September 16, 2026, 11:34:28 am
Hoffman Amps Forum image Author Topic: DUAL SE amp...  (Read 8954 times)
DUAL SE amp...
« on: February 06, 2013, 01:39:45 am »
as a side project i've been thinking about constructing a 2ch SE amp. recently, i acquired some schumacher wound one-electron UBT-2 iron for a price i couldn't pass up. anyway, was thinking about switching to strap mono & split for stereo - leaning towards the 6L6GC and 6550 output tube types, or even 2x paralleled 6V6GTA/ch. any thoughts/suggestions about which/what pre-amp(s)?
Online kagliostro
Re: DUAL SE amp...
« Reply #1 on: February 06, 2013, 06:46:01 am »
Hi DummyLoad
Nice idea, I would use two different preamps and may be also two different PA output tubes
may be also one PSE and the other simple Se
as to use it in parallel or with a "balance" as to chose the % of the signal from each one
Which preamps ? ........ At your taste
it will be an head with a separated speaker cabinet composed by two joined separated units, as to have it in use joined, when used paralleled or separated as to increase the stereo effect
« Last Edit: February 06, 2013, 06:52:53 am by kagliostro »
Offline rzenc
  • TUBES RULE
Re: DUAL SE amp...
« Reply #2 on: February 06, 2013, 11:13:04 am »
6550 output tube
Sounds interesting! How much voltage will you use on plates/G2?
How about a revibe front end coupled to 6550 power?
Hope this helps!
Best Regards
R.
Re: DUAL SE amp...
« Reply #3 on: February 06, 2013, 11:20:27 am »
6550 output tube
Hope this helps!
Best Regards
R.
around 400-450V and around 380V for G2
revibe idea is cool and a candidate. perhaps a triode > TS > pentode > CF for the 2nd ch...
Online kagliostro
Re: DUAL SE amp...
« Reply #4 on: February 06, 2013, 12:49:37 pm »
Something like one of this ?
Offline rzenc
  • TUBES RULE
Re: DUAL SE amp...
« Reply #5 on: February 06, 2013, 03:52:57 pm »
Nice!! How much power do you spect from such monster?
Another possibility for 2nd channel:
Triode - gain control - triode - pentode - triode - cf - tonestack
Makes up for riotstarters
Best Regards
R.
Re: DUAL SE amp...
« Reply #6 on: February 06, 2013, 05:38:06 pm »
35-40W total.
too much gain perhaps???
respectfully,
Offline rzenc
  • TUBES RULE
Re: DUAL SE amp...
« Reply #7 on: February 07, 2013, 06:25:50 am »
Is it?  :l2:
So...how about changing positions?
triode - gain control - triode dc coupled to pentode - triode - cf - tonestack?
I don't know if you are into high gain. I built a preamp using similar topology:
triode - gain - triode - triode dc coupled to triode - drive control - triode - dc cf - tonestack.... I think I found my way to high gain territory...
It might sound bizarre but connected to a ss poweramp (I wanted to know how much disto preamp was generating) it sounds massive. When connected to Marshall 9200 pumping 4x12" (friend set :headbang:) sounds incredible....Fits perfectly for highspeed riffs and  brutal soloing..
If you get interested in such stuff, pm me and I will send you schema...
Best Regards Pete!!!!
R.
Re: DUAL SE amp...
« Reply #8 on: February 07, 2013, 10:20:24 am »
thanks K! interesting layout - more to the point, interesting to see someone actually used that octal pentode in a production amp.
yes, similar layout, but without the LTPI and add a CF.
thanks for sharing.  :icon_biggrin:
Online kagliostro
Re: DUAL SE amp...
« Reply #9 on: February 07, 2013, 12:24:35 pm »
Hi Pete
If you want to see the complete circuit of the Selmer Zodiac twin 30 (a very unusual amp on the channel 2 Tone Control) I've sent it to Doug and now it is on the library of schematics
http://www.el34world.com/charts/Schematics/files/selmer/selmer_zodiac_twin30_.pdf
Re: DUAL SE amp...
« Reply #10 on: February 07, 2013, 01:10:20 pm »
that schematic was drawn by one of our forum members.
 :icon_biggrin:
Offline echuta13
  • Elder God
Re: DUAL SE amp...
« Reply #11 on: February 07, 2013, 02:01:53 pm »
That is such a great asset for the schematic library!     :worthy1:
Back on topic...  Looks like Swart is releasing a stereo SE amp: http://swartamps.com/swart_st-stereo.htm
"When choosing between two evils I always like to try the one I've never tried before."
Re: DUAL SE amp...
« Reply #12 on: February 07, 2013, 07:38:18 pm »
Matchless didn't use the 6SH7 long. I think there were claims about availability or microphonics, but 6SH7's are generally pretty cheap from places that stock radio stuff (I have some signal generators that use that tube).
The Clubman 35 switched to use an EF86 in that position fairly early on. I used to have an EF86-equipped Clubman 35.
Re: DUAL SE amp...
« Reply #13 on: February 07, 2013, 08:50:14 pm »
good to know. it seems that most octal tubes are prone to being microphonic - my opinion based on my limited experience working with them anyway. how did you like the clubman? decent? would you own another? i built a matchless DC30 clone - the EF86 channel for a friend, as i recall, it was a decent sounding amp. we used salvaged baldwin organ iron.
PS: standel coming along... :-) mechanical drawings coming together and the second breadboard is almost done. i'm leaning towards a head rather than a combo for greater flexibility of speaker options.
Online kagliostro
Re: DUAL SE amp...
« Reply #14 on: February 08, 2013, 01:53:31 am »
Here is an old Marconi Equivalent Tube Manual
http://www.introni.it/pdf/Marconi_tavole_sostituzione.pdf
at page # 16 you can see that 6SH7 8 pin tube can be replaced with a 6AU6 7 pin tube (who gives more gain)
Online kagliostro
Re: DUAL SE amp...
« Reply #15 on: February 09, 2013, 06:06:46 pm »
I've just recognized that also the Gibson Ga-46 uses a pentode in V2 position (labeled as V3 & V4 on the schematic)
http://www.el34world.com/charts/Schematics/files/gibson/GA-46.pdf
as pot with intake for the tone control a rotary switch with in series resistors must be used because as we know no pot with intakes are available nowaday
« Last Edit: February 09, 2013, 06:10:36 pm by kagliostro »
Re: DUAL SE amp...
« Reply #16 on: February 09, 2013, 09:21:11 pm »
Yeah, it was a Marshally-enough sounding amp. At the time I think I was most excited by the build style of the electronics.
I'd probably make something like it again, but being that I don't gig I just don't need anything in the 30w+ range unless I want absolute clean.
I guess that means I really didn't need the Standel, but I just wanted to build it, so here it is...
