September 15, 2026, 05:07:32 pm
Hoffman Amps Forum image Author Topic: OT labeled 0.1 - 20KC +25 DBM - What mean +25 DBM ??  (Read 4750 times)
« on: December 02, 2012, 03:34:46 am »
In the same unit where I recovered the pulse transformers (those of my other post), inside there are two very small chassis (near 15cm x 12cm) labeled as Amplifier, the tubes mounted are a 5654 and a 6aq5
On each chassis there is a small transformer labeled as follow:
TF - 1A - YY
Z 185+600:6000
(1-T-2):(3-4)
25 MA DC UNBAL
01,-20KC + 25DBM
(1-T-2) <50v
(3-4)      250v
S         <10v
what I understand is:
a 0.1 - 20Kc OT with an attitude to have max 25MA of DC current across it, the primary winding (6000ohm) is rated for max 250v - the secondary winding/s (185+600ohm) is/are rated max 50v
But I don't understand a pair of things
What mean the +25 DBM  that follows the frequency response of the OT ?
also
I can understand 25 MA DC but what means UNBAL ?
EDIT: does +25DBM menas that the transformer is rated for max 25mW of power ????
Many Thanks
p.s.: I can't post a photo of the transformer because it is labeled on the face that looks the other components
« Last Edit: December 02, 2012, 04:43:31 am by kagliostro »
Re: OT labeled 0.1 - 20KC +25 DBM - What mean +25 DBM ??
« Reply #1 on: December 02, 2012, 07:39:18 am »
dbm is a unit of power, just as Watt is a unit of power. In my world...
0dbm = 1mW = 0.001W
+10dbm = 10mW = 0.01W
+20dbm = 100mW = 0.1W
+30dbm = 1000mW = 1W
and +25dbm = 320mW = 0.32W
« Reply #2 on: December 02, 2012, 09:16:25 am »
Many Thanks Steve
« Reply #3 on: December 02, 2012, 09:27:52 am »
TF - 1A - YY
Z 185+600:6000
(1-T-2):(3-4)
25 MA DC UNBAL
01,-20KC + 25DBM
Did you read our other thread about using a push-pull transformer in a single-ended circuit? The big problem is a single-ended output tube placing unbalanced d.c. on the primary. Too much unbalanced d.c. reduces the amount of power the transformer can pass from the primary to secondary, may limit bandwidth and in the worst possible case, could permanently magnetize the core.
Your transformer is providing a allowable limit for unbalanced d.c.
« Reply #4 on: December 02, 2012, 11:57:32 am »
Many Thanks HotBluePlates
now I've understand, the unbal = unbalanced refers to the fact that in an SE transformer the DC crossing the primary is'nt balanced by one opposite signal in the other half winding that in the primary of an SE transformer isn't present
