August 02, 2026, 01:54:48 pm
Hoffman Amps Forum image Author Topic: choosing a thermistor ?  (Read 8106 times)
Offline floyd
« on: May 18, 2013, 09:20:43 am »
How do I decide what value , etc. when choosing a thermistor , ( inrush current limiter ) to simulate the slow warm-up of a GZ34 for instance ? ... Weber uses these in their Copper Caps.
Re: choosing a thermistor ?
« Reply #1 on: May 18, 2013, 09:29:34 am »
Are you sure Weber uses thermistors ?
I see nothing or resistors, not thermistors
Other thing will be to find a substitute for the old Brimistor (like the CZ4 used in the Vox AC50)
http://www.el34world.com/charts/Schematics/files/Vox/ac50_1.pdf
« Last Edit: May 18, 2013, 09:38:18 am by kagliostro »
Offline floyd
« Reply #2 on: May 18, 2013, 09:32:17 am »
I'm looking at the guts right now.... diodes, followed by thermistor, followed by dropping resistors. But , of course , the thermistor value is obscured .
« Last Edit: May 18, 2013, 09:34:49 am by floyd »
« Reply #3 on: May 18, 2013, 09:35:10 am »
Which guts ?
Offline floyd
« Reply #4 on: May 18, 2013, 09:36:31 am »
Which guts ?
A weber GZ34 Copper cap module.
« Reply #5 on: May 18, 2013, 09:56:58 am »
So you are saying that they sell something that is different from what they show in their's Kit reference pages ?
If you see the thermistor, can't you detect the model of the same by the label on the component ?
EDIT: May be you can find something of your interest here
http://www.ge-mcs.com/en/temperature/inrush-current-limiting/inrush-current-limiter.html
http://www.ge-mcs.com/download/temperature/920-325D-LR.pdf
http://www.ge-mcs.com/download/temperature/GE-THM_Curves.pdf
« Last Edit: May 18, 2013, 10:06:14 am by kagliostro »
Offline floyd
« Reply #6 on: May 18, 2013, 10:56:13 am »
copper cap
« Reply #7 on: May 18, 2013, 11:08:02 am »
I see, deleted label on the component
and more, that didn't seems the substitute for the GZ34 tube I was thinking
May be that is a substitute for the CZ4 Brimistor ??
I see only 3 diodes, can  you draw a (pencil) schematic ?
« Last Edit: May 18, 2013, 11:10:23 am by kagliostro »
Offline floyd
« Reply #8 on: May 18, 2013, 11:18:12 am »
There are 4 diodes... one is hidden behind the thermistor. Weber makes , or made two Copper cap types... one is a plug in, and one is hard wired, like mine.
« Reply #9 on: May 18, 2013, 11:35:56 am »
OK, sorry, I didn't know the existance of that version of the component
if the value is obscured using some kind of paint you can try to remove using solvent
if the label is abraded you can measure the resistance at cold and when warm
than you must read the explanation on the GE pdf I posted and try to recognize which
can be the right component to be used, you have the great luck that you can measure
the component
if you post here the cold and warm resistance values, may be some more experienced (than I'm)
member of the forum can give you a specific indication about what to use
Offline floyd
« Reply #10 on: May 18, 2013, 11:55:21 am »
another pic
« Reply #11 on: May 18, 2013, 07:13:52 pm »
Can you take a picture of the other side of the board?
The position of the component almost implies a varistor instead of a thermistor.
Offline floyd
« Reply #12 on: May 18, 2013, 11:38:26 pm »
The components are in this order... from AC- rectifier diodes , then thermistor, then dropping/sag resistors.
« Last Edit: May 18, 2013, 11:46:53 pm by floyd »
