September 16, 2026, 03:00:16 pm
Hoffman Amps Forum image Author Topic: Fusing for 2 PTs in 1 build?  (Read 4321 times)
« on: February 07, 2013, 09:09:40 pm »
I'm wondering about what is the best way to fuse 2 PTs on 1 build?
I want to use 2 Hammond 229 series simi-torides for Sluckeys Warbler. 1 for the HT B+ and the other for the heaters at 12acv since it's all 12 - - 7's.
I want to fuse both the primaries and secondaries on both PT's. I'm going to buy some PCB fuse holders, 5mm x 20 mm for the secondaries which will be inside the chassis.
But for the 2 primaries I'm thinking you have to use a fuse for each, because their separate?
If not I have a few IEC pannel sockets I bought from Doug's store that have a 5mm x 20mm fuse holder built in that I could use.
Here's the link for the Warbler build with the schemos;
http://www.el34world.com/Forum/index.php?topic=10681.msg145523#msg145523
                Brad       :think1:
« Last Edit: February 07, 2013, 09:26:26 pm by Willabe »
Re: Fusing for 2 PTs in 1 build?
« Reply #1 on: February 07, 2013, 09:33:08 pm »
I would keep it simple on this project.... One fuse.
« Reply #2 on: February 08, 2013, 12:30:21 am »
Why? Are you dropping pennies through the slots?
One fuse. 0.5A if it holds, else 1A.
« Reply #3 on: February 09, 2013, 12:04:29 am »
Ok, thanks guys.
             Brad     :icon_biggrin:
