September 17, 2026, 05:50:28 am
Hoffman Amps Forum image Author Topic: What solder do you use for amp work  (Read 9105 times)
Offline kwm488
« on: February 05, 2013, 12:37:48 pm »
Hi
i have question. Do better solder for the amp will sound better ? I find out msolder for guitar wiring is worse than kester 44.
So i hope to know what solder you use for amp work?
Re: What solder do you use for amp work
« Reply #1 on: February 05, 2013, 12:39:57 pm »
alphacore 60/40 or kester 44
Offline kwm488
« Reply #2 on: February 05, 2013, 12:51:02 pm »
I used expensive solder all the way before. Because i think more money more better.
But i mod one distortion pedal. And i restore everything original. But i use furutech solder. Sound being not sharp. And too fat.
Now , i believe guitar should use no silver solder
« Reply #3 on: February 05, 2013, 04:45:36 pm »
I'll sell you the most expensive solder you've ever seen...
Offline alerich
  • This one goes to 11.
« Reply #4 on: February 05, 2013, 11:32:08 pm »
Kester 44 60/40 .050 diameter.
Offline kwm488
« Reply #5 on: February 05, 2013, 11:35:03 pm »
I just remove my guitar msolder and use kester 44. Sound a lot of different. Msolder sound very smooth , but not like guitar sound. Kester sound very rough , like a man. But sound correct for guitar.
Btw. Will vintage made in usa kester solder sound more better
« Reply #6 on: February 06, 2013, 12:28:34 am »
I can get you even more expensive solder (NOS export grade vintage solder with original rosin core). 60:40 (or thereabouts) leaded works fine.
« Reply #7 on: February 06, 2013, 12:37:35 am »
you'll need an 80W NOS weller soldering iron with a chisel-tip to go with that. just won't sound right without it. that's real mojo right there...
Offline kwm488
« Reply #8 on: February 06, 2013, 01:29:55 am »
Thank you everyone to reply me. Maybe you think solder is not affect the sound too much. But i test with with other 5 people. All prove it
btw , i am using weller ws81 80w solder iron. This iron really make my cable sound better. Because it provide enough heat
