with more current capacity.
« Last Edit: November 21, 2012, 05:10:49 pm by worth »
Offline TubeGeek
    • Glacier Amps
« Reply #3 on: November 21, 2012, 05:17:05 pm »
Yeah but original schematic of what?  It's supposed to be a secret design right? Why else would all the components be covered up?  For good looks?
Offline worth
« Reply #4 on: November 21, 2012, 05:19:28 pm »
Czart!!!! you're right !!
Offline Zipslack
« Reply #5 on: November 21, 2012, 09:38:16 pm »
Seems a little silly, especially with tag/turret layout where you can probe and measure each component (mostly).  But it sure does look purty!
« Reply #6 on: November 21, 2012, 10:22:57 pm »
And it's not hiding anything if you know what you're looking at.
Most of the resistors have the form-factor of Vishay Dale RN65D metal film resistors, the long skinny caps have the form factor of Sozo caps, the short fat coupling cap has the form factor of an orange drop (possibly a polyester 225P version).
I mean why hide anything? As Zipslack said, if you want to discover the secrets, you'll get them from measuring, which no one can prevent when the amp is in the user's hands.
I'm waiting for someone to get inspired by this and create their own little "blackbox" components encased in epoxy... kinda like the Sprague network modules found in some Ampeg tone control circuits.
Offline Zipslack
« Reply #7 on: November 22, 2012, 09:19:44 pm »
I just envisioned a block of epoxy with turrets sticking out of it...."amp modules".  Drop them in, hook up power, pots, and OPT.  Change your amp to another model quickly and easily...must don't expect to ever repair it -- replacement modules only.
Offline phsyconoodler
« Reply #8 on: November 22, 2012, 11:48:50 pm »
Secret circuits need secret sauce.
Offline triode
  • Use the silver solder
    • TheAirtightGarage
« Reply #9 on: November 23, 2012, 06:28:18 am »
I agree with TubeGeek and HBP, but wanted to add:
Are you just going to copy a princeton and sell it? Why? You are now competing with a 1000 other
guys/gals who build fender/marshall/vox and sell them, and they have connections and buying power
(or they look at their time as worthless (e.g. charge no labor)), it is a loosing market, IMHO.
If you are not doing it for the money/a job, and just to have fun, then who cares if someone notices it is a copy?
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
« Reply #10 on: November 23, 2012, 06:40:07 am »
 :laugh:
and secret service
« Reply #11 on: November 23, 2012, 09:21:28 am »
http://www.permatex.com/products/product-categories/adhesives-sealants/epoxies
Link to what exotic pedals uses.  Comes in a spray can and is black.
Offline Zipslack
« Reply #12 on: November 23, 2012, 10:20:34 pm »
Or do like Zinky or Valpreaux - focus on a non-standard, slightly off-the-beaten-path brand that had an interesting sound, as opposed to all the Fender and Marshall clones.
Offline rafe
  • I have tube amps
« Reply #13 on: November 24, 2012, 08:12:55 am »
This is all secret and should not ever have been brought out in the open. If the identity of even one of those caps or resistors is revealed ,it could compromise the value and   integrity of all the rest of them. And you know what happens then....one by one they are removed....They were undercover for a reason.............
Rafe
