August 29, 2026, 12:17:50 pm
Hoffman Amps Forum image Author Topic: 1973 Princeton Reverb question  (Read 9703 times)
Offline Michael1
« on: January 22, 2013, 03:30:47 pm »
Hi everybody-i have a 1973 Princeton Reverb im working on for a friend (recapping etc.) Im not sure what circuit this is as it is not written on the tube chart. It seems to be missing a couple of 25/25 cathode bypass caps-it has 4 total. All the schematics ive seen have 6. The ones missing are pin 8 V2 and pin 3 V4. Is this normal for this amp (solder joints look original). Should i add them? Thanx in advance for you help!
        Michael
Offline smackoj
Re: 1973 Princeton Reverb question
« Reply #1 on: January 22, 2013, 05:56:57 pm »
hi; how did you date the amp?  did the owner say whether adding stuff to the circuit is ok?  might want to hold off until you are sure you have the right scheme for the amplifier.
 :icon_biggrin:
stratele52
  • Guest
« Reply #2 on: January 22, 2013, 06:04:45 pm »
Yes you need these cap if you want original. Can work well without , another tone
Schematic is there;
ampwares.com/schematics/princeton_reverb_aa1164.pdf
More infos
ampwares.com/amplifiers/fender-silverface-princeton-reverb/
« Reply #3 on: January 22, 2013, 06:25:24 pm »
Is it possible that two of the caps are actually double caps in one case (similar to the attached pic)? That would make for a total of 6 caps.
EDIT... added another pic. BTW, I just saw a couple SFPRs with only 4 cathode bypass caps. Don't know which circuit though.
« Last Edit: January 22, 2013, 07:14:30 pm by sluckey »
« Reply #4 on: January 22, 2013, 08:07:19 pm »
Yeah, if you have any "3-legged critters" in the preamp, they are dual 25uF caps with a common negative lead.
Offline Michael1
« Reply #5 on: January 22, 2013, 08:48:28 pm »
Thank you all for the reply's! I dated it by the numbers on the trannys-output reads 606-3-29. Power reads 606-3-45. There were no double 25/25 caps-all were singles. It has the 5u4 rectifier tube (also says 5u4 on the tube chart). I was surprised to see 2 less 25/25 caps in there-i havent been inside a princeton before-quite a few other fenders though. I thought that maybe someone removed them for some reason-the solder joints look factory.  I have replaced the capcan-bias cap-and the 4 25/25s. The amp is quiet-reverb and trem work-it sounds just ok-it has a 12" fender utah speaker in it(I would change that). Ill put them in and see how it sounds. Thanx a million everybody for the help! Any advice from you guys is much appreciated!
        Michael
« Reply #6 on: January 22, 2013, 11:00:50 pm »
The era your Princeton was made probably precludes the brown-wrapped Mallory caps Sluckey pictured, and likely the black dual-25uF's too.
Are yours the white Mallory 25uF caps? If so, there were probably others in there before that maybe someone took out. The PRinceton is one of the amps Fender never really changed during the transition form blackface to silverface.
stratele52
  • Guest
« Reply #7 on: January 23, 2013, 03:52:58 am »
I see an 1 watt BURN looking  resistor close to the quad filter cap can.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #8 on: January 23, 2013, 04:50:46 am »
Probably removed because someone thought it broke up too easily.
Call me Dan
www.fydamps.com
Offline phsyconoodler
« Reply #9 on: January 23, 2013, 10:43:06 am »
Why? Utah speakers seem to get a bad rep for some unknown reason.I have them in two amps and have used them in many others and they are great.
 My two amps,a 68 Pro Reverb and 77 Vibrolux are both the best sounding amps I've heard lately.
Both have the original Utah speakers.
In your case I would look at an AA1164 Princeton Reverb circuit and add the bypass caps where they are missing.I bet it will perk it up quite a bit.
That's Sluckeys picture,not the OP's.
« Last Edit: January 23, 2013, 10:46:34 am by phsyconoodler »
« Reply #10 on: January 23, 2013, 03:42:43 pm »
Me, I would date that am to 1968 judging by the chassis ink-stamp.
stratele52
  • Guest
« Reply #11 on: January 23, 2013, 03:56:39 pm »
Dating the pots will say too.
IMO  Power Transformer is not the originald
Offline daven
« Reply #12 on: January 23, 2013, 04:25:12 pm »
yours might not be a later pull-boost model, but it might already reflect some of the changes that occurred with it, notably the reverb drive circuit.  fender changed the common cathode resistor on V2 to 680 ohms, and dropped the cap.  that circuit only has five 25uF caps, and the fifth one was moved to the back of the chassis.  I've included pictures of my '78 SFPR, and you can see the fifth one attached to V4.
« Reply #13 on: January 23, 2013, 07:04:56 pm »
also, in the 70's fender started using the 5U4GB in the PR and upped the PT sec. from 325V to 340V to compensate.
--DL
« Reply #14 on: January 23, 2013, 09:07:12 pm »
My '67 Princeton Reverb used a 5U4GB, and had that indicated on the tube chart.
Offline Michael1
« Reply #15 on: January 24, 2013, 12:27:48 pm »
Thanx again guys for the replys! I forgot about the 25/25 on the back of the amp-that makes 5. The 25/25's were the white ones. And also-no push pull. It had a 1k 1 watt resister fried pretty bad-close to the cap can. I put in a 3 watt there-also put in 3 watt 18k's. I dont know about the Utah speaker-ive never owned one-just was reading some things about them not being the best lol. I'll let the owner decide on that-he might like it. Thanx again everybody!
« Reply #16 on: January 24, 2013, 05:13:28 pm »
Is the cap can good? Has the PS cap can been changed since? I actually have a princeton reverb cap can from 1977 that is still good and quiet. It's on the shelf. It might come in handy one of these days
« Reply #17 on: January 24, 2013, 07:58:13 pm »
That was just a picture Sluckey posted to show examples of dual cathode bypass caps. NOT the amp Michael is working on.
« Reply #18 on: January 26, 2013, 06:55:32 am »
Whoops!
