August 29, 2026, 12:18:12 pm
Hoffman Amps Forum image Author Topic: Homebrew Amp Bias Tap Lacking  (Read 8278 times)
« on: July 28, 2013, 09:24:08 am »
I just retubed an amp this morning.  Guy said his amps have been eating tubes.  Amp is basically a Marshall 50 watter with EL34, but with a fixed bias section like a fender.  Problem, the Bias Tap reads 20 vAc and I cannot get enough negative voltage which is why it is eating tubes.  I have no idea what the PT is, who made it or what it was intended use is.  Plates are seeing 470 vDc.
Anyone ever modified a fender bias with a voltage doubler?  Would it be best to just use an HT tap?  I could just put a half wave rectifier, but wanted to find out if anyone had a design where the doubler was incorporated into the bias supply?
Offline clyde
Re: Homebrew Amp Bias Tap Lacking
« Reply #1 on: July 28, 2013, 09:37:35 am »
Or make a tap from one leg of the PT secondary?
Offline JPK
« Reply #2 on: July 28, 2013, 10:42:23 am »
I recently had this problem on a new build last winter (Marshall Plexi 20 watt). I'm not sure if my bias circuit is identical to yours but all I did was swap out the 33k tail resistor with a 47k. Now I can get the bias current where it should be with a 6V6GT (28ma max if I remember correctly). You can experiment with resistors in series with the present one until it gets to the bias current you need. In general you need to raise the tail resistor to get higher negative voltage, which will allow you to bias colder. I have an adjustable bias on mine. It would bias too hot at its lowest setting until I raised the tail resistor.
« Last Edit: July 28, 2013, 11:01:36 am by JPK »
I love tubes
« Reply #3 on: July 28, 2013, 11:06:20 am »
Yes, that's too low.
That's what I'd do to my amp.
stratele52
  • Guest
« Reply #4 on: July 28, 2013, 03:17:55 pm »
+1
« Reply #5 on: July 28, 2013, 05:05:59 pm »
You could do either the doubler or a HV tap...the doubler requires a few more parts...not a big deal either way. Inevitably you'll have to experiment with your dropping/dividing resistors, but it's going to be much the same process regardless of the circuit choice.
I'm a little confused when you say there is cathode bias (implying no need for a separate tap, backwards diode and simple little filter...like what is lacking on a 5E3 Deluxe) versus "tap". Is it a hybrid where some of the bias is derived from a cathode bias structure and some derived from a rectifier-filter? Such a thing is certainly possible but what, if anything, might be gained over either choice (fixed/cathode or variable) I couldn't say.
stratele52
  • Guest
« Reply #6 on: July 28, 2013, 05:44:02 pm »
Homebrew amp ??? Is this a homemade amps , homemade desing ? No schematic avalaible ?
« Reply #7 on: July 29, 2013, 06:03:07 am »
Fixed is not cathode.  Self bias is.  Fixed adjustable like a Blackface, not self bias cathode like a Valco or 5E3.
« Reply #8 on: July 29, 2013, 06:07:02 am »
You are correct.  No schematic.  Looks like a parts amp.
stratele52
  • Guest
« Reply #9 on: July 29, 2013, 06:52:05 am »
So you may have check everything.....
« Reply #10 on: July 29, 2013, 11:46:59 am »
Problem, the Bias Tap reads 20 vAc and I cannot get enough negative voltage.
Is that reading with the bias tap alone with nothing hooked up to it?
                   Brad      :icon_biggrin:
« Reply #11 on: July 29, 2013, 12:52:52 pm »
                   Brad      :icon_biggrin:
It is.
« Reply #12 on: July 29, 2013, 01:22:25 pm »
What Steve said. Run the bias supply from one side of the HT winding with a voltage divider (decoupled at the knee with something like 10-47uF), like a BF Princeton.
Offline drgonzonm
« Reply #13 on: July 29, 2013, 05:25:06 pm »
look at plexi_superlead_reissue 1987 in this forum's Marshall schematics.  to Provide Bias Tap.
