August 29, 2026, 01:59:28 pm
Hoffman Amps Forum image Author Topic: PV Deuce with high plate voltages  (Read 7518 times)
Offline BigE
  • Fender guy...
« on: June 24, 2013, 12:08:39 pm »
On the bench is an old PV Deuce with the solid state rectifier.  The plates are running @ 530v.   What would be the first culprit and/or what could ya do to knock this down.  It's got new 6l6's and has had a cap job.  It's smoking 6l6 tubes, I'm assuming cause of the high plate voltage.
thanks in advance for the ideas/suggestions.
Re: PV Deuce with high plate voltages
« Reply #1 on: June 24, 2013, 10:25:28 pm »
Does it have a schematic?
However 530V *alone* won't kill 6L6GC. What's the current??
Offline BigE
  • Fender guy...
« Reply #2 on: June 25, 2013, 09:54:54 pm »
schematic attached...
6l6's are running @ .045 ma...
the new 6l6's are JJ's.  I've been having a LOT of trouble with new JJ's going bad.  I guess it could be a coincidence that 2 of these new tubes went bad if he got a bad batch.  But the owner says the amp runs REALLY hot temperature wise on-stage.
« Reply #3 on: June 26, 2013, 03:49:40 pm »
I think you meant 45mA? .045A = 45mA and .045mA is 45 thousands of an mA.
And are you saying 45mA for each, single tube or for both added together? If 45mA for a single tube @ 530dcv, that's way too hot.
Brad        :w2:
« Last Edit: June 26, 2013, 04:04:56 pm by Willabe »
Offline mrr3000gt
  • Idiot Savant Engineer
    • Sponsored by Dimarzio Pickups since 2010
« Reply #4 on: July 16, 2013, 07:37:01 pm »
I got a 1979 Peavey Deuce I had to rebuild. I do not recall the voltage near that high, but it is 120 watts and extremely loud (the mace is 6 6l6 tubes and 160 watts!).
The fix I had to do was to rebuild the rather primitive power section - I had to undo 35 years of poor repair jobs and mine still has the original transistors!
This amp is self-boasting (at least mine was) with no provision to 'dial it in'. A check of what the dissipation mine worked at for the tubed I had was around 60% of the 25 watt 6l6 rating. That was good enough for me.
These amps run hot and owners report spectacular deaths of these amps because of the voltage and heat they produce. I can't say I want mine to do that...
Mark of Dire straits used one for a year in the bands history, and these amps nail the Lenyrd Skynyrd sound and tone to the T: right down to the built in phaser effect.
Offline mrr3000gt
« Reply #5 on: July 16, 2013, 07:42:50 pm »
500 volts is the nominal: see if another set of tubes is better liked by the amp.
I have svetlannas in mine, and have a set of chino Rubey tubes that do just fine in this amp.
I'd check the power section: the only pain in the ass with these amps is the solid state preamp. The power supply and power tube section are Neolithic simple.
« Reply #6 on: July 16, 2013, 07:59:16 pm »
Now that's a term I haven't heard before. Is it an electronic term or a musical term? Or just braggin' rights? :wink:
Offline mrr3000gt
« Reply #7 on: July 16, 2013, 08:26:20 pm »
Lol no it's my iPad thinking for me again..I meant self biasing. It's like when my voice software on my smart phone sent "I am playing my eye bananas tonight" when I said "I am playing my Ibanez tonight"....
Gotta love technology...
« Reply #8 on: July 16, 2013, 08:30:55 pm »
Smart phone technology is great. The funny part is I understood what you were saying. Just hat to tease though.  :icon_biggrin:
Offline mrr3000gt
« Reply #9 on: July 16, 2013, 10:26:36 pm »
 :l2:
Offline mrr3000gt
« Reply #10 on: July 17, 2013, 11:12:25 pm »
Played on my deuce tonight! I will be playing guitar on it on a side project for a couple months. Nice change of pace. I used the built in phaser - my favorite phaser tone. More of a phase 45 effect.
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« Reply #11 on: July 18, 2013, 11:18:09 am »
I would have to say your problem is most likely those JJ's , I don't use them unless a customer insisted on them , I recommend Ruby's or if your brave you can try those mesa labeled tubes that are made in China they are made for higher plate voltages , also are measuring the plate voltage with the tube in the socket or out , if it's out that is the unloaded voltage and 540 is nominal.
