September 16, 2026, 07:26:05 pm
Hoffman Amps Forum image Author Topic: 6L6 input grid resistor always tied over to pin 6????  (Read 5671 times)
Offline nandrewjackson
« on: August 26, 2013, 09:42:12 pm »
It seems that most layout diagrams show the input grid resistor always jumps over to pin 6 on the 6L6.  Why?  Is it just a layout thing?
Isn't  pin 6  an "empty" pin?
Offline Deric
Re: 6L6 input grid resistor always tied over to pin 6????
« Reply #1 on: August 26, 2013, 10:34:39 pm »
I thinks it's done for 2 reasons....
1 - It's best to have the grid resistor as close to the grid as possible - as in directly on the tube socket pin - and...
2 - Like you said, pin 6 is unused/not connected internally therefor it makes a very convenient and sturdy place to mount the resistor....
May be other reasons too....but that's the way I understand it.
« Reply #2 on: August 26, 2013, 10:40:07 pm »
Most Fender amps mount a 470Ω/1W screen resistor between pins 6 and 4. And the 1.5KΩ grid stopper is mounted between pins 1 and 5.
It's just convenient. Pins 1 and 6 are both available on a glass 6L6 or 6V6 .
« Reply #3 on: August 27, 2013, 09:01:37 pm »
