September 15, 2026, 12:08:23 pm
Hoffman Amps Forum image Author Topic: Musicman RP-100, where to install a 1 Ohm resistor for bias ?  (Read 4634 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: December 07, 2012, 09:49:54 am »
Hi !
I am working on a Music Man RP100 and wondering how to do the bias : I just don't know where to solder a 1ohm resistor since the cathode is tied to a transistor. Also,the main problem was a screen resistor totally burnt on 1 tube socket which I replaced: is it possible that a defective tube draws that much screen current ?
Thanx
Colas
P.S.: call me Alvin.
  • MAKE LOVE NOT WAR
Re: Musicman RP-100, where to install a 1 Ohm resistor for bias ?
« Reply #1 on: December 07, 2012, 09:51:31 am »
sorry, I should have said : ....each cathode is tied to a transistor ( 2 tubes ).
« Reply #2 on: December 07, 2012, 10:23:11 am »
Don't bother. Just measure the voltage across R77 for V1 or R78 for V2. Divide that voltage by 3.9 to get the cathode current. Close enough.
But if you must use a 1Ω resistor, put it between the tube cathode and the transistor's collector. Measure voltage across the resistor, not from cathode to ground.
Yes, that's a fairly common failure when using 470Ω/1W resistors on a 6L6. Some people like to replace those with 1K/5W resistors.
« Last Edit: December 07, 2012, 10:26:40 am by sluckey »
« Reply #3 on: December 07, 2012, 11:16:00 am »
Be careful in there Alvin. That amp has around 700vdc on the output tubes plates with enough current to fry a large horse.     :w2:
I had an RD50 years ago, not a bad sounding amp. It was the only amp I could actualy use the bridge PUP on by itself. Never heard the RP-100. Let us know how it sounds when you get her fixed.
             Brad      :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #4 on: December 07, 2012, 02:54:53 pm »
Yeah, I have noticed. with the standby switch on the Hi side.  ouch !
I should have thought of that, I had ''ground'' in my head and couldn't figure it out, in fact, the 1 OHM right between the cathode and whatever comes after :think1:
That's what  I did right away, every amp that comes in here deserves that small operation, costless, almost.
Thanks guys!
Colas
