August 29, 2026, 12:18:28 pm
Hoffman Amps Forum image Author Topic: diode distortion  (Read 6277 times)
Offline phsyconoodler
diode distortion
« on: July 28, 2013, 02:11:07 pm »
Anyone experiment with passive onboard guitar distortion using schottky diodes,or LED's in amps? I did try an LED circuit in a small amp once but didn't like it much.I do want to tro one in my tele though,having heard one that I liked.
Offline Tone Junkie
Re: diode distortion
« Reply #1 on: July 29, 2013, 02:23:34 am »
I have not tried schottky diodes, but I have tried LED,s I didn't like them either.
I have been looking at a bunch of different types of diode clipper circuits. What I have found so far is I like  a saturation switch 2 u5408 diodes in front of the standard Marshall style treble pot ,doesn't add clipping as much as it changes the feel when picking .
Timbo sent me a link to some literature on different styles of Diode clipping if you want me to find it I will.
Bill
« Reply #2 on: July 29, 2013, 04:18:18 am »
Offline Geezer
« Reply #3 on: July 29, 2013, 06:04:23 am »
Like you, I have tried it in both amplifiers and distortion pedals and do not like it.
In fact, I have come to realize that I do not like diode clipping in any form. I dislike the raspy buzzsaw tone they produce.
I've built many OD pedals And always like them better with the diodes removed...... I like them better as a booster just pushing the front of the amp with no clipping added.
I much prefer FET's in overdrive pedals, but that is a different subject.
G
Offline Tone Junkie
« Reply #4 on: July 29, 2013, 06:45:09 pm »
Geezer what would stop us from using FET,s were we now are trying diode,s and which ones do you like.
Thanks Bill
Offline Geezer
« Reply #5 on: July 29, 2013, 07:43:33 pm »
Bill, I think you're talking about wiring an FET AS a diode, such as the Zendrive does(?)
That is just a slightly different tone, but still diode clipping to my ears.
I was referring to running the FET(s) like a triode gain stage in an amp, only in a low voltage pedal.
My favorite so far is the Himmelstrutz Fetto.....here's a link to the schematic >
http://2.bp.blogspot.com/-HDMx7AB7MDs/Txgad6S3yiI/AAAAAAAAAog/fn93dntUIkw/s1600/HimmelstrutzFetto.GIF
It sounds so close to the OD channel(s) on my amps that I can hardly distinguish between them. And when you run the pedal WITH the OD channel, WOW!
It uses 3x 2SK170 FET's
G
« Last Edit: July 29, 2013, 07:48:19 pm by Geezer »
Offline Tone Junkie
« Reply #6 on: July 29, 2013, 08:55:47 pm »
Thanks Geezer I might have to build that.
Bill
« Reply #7 on: July 30, 2013, 10:56:10 pm »
Hmmmm....gotta try out the Himmelstrutz Fetto !!
 Thanks Geezer!
