August 29, 2026, 01:59:28 pm
Hoffman Amps Forum image Author Topic: Post phase inverter master volume  (Read 11432 times)
Offline dude
« on: May 23, 2013, 05:48:25 pm »
Can I use this master volume on this Ampeg schematic?
Re: Post phase inverter master volume
« Reply #1 on: May 23, 2013, 06:02:44 pm »
yes
stratele52
  • Guest
« Reply #2 on: May 23, 2013, 06:03:16 pm »
This won't shut amp volume . A volume / master vol need one side of the pot connected to ground.
« Reply #3 on: May 23, 2013, 06:12:52 pm »
It certainly will. Been done many times. The pot is connected to the bias voltage supply which is at AC ground due to the filter caps.
stratele52
  • Guest
« Reply #4 on: May 23, 2013, 06:16:45 pm »
Sluckey , very strange circuit , I learn someting if you say it work.
But IMO there are better master volume circuit
« Reply #5 on: May 23, 2013, 06:24:10 pm »
It's as good as it gets. Been around a long time. Read this...
http://metroamp.com/wiki/index.php/Lar/Mar_PPI-MV
Offline dude
« Reply #6 on: May 23, 2013, 06:40:58 pm »
Can I use a 1 meg A ganged pot? No 500KA on hand
al
« Reply #7 on: May 23, 2013, 07:59:43 pm »
Yes, that should still work fine.
« Reply #8 on: May 23, 2013, 08:21:46 pm »
8uFd in bias supply is audio-ground enough.
Ground is not essential to killing a balanced amplifier. Strapping the two sides together will do it. Usually with side effects we don't like, but it works.
« Reply #9 on: May 23, 2013, 08:56:31 pm »
Think of it as a Vox cross line tone cut, but with out the tone cut cap so full frequency and a dual pot instead of a single pot. Feeding signal from both sides of the PP lines to each other kills the opposing signal.
              Brad     :icon_biggrin:
« Reply #10 on: May 23, 2013, 09:37:10 pm »
No, don't think that because it's still a voltage divider like every other volume control.
It's just that the ground end of the pots are not connected to d.c. ground but to a cap which is itself connected to ground. For a.c., that's the same thing as if the pots had a connection to the chassis.
« Reply #11 on: May 23, 2013, 10:17:56 pm »
Maybe I'm not seeing this right, but I was not talking about any signal going to ground whether it's ac or dc. The Vox cross line tone cut has no direct path to ground.
I was talking about out of phase cancellation of the ac signal caused by mixing the 2 opposing PP signals together. Just like the Vox cross line tone cut except no cap to limit the bottom end of the cut across the 2 signal lines. So full frequency cut = MV.
Even if you cut the connection from the 3 terminal (x end of the pots) to the junction of the -bias/220k grid leaks it would still phase cancel the signal to the output tubes.
                  Brad     :think1:
« Last Edit: May 23, 2013, 10:58:59 pm by Willabe »
« Reply #12 on: May 23, 2013, 10:28:16 pm »
Watch out for that link....my Vipre active protection picked it up as a known bad exploit
« Reply #13 on: May 23, 2013, 10:57:19 pm »
I was talking about out of phase cancellation of the ac signal caused by mixing the 2 opposing PP signals together. Just like the Vox cross line tone cut ...
Redraw the entire circuit. Notice that at the minimum-volume setting, there exists the same resistance between the two drive signals as at the maximum volume setting (more really because the 220k resistors aren't shunting the pots).
In fact, redraw just one side of the push-pull circuit. Then I think you'll see how this is like any other volume control, except there are 2 of them and it's connected to the bias circuit. So it is not functionally like the Vox Cut control or Matchless master volume.
Offline darryl
    • ValveTone Amplification
« Reply #14 on: May 23, 2013, 10:58:25 pm »
Even if you cut the connection from the 3 terminal (x end of the pots) to the junction of the -bias/220k grid leaks it would still phase cancel the signal to the out put tubes.
If you do cut the connection from the pot terminals labeled "3" to the bias circuit, then the pots will act as a cross-line master volume.
If you leave the connection in place, then AC signals at the "3" terminals are effectively connected to ground via an 8mfd electrolytic capacitor. There is no cross line phase cancellation, because the out-of-phase signals are isolated from each other by the shorting effect of the 8mfd cap.
« Reply #15 on: May 23, 2013, 11:03:26 pm »
Ahhh... Thanks Darryl, now I see it. I missed that.
                Brad     :icon_biggrin:
« Last Edit: May 23, 2013, 11:08:18 pm by Willabe »
« Reply #16 on: May 24, 2013, 02:00:23 am »
Is that architecture and cap the reason for which isn't necessary a second couple of capacitors between the 220k resistors and the MV pots as to avoid scratch due to DC, correct ?
« Reply #17 on: May 27, 2013, 11:14:07 am »
No, because the output tube bias voltage is also coming through the master volume pot.
Seems like the existing 220kΩ resistors could be more like 2.2MΩ, as they're just there in case the wiper lifts from the resistive track in the pot.
Now I would normally wire up a master volume like what you showed... but then again I don't use master volumes much and don't know which is "best sounding" or not...
