August 29, 2026, 12:17:51 pm
Hoffman Amps Forum image Author Topic: PUSH-PULL, no cathode follower ?  (Read 4688 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: January 24, 2013, 01:33:41 pm »
I am modifying a  50 w amplifier with no tone stack. I was wandering if I could skip the cathode follower and send the signal straight to the PI, from the preamp tube. Would that be a heavy load on the preamp tube ( s ) ?  I couldn't find no schem of PP amp with no CF.
Thanx
Colas
P.S.: call me Alvin.
Re: PUSH-PULL, no cathode follower ?
« Reply #1 on: January 24, 2013, 01:49:01 pm »
Fender BF AB763 (and silver face models) TS has no CF. It's plate driven.
You can feed the PI with a coupling cap from the plate of the preamp tube, but it might not have enough drive signal. I think you need at least 2 triode gain stages.
             Brad     :think1:
« Last Edit: January 24, 2013, 01:51:26 pm by Willabe »
Offline archaos
« Reply #2 on: January 24, 2013, 02:03:03 pm »
Check the AC30 normal channel schematic (no tone stack) & you're done... :icon_biggrin:
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
  • MAKE LOVE NOT WAR
« Reply #3 on: January 24, 2013, 02:27:58 pm »
PP amps require more signal voltage than a SE ( like the Fender Champ ? )
« Reply #4 on: January 24, 2013, 02:30:43 pm »
yes, you can. will you have enough drive swing? that's another question and requires schematic with telemetry to answer with reasonable accuracy.
--DL
