August 29, 2026, 01:14:51 pm
Hoffman Amps Forum image Author Topic: Is a typo or this LTPI using 1/2 6aq8 + 1/2 12ax7 in an ELK amp is correct ???  (Read 12656 times)
What do you think ?
is a typo or really the ELK ES-30 Japan guitar amp uses such mixed architecture for his LTPI  :w2:
Yes, is commonly published, but the send of the reverb is an ecc85 and the return is labeled 12ax7
the LTPI has 1/2 ecc85 and 1/2 12ax7  that is very odd
the same ELK brand but model Twin 50 has the same odd architecture
http://www.drtube.com/schematics/elk/twinamp50.gif
I can understand that may be there is a necessity to have the 12ax7 tube in the recovery of the reverb
but don't you think that an LTPI using different triods is really odd ??
It's probably an error, as the ECC85 has half the mu of the 12AX7 so the inverter is less likely to be balanced.
Then again, the tail resistor may force balance close-enough.
Hi HotBluePlates
I've seen only this two schematics and both has the same odd architecture
looking to the first I was thinking that it was a typo, but when I've seen the second schematic a doubt come to me
may be they do this thing (using the tailor resistor as to balance the signal) for "special effect" in the sound ?
sometimes I've read about people using resistors or also trimmer to balance near perfectly the PI (I think guitar guy borrowed this from HiFi guy) but there was people that say that they prefers a non perfectly balanced PI who gives a "pleasant tone" to the amp
Which is your personal opinion about ?
I don't know. I've never seen an Elk amp in person, much less inspected the actual amp or played through one. So I really couldn't say...
I haven't put my question in a clearly way
I mean, which is your opinion mixing different triodes in an LTPI and balancing the signal with resistors
do you think that a sort of mojo sound may come out doing that ?
If my memory and tube charts serve me correctly isn't there  a 12__7 with mixed triodes that would someone to test mixed mu tubes in a LTPI circuit, without having to have two heaters.
Agreed; I think this would be the best way to find out.
The 12DW7/7247 is the American part number for 1/2-12AX7, 1/2-12AU7. The European part number is ECC832.
12DW7 is claimed to be a good tube for reverb circuits and for FXLoop too, I think
to try it in a LTPI is a good idea  :thumbsup:
within 15 days here there is an electronics fair, I'll look for a pair of those tubes  :smiley:
JJ makes them in 2 pin configurations:
the ECC832 with the 12AU7 triode on pins 1, 2 and 3 and the 12AX7 triode on pins 6, 7 and 8
and the ECC823 with the triodes on the opposite sets of pins
I've find this odd PI that uses a Pentode and a Triode one for each branch
New Phase Splitter
A R Bailey MSc(Eng) AMIEE, Bradford Institute of Technology. Wireless World, September, 1962.
Improved high-frequency response.
Circuit of complete EF86 pentode amplifier and ECF82 phase-splitter for use in a high-fidelity amplifier with a large amount of negative feedback.
http://www.amplimos.it/phase%20splitter.htm
May be this give more sense to an "apparently" unbalanced PI like the 1/2 ecc85 + 1/2 12ax7 ?
Online sluckey
You've been finding a lot of oddball circuits lately. Maybe you need to update your search engine.  :wink:
YES ! :l2: :laugh: :laugh: :l2:
I was looking about documentation for the paraphase PI
in reference to this tread and PRR post
http://www.el34world.com/Forum/index.php?topic=15485.0
and I've find this strange thing
Ciao Steve
he does come up with the weirdest stuff...   :icon_biggrin:
attached is how i think elk ES-30 is built.
« Last Edit: April 24, 2013, 12:34:15 am by DummyLoad »
italian search engine... like italian cars & motorcycles... they have a mind of their own...  :wink:
ps. i can confirm this; i own a guzzi le-mans.  :icon_biggrin:
Nice Toy Pete
Some year ago there was an article on MotoTecnica of a modded Le Mans with a volumetric compressor from a Lancia HPE Volumex car
unfortunately (for you) I do not have anymore the magazine with the construction plans  :icon_biggrin:
« Last Edit: April 24, 2013, 01:34:40 am by kagliostro »
nice scooter k, but not the 850, the V11 tenni
this one:
Oh, yours is a newer model
NICE  :thumbsup:
« Last Edit: April 24, 2013, 07:29:20 am by kagliostro »
Offline Custom_Amp_30
What do you think ?
Its not a typo, I can assure you. half of the 6AQ8 is used in the reverb circuit while the other is used in the in the PI shared with half a section of a 12AX7. It works out.
« Last Edit: July 10, 2013, 01:04:29 am by Custom_Amp_30 »
I think it would work the same with a twin-triode.
You guys with your supercharged scooters! Do they mow the lawn as well as a 1972 Craftsman GT-18? (OK, today my GT wanted to leak fuel, so I turned to my newest motor: a 2.3HP $119 WalMart push-mower.)
PRR if you like the Craftsman
give a look to what is building a friend of an italian forum (he is a carpenter)  :icon_biggrin:
starting from this
at the begin of the job
this is the result (still not ultimated)
