September 19, 2026, 07:13:04 pm
Hoffman Amps Forum image Author Topic: ADDING A GAIN STAGE  (Read 6816 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
ADDING A GAIN STAGE
« on: January 15, 2013, 05:14:47 pm »
Hi everybody !
I would like to add a gain stage to a Champ 5E1. In fact, I did it, but it doesn't work very well. I have reduced the signal by 2 with 2 X 470k, one to gnd and the connection between the 2 to new grid,  added a B+ cap to feed the new 12AX7's plate, put a 10K from new cathode to gnd, and sent the plate signal to the power tube.
I do not want to use an additionnal 1 meg pot, I want to keep it simple.
Thanx
Colas
P.S.: call me Alvin.
Re: ADDING A GAIN STAGE
« Reply #1 on: January 15, 2013, 07:07:41 pm »
Alvin try a 12AT7 or 12AY7 or 5751 or 12AU7. That will lower your gain.
Tubenet, Geezer, Dummy Load (Pete) and others do this all the time.
If you have 4 gain stages before the power tube you may need attenuation in between 2 or 3 of the gain stages. Try adding larger value grid stop R's and or smaller grid return R's.
                  Brad      :icon_biggrin:
« Last Edit: January 15, 2013, 07:16:34 pm by Willabe »
  • MAKE LOVE NOT WAR
« Reply #2 on: January 15, 2013, 07:34:15 pm »
grid return = grid leak ??????????
« Reply #3 on: January 15, 2013, 07:40:01 pm »
Yes.
     Brad     :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #4 on: January 15, 2013, 07:57:41 pm »
thanxxxxx
Alvin try a 12AT7
love that  hey hey !
Offline jerrydyer
  • Make it one of a kind
« Reply #5 on: January 16, 2013, 04:25:28 pm »
bleed more to ground like 100k to ground, 220k 220 pf in series right before it, 33 k grid res.
  • MAKE LOVE NOT WAR
« Reply #6 on: January 16, 2013, 04:43:31 pm »
thanx buddy
Offline jerrydyer
« Reply #7 on: January 17, 2013, 11:10:17 am »
i actually meant piggy backed or paralel on the 220k 220pf thing but you get the idea. try the standard 470k470pf then 470k to ground but in your case just lowering the value of that one to ground.
you going to try the cerem mod?
  • MAKE LOVE NOT WAR
« Reply #8 on: January 17, 2013, 01:50:45 pm »
to avoid electrons build up on the + side
that's for sure ! But not on my super reverb though......
« Reply #9 on: January 17, 2013, 02:55:50 pm »
To bleed off/throw away signal to ground so you don't slam the next gain stages grid with too much signal.
             Brad      :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #10 on: January 17, 2013, 03:26:57 pm »
common voltage divider
« Reply #11 on: January 17, 2013, 04:11:19 pm »
Yes.
            Brad     :icon_biggrin:
