September 17, 2026, 03:30:34 am
Hoffman Amps Forum image Author Topic: Gibson GA40 LP on bench  (Read 5718 times)
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
« on: August 14, 2013, 08:42:45 am »
Just wondering if the tremolo frequency pot is normal or reversed on these?
I mean, it works in reverse as I rotate it.
IOW dimed the speed is slowest.
Amp is all original, even the tubes.
Did a full cap job, sounds superb and pretty darn loud.
Think I like it better than a 5E3.....and I LOVE 5E3s!
Too bad it is a bear to work on!
The put most of the caps under the board.grrrrr!
Re: Gibson GA40 LP on bench
« Reply #1 on: August 14, 2013, 09:33:52 am »
If you want it to be slowest when rotated max CCW, then move the wire on the outer lug to the other outer lug.
Offline Madison
    • Funky Dolphins
« Reply #2 on: August 14, 2013, 07:12:16 pm »
There are only 2 lugs on that pot.
Tried reversing the wires but , as I suspected, no change.
Thanks.
« Reply #3 on: August 14, 2013, 10:01:46 pm »
What? Since when does a pot, which is a variable resistance, have only 2 lugs?
Can't be.
                Brad      :think1:
« Reply #4 on: August 14, 2013, 10:10:17 pm »
Might have been cut off at the factory..? If so, you'd have to try to solder to the rivet on the little piece of bakelite where the lugs usually come out. Dicey.
« Reply #5 on: August 14, 2013, 10:47:58 pm »
It wants to be a Reverse Audio taper.
A hack is to use a Normal Audio taper, use the other side, let the knob work "backward".
Which way is backward? Look at the volume control on a radio etc. Now find an old-fashioned gas stove. Those knobs turn the other way. It's arbitrary.
Offline Madison
    • Funky Dolphins
« Reply #6 on: August 16, 2013, 08:07:38 am »
Slapped a 3M RA pot in there.
Works good enough to R&R.
Customer was very pleased, so was I.
Nice amp.
« Reply #7 on: September 15, 2013, 11:01:24 pm »
Was your version the one with 2x 5879's & 6V6's? Just a single tone control?
