September 15, 2026, 01:14:04 am
Hoffman Amps Forum image Author Topic: Simple compressor circuit for guitar amps  (Read 21514 times)
Offline Lauri
« on: October 03, 2013, 01:14:59 pm »
This is the simplest way to make a compressor with tubes or at least I haven't figured out any simpler way than this.
Signal is taken from power tube plates through coupling capacitors then rectified to a negative DC voltage and applied to a preamp pentode suppressor grid. Negative voltage on suppressor grid decreases plate current and increases screen grid current. When plate current decreases also control grid to plate transconductance decreases which means gain decreases.
compressor sidechain
C1, R1 and R2 set the attack and release times. RV1 sets the threshold. Attack and release times can be made adjustable by replacing R1 and R2 with potentiometers. Reduction in plate current causes shift in plate voltage which will be audible as a thump if the attack time is too fast. Thump can be reduced by cutting bass.
I've tested this circuit with 6SJ7 and 6SK7 pentodes and it works great but it should work with almost any preamp pentode that has a separate connection for suppressor grid.
Here's a schematic for a guitar amp I built which uses this compressor circuit
« Last Edit: October 03, 2013, 01:21:42 pm by Lauri »
Re: Simple compressor circuit for guitar amps
« Reply #1 on: October 03, 2013, 02:47:06 pm »
Hi Lauri, welcome!
Looks like a nice amp. Don't most compressors thump if their turned up to high?
If you wanted to keep it all tube you can use a 6AL5 instead of the 1N4007's.
You can do it on a triode too. Just take the side chain signal and feed it to the bottom (ground) end of the grid leak R. The grid leak will be referenced to ground through the cap at the end of the side chain.
You can also take the signal from the PI and feed it back to the grid leak R on the stage before the PI.
If you have just a preamp and are going with 12.6v heaters they made a 12AL5. Lots of 6/12AL5's around for cheap. Standard 9 pin miniature socket.
You've probable all ready looked at the Altec 436/8 compressor, same side chain circuit.
             Brad     :icon_biggrin:
« Last Edit: October 03, 2013, 02:49:53 pm by Willabe »
Offline terminalgs
« Reply #2 on: October 03, 2013, 03:15:51 pm »
Very cool.  I never though about the screen in a pentode to be the recipient of the control voltage.  I've built compressors into preamps using a side chain  only I've applied CV voltage to a triode's grid to the change the bias on said triode.   Basically, a Altec 436C or a UAI 175B just unbalanced instead of balanced, and with coupling caps instead of interstage transformers.
The trouble I always had with the sound of it stemmed from the full frequency band of a guitar signal being evenly smashed by a single compression hammer.   guitar signals would sort of lose sparkle.  maybe the Vrms of low frequencies would unfairly get to control high frequencies.  So I played with high frequency by-pass's on rotary switches, to let higher frequencies pass by the effect and let lower frequencies compress.   I could never quite get it the way I wanted (especially compared to a dynacomp).  I remember I also tried to change the source voltage of the sidechain buffer from a late in the signal path (like yours) to an early spot (before the CV was applied).   It is project I hope to return to someday and conquer (it is one of my many white-whales sitting around the shop)!
Its cool to see your approach.
Offline Lauri
« Reply #3 on: October 03, 2013, 03:26:58 pm »
Hi Lauri, welcome!
Single ended vari-mu and supressor-grid controlled compressors with fast attack times will always thump audibly, push pull not as much. Theres also a way to make this kind of a compressor to thump less with another pentode as a dummy tube to keep the plate voltage more constant, example of this can be found in RDH4 chapter 16.
If the control voltage is taken to the control grid then a coupling cap is needed for the input and it would introduce second time constants for attack and release. It's simpler with one time constant.
« Last Edit: October 03, 2013, 03:29:01 pm by Lauri »
« Reply #4 on: October 03, 2013, 03:37:29 pm »
No it doesn't.
Got a dozen or 2 different side chain compressors in TUT2, 4 and 6, some with the signal being feed to the grid leak with no coupling cap.
Altec 436/8 feeds the side chain signal to a CT on the input transformer secondary that feeds the input triode grids with no coupling/blocking cap.
They were pretty popular compressors they must have worked fine that way.
             Brad      :icon_biggrin:
« Last Edit: October 03, 2013, 03:44:36 pm by Willabe »
Offline Lauri
« Reply #5 on: October 03, 2013, 03:48:16 pm »
No it doesn't.
Altec 436/8 feeds the side chain signal to a CT on the input transformer secondary with no coupling/blocking cap.
             Brad      :icon_biggrin:
Transformers are expensive. My goal with this was to keep things as simple as possible. With a transformer you might as well go with push pull compressor stage and that's too fancy for a guitar amp.
« Last Edit: October 03, 2013, 04:01:44 pm by Lauri »
« Reply #6 on: October 03, 2013, 04:08:08 pm »
I understand that transformers are expensive and you wanted to keep it simple. I think you did a great job, I'm just suggesting that you can keep it simple and just use a triode instead of a pentode with the same side chain circuit.
The Altec 436/8 series are push/pull input but the point is that they didn't use coupling caps to feed the side chain input to the input triodes. So dc was present on the input tube grids but it worked just fine.
You can take the output of a single 12AX7 triode from the plate signal to feed the side chain circuit and return it to the same triodes grid leak R's ground end with no coupling cap.
It's just a NFB loop that you set the controls on for when it kicks in, threshold and you can have pots for attack and release.
            Brad     :icon_biggrin:
« Last Edit: October 03, 2013, 04:14:53 pm by Willabe »
Offline Lauri
« Reply #7 on: October 03, 2013, 04:46:09 pm »
            Brad     :icon_biggrin:
A picture of this kind of circuit would help. English isn't my first language so I might be misunderstanding what you are saying and I apologize for that. NFB loop? The way Altec 436 and the compressor circuit in my amp work are basically the same. By reducing anode current the gain is also reduced. Are you talking about some sort of variable negative feedback circuit?
« Reply #8 on: October 03, 2013, 05:07:45 pm »
No need to apologize. Your writing is very clear. Might be the way I'm trying to explain it.
Again I think you did a great job. Just bring up different ways to do the same thing for discussion.
I'll draw a picture and post it.
Yes they have the same side chain circuit.
Yours go to the pentodes suppressor grid the Altec feeds the side chain signal to the input transformers CT which feeds the transformers ends (start/finish) that feed the input tubes grids.
The side chain output is a negative dcv. So it fights the guitars positive signal. The more of this negative dc signal you feed back to the suppressor or input grid the more it cancels the tubes guitar signal output.
                    Brad      :icon_biggrin:
« Reply #9 on: October 03, 2013, 06:06:01 pm »
Push-pull cancels most of that.
But costs much more.
Suppressor G3, not Screen G2.
Many common pentodes have G3 hard-strapped to Cathode, so we don't often think about G3.
A hammer on G2 also works but has real problems. It must be way-positive, it sucks significant current, it causes large change in plate current.
G3 is easier to push around.
The effect of G3 depends on the tube. Some it has large effect, some it is very slight. Must be different ways to wind and space a G3.
This *does* complicate (and slow-down) the response time.
Filtered control voltage goes into the gridleak and then hits the coupling cap. This R-C network *slows* the signal further.
You can get away with it in slow soft limiters, which may even be fine for guitar where you want a little overload on the initial attack to emulate the missing power.
That's very different. No additional R-C network.
IMHO, the "simplest" is an LED on the speaker-tap to an LDR somewhere in the first stage. However now your timing is ALL about LDR selection, not adjustable, and often hard to find a musical LDR. Especially now that LDRs are going out of fashion, because their core ingredients and all the dope they use to adjust time-response are mostly toxic metals which are being banned in major markets (Europe).
> NFB loop
I spoke english young but "NFB" threw me when it came into use about a decade ago. "Negative FeedBack".
« Last Edit: October 03, 2013, 06:08:09 pm by PRR »
« Reply #10 on: October 03, 2013, 06:21:10 pm »
OK, here's a couple of drawings, ideas came from Kevin O'Connor TUT books and Altec.
Top 2 are simple gain stage, bottom 1 is LTPI (long tail phase inverter). Can be done with a split load/concertina PI too. Signal gets taken from split load PI plates goes to side chain but is fed back to split load PI's driver triode.
             Brad      :icon_biggrin:
« Last Edit: October 03, 2013, 06:26:55 pm by Willabe »
« Reply #11 on: October 03, 2013, 08:27:40 pm »
It seems like the only advantage might be smooth low-voltage turn-on of the 6AL5.
The the rectified voltage is more than a few-to-10 volts, it seems like the solid-state is superior in every regard.
Said the guy with TONS of 6AL5's sitting around doing nothing...
« Reply #12 on: October 03, 2013, 09:27:39 pm »
Yeah that's what the Altec's used, I put it up for a fun option. Although the smooth turn might make a difference in the sound?  :dontknow:
UF (ultra fast) diodes might be helpful in eliminating the little turn off/turn on noise between rectifier pluses?
          :laugh:
       Brad     :icon_biggrin:
« Last Edit: October 03, 2013, 09:33:34 pm by Willabe »
« Reply #13 on: October 03, 2013, 09:59:21 pm »
"Said the guy with TONS of 6AL5's sitting around doing nothing.."
Yes, the only thing sorrier than a 6AL5 is a 12AL5 which laughs at the filament current consumption of the 6AL5 even as it, too, sits around doing nothing.
« Reply #14 on: October 04, 2013, 08:37:31 am »
             Brad      :icon_biggrin:
You have my attention.  Compression.  Brad, are you saying you can simply add the circuit (the top 2) to an existing tube, like v1 or will you have to add a gain stage?
I assume it does need an added tube.  I have a 5F6a with a 9 pin socket with nothing connected and that is a shame.  Got any ideas of what would be a good start on component values?
Now I have used many valve compressors for recording.  Usually added to the track during mixing with great results.  Is this MOD even close to the compression of these?  I have not used one in years since digital recording, but my memory is they are far superior to any pedal.
Offline Lauri
« Reply #15 on: October 04, 2013, 08:55:56 am »
             Brad      :icon_biggrin:
The top 2 circuits will work if the input signal is big enough to produce enough signal on the output to make a sufficient amount of control voltage. Probably won't work well as a first stage of a guitar amp. Also cathode resistor should be kept small or otherwise changing cathode voltage will counteract control voltage on the grid.
Your LTPI compressor circuit has a low pass filter on the input grid (cap from grid to ground). Shouldn't the control voltage go to both tube's grids and not just the one tube if it is used as a phase splitter?
« Last Edit: October 04, 2013, 09:59:28 am by Lauri »
« Reply #16 on: October 04, 2013, 10:23:47 am »
put some to use...   :icon_biggrin:
http://www.triodeel.com/al444b3.jpg
« Reply #17 on: October 04, 2013, 11:26:39 am »
Yes.
You just have to add the side chain circuit.
These are good points.
You don't need a dedicated gain stage all you need is to tap a gain stages output for a sample ac signal and rectify it for a control -dcv.
It's all about the -dc control voltage. It's about cutting signal not increasing (gain) signal.
The way I understand it is;
The -dc control voltage is used to re-bias the tubes grid with respect to it's cathode but only on the peaks. The more the tube puts out the more -dcv is fed back the input, which changes the tubes bias and limits it's output gain. Because it's a dcv I don't think you have to worry about the phase. So you can take the sample acv from, say the 2nd gain stage and feed it back to the 1st (input) stages grid. You can take the sample signal from the output power amp and feed it back to the 1st stage which would give you a whole amp loop. Depending where you take the sample and where/what stage you feed it back to will change the R and pot values in the side chain. Also including more stages in the loop may make the amp unstable just like with a normal NFB loop and may not be needed to get a good compression effect ?    :dontknow:
The threshold knob sets/controls when the diodes (SS or tube) turn on. Until they turn on NO -dcv is fed back to the input grid, so no compression.
My understanding of this is that it's a type of negative feed back loop (NFB) but with a control that you set for when it kicks in. That way you set it to only kick in on the peaks so it limits the output signal which is compression. You can also add an attack and release control.
A regular NFB loop is on constantly and is set to the amount (of looses) the designer chooses. Like on the output stage OT secondary taken back to the PI.
Look at the schemos in Lauri's 1st post and also at Altec 436C, it has threshold, "C" has attack and release controls.
I found this on adding an attack control to the Altec 436C.
my guess is that you make the resistor R12 (33k) right after 6AL5 tube variable. This controls the time how quickly the capacitor c4 charges - just like the pot P2 controls its discharge (release).
I have not built this into an amp, but I do trust that Kevin knows what he's talking about. I also trust what PRR has to say and he sited some reservation about this side chain, so?   :dontknow:
Is it close? Not sure it's quite the same thing (apples to oranges?) but I do think for a guitar amp it might/will work fine.
I do have 1 of his sustain kits (small pcb with parts) that one of these days I'll put in something.    :laugh:    There's more info on his London Power web site that's worth reading.
Kevin brought up in 1 of the TUT books on sustain/compression that a tube amp pushed into clipping will sustain/compress by itself but sometimes you want/need a clean tone to sustain/compress. He said this is a way to do that.
This type of side chain compression will work on a high bias amp like a SE Champ or Vox AC30 where you really can't get power supply sag because it's already sagged.
              Brad      :icon_biggrin:
« Last Edit: October 04, 2013, 11:33:33 am by Willabe »
« Reply #18 on: October 04, 2013, 11:30:46 am »
May DL or SG  will be interested enough to experiment with this on their nifty proto type bread boards next time they bread board an amp?
                Brad     :icon_biggrin:
« Reply #19 on: October 04, 2013, 11:45:06 am »
   :dontknow:     I don't think so. The input signal to the PI is only applied to 1 grid. You may be right.
Also if the amp has a NFB loop I don't know if you can run the control voltage to both grids?
I think you edited it out about the PI output taken from only 1 triode plate, that's a mistake in my drawing, sorry, I'll fix that and repost it.
             Brad      :icon_biggrin:
Offline Lauri
« Reply #20 on: October 04, 2013, 12:05:25 pm »
There's a cap straight to ground from the grid where input is taken.
Yeah I figured it was probably a mistake in the drawing so I edited my question out.
« Reply #21 on: October 04, 2013, 12:27:17 pm »
Yes your right. Sorry, I only meant about applying the signal to both grids on the PI. The -dc control voltage might have to go back to the gain stage before the PI because of that cap, good point.       :icon_biggrin:
I'm glad you caught that, thank you. It's helpful when the other guys pick up on my mistakes.
              Brad     :icon_biggrin:
« Last Edit: October 04, 2013, 12:30:16 pm by Willabe »
