September 08, 2026, 12:17:46 pm
Hoffman Amps Forum image Author Topic: Hartke HA5000 output module repair  (Read 8696 times)
Offline bobmegantz
« on: August 02, 2013, 06:19:08 pm »
Hi -
There are two pots on the power amp modules. I assume they are meant to be adjusted when the output devices are changed. Does anyone know the procedure?
Tnx
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
Re: Hartke HA5000 output module repair
« Reply #1 on: August 07, 2013, 11:28:36 am »
they are bias adjustment , yes they should be adjusted to the voltage or current that is marked on the schermatic, however if you have tested the amp to full volume and it doesn't distort don't worry about it.
