September 16, 2026, 04:23:08 pm
Hoffman Amps Forum image Author Topic: Cathodyne follower tone stack?  (Read 4935 times)
Offline skeezbo
« on: February 17, 2013, 09:17:14 pm »
Daydreaming about amp design... Would it make any difference to a Marshall style cathode follower tone stack if the triode had a plate resistor of equal value to the cathode resistor? I would like to be able to take an inverted signal off the plate of the trode currently set up to drive the tone stack for a KOC inspired side chain loop. This would essentially turn the cathode follower triode into a split load inverter. Would taking a signal off the plate cathodyne style affect the original signal on the cathode follower tone stack? Would I need to add a coupling cap before the split load?
Skeez
Re: Cathodyne follower tone stack?
« Reply #1 on: February 18, 2013, 05:16:02 am »
no
no
What do you mean? The only cap you will need to add is a coupling cap from the plate of the tube. If your plate resistor is the same size as your cathode resistor the plate signal will have no gain. If you need a little gain you can use a larger plate resistor.
Offline skeezbo
« Reply #2 on: February 18, 2013, 08:36:54 am »
Steve
Thanks so much for the quick response. I thought it would work, but needed some expert advice. My question about the coupling cap was based on the fact that the cathodyne inverter schematic I was looking at had one between the two stages, but the cathode follower looked to be direct coupled.
I know it won't have gain, but it may seem to have more gain compared to the cathode follower side with the tone stack loss. I am thinking of a two stage reverb loop with tone and dwell that will get re-inverted when it re-enters Matchless Chieftain style at the long tail pair phase inverter.
Thanks again,
Skeezbop
« Reply #3 on: February 18, 2013, 08:46:52 pm »
Think of the typical 12AX7 plate load, 100k.
In a cathode follower, that same load is slid through the tube to the cathode side, 100k load. But this causes degeneration, 100% feedback and gain less than 1. Load line is still the same, but you have to do extra thinking to see what the gridlines really represent.
In a split load, the 100k load didn't slide all the way to the bottom of the cathode; half below, half up top. That should be a 50k resistor on either side, but 56k is a good compromise in a standard part value.
So 100k on top and bottom would be the loadline for a 200k plate load. Consider this, and whether it will impact your situation (it may not).
Offline skeezbo
« Reply #4 on: February 19, 2013, 01:23:37 pm »
Matching 56k plate and cathode resistors in a split load will create a similar load line for the cathode signal when compared to a 100k cathode resistor in a cathode follower setup.
Got it, thanks again!
Skeez
