September 14, 2026, 04:51:34 am
Hoffman Amps Forum image Author Topic: possibly a standby switch problem  (Read 5883 times)
Offline pbman1953
« on: July 26, 2013, 07:18:19 pm »
The amp is an old Traynor YBA-3A super- sometimes when switching on the amp there isn't any sound. After checking all the connections, which are typically fine, and after re-cylcing the amp the sound comes back.
A tech told that it could be a carbonized stand by. Has anyone faced this?
Re: possibly a standby switch problem
« Reply #1 on: July 26, 2013, 09:38:52 pm »
Check for B+ voltages after the standby switch next time it happens.
No B+ then switch is bad.
                 Brad     :icon_biggrin:
stratele52
  • Guest
« Reply #2 on: July 27, 2013, 04:55:46 am »
                 Brad     :icon_biggrin:
First you must have  B+  BEFORE  the switch
stratele52
  • Guest
« Reply #3 on: July 27, 2013, 05:03:08 am »
Start by Standby switch test .
It could be the fuse and fuse socket too ; Intermittent , but you won't see no heater glow on tubes.
If all tube 's heater glow ;
Checking connections : How you do that ? Just by looking without any skill ?? Old amps could have bad solder in B+ circuit, need to reheat.
Speaker connexion too.
Did you hear a hum at high ( if need) volume  when no sound ?
Offline pbman1953
« Reply #4 on: July 29, 2013, 05:54:17 pm »
Actually my tech he also  mentioned the B+ and is checking the switch too
Thanks to all!!
stratele52
  • Guest
« Reply #5 on: August 02, 2013, 02:00:17 pm »
Stand by's can be on the B+ or they can be placed on the B- (read center tap),  in theory, all your doing is breaking the circuit.
On a Traynor YBA-3A switch is on the B- , center tap of power transformer.
