September 18, 2026, 06:39:24 am
Hoffman Amps Forum image Author Topic: Hoffman AC30 voltage  (Read 8541 times)
Offline labb
« on: October 29, 2013, 10:45:12 am »
Been looking for a schematic of the Hoffman AC30 build that has power supply, plate and screen voltages on it. Have not been able to find one. Anyone know where I might find this.
stratele52
  • Guest
Re: Hoffman AC30 voltage
« Reply #1 on: October 29, 2013, 12:42:13 pm »
And what about 1996 Vox AC 30 ?
EL84 plate is 324 VDC with very very hot bias . Screen pin 9 ; 332 VDC
stratele52
  • Guest
« Reply #2 on: October 29, 2013, 12:54:26 pm »
stratele52
  • Guest
« Reply #3 on: October 29, 2013, 12:57:57 pm »
Did a search on Hammond's site and found a replacement P/T (EDB290NX) was 290-0-290, so stratele52's numbers sound reasonable.
Which version of the AC30 are you working on?
+1 if he look to buy one ; look on PDF sheet here
www.hammondmfg.com/guitarLinePWR.htm
Offline labb
« Reply #4 on: October 29, 2013, 01:06:56 pm »
Thanks...The valve data chart helps a lot..I have a hard time searching on the site. I am looking at the AC-30 normal and top boost no tremolo channel. Actually I have a Marshall 18 watt IIB clone that I want to convert to the Vox. Make it initially a 15 watt keeping the Marshall xformers that I can up grade to the 30 watt Vox at a later date. I will have to add the third pre amp tube. I will go ahead and add the two additional EL84's and wire the sockets.
« Last Edit: October 29, 2013, 01:27:55 pm by labb »
stratele52
  • Guest
« Reply #5 on: October 29, 2013, 02:45:01 pm »
You'll need another Power transformer and Output transformer . You must rewired Phase Inverter , and change many value on capacitor and resitor .
Better to build a new one and keep Marshall original.
Offline labb
« Reply #6 on: October 29, 2013, 03:07:38 pm »
Meant to say add the two additional EL84 sockets and wire them up. That keeps me at the 18/15 watts with the two El84's which should let me use the existing transformers untill I decide ($) to upgrade to the 30 watts. The PT should be able to handle the extra Pre amp tube.
stratele52
  • Guest
« Reply #7 on: October 29, 2013, 03:34:56 pm »
A 18 watts amp's Power Transformer can't drive a  30 watts output amp with 4  X EL84
When all finish , you scrap the 15 watts output transformer AND the Power Transformer . What about news capacitor and resistors ?
You'll loose all tha money ?  Better to sell you amp and built a new real AC30 .
« Reply #8 on: October 29, 2013, 05:07:10 pm »
Why not?
Chassis space for 1.
2. Layout design noise/oscillation problems. Could be a lot of head scratching tracking down any and all new problems.
             Brad      :think1:
« Reply #9 on: October 29, 2013, 05:29:18 pm »
Look at the VOX et -1
Where?????
I looked in the schemo and layout section here and I don't see it in there.
It would be nice if you posted a link to what you want us to look at. Or at least tell us where to look.
            Brad     :dontknow:
stratele52
  • Guest
« Reply #10 on: October 29, 2013, 05:41:27 pm »
Where?????
            Brad     :dontknow:
+100000
« Reply #11 on: October 29, 2013, 06:29:43 pm »
I'll bet you mean Ampeg ET-1? Totally unrelated to the info lab seeks.
« Reply #12 on: October 29, 2013, 07:56:37 pm »
Ohh, well that's a horse of a different color then.      :laugh:
« Reply #13 on: October 30, 2013, 05:14:34 am »
Here you go. AC-15 complete with voltages.  It was in the schematic library that is NOT ExpressSCH
http://www.el34world.com/Forum/index.php?topic=5048.0
And here is a Hoffman style layout to go by:
http://www.el34world.com/Forum/index.php?topic=4811.0
FYI ................. we have 3 schematic libraries.  1) original manufactured amp schematics, 2) ExpressSCH editable and 3) non-editable schematics that posters have posted.
« Last Edit: October 30, 2013, 05:20:30 am by tubenit »
Offline labb
« Reply #14 on: October 30, 2013, 08:52:28 am »
Thanks tubenit. That is what I was looking for. There is so much info on this site that it is unbelievable.  Just hope that one day I will learn how to find all of it.
Offline labb
« Reply #15 on: October 30, 2013, 09:02:52 am »
For Stratele52-thanks for your input. I understand what you are saying about just keep the Marshall and build the AC 30 and normally you would be correct. My situation is a little different. I build amps as a hobby and give them to my Son. I don't even play guitar. We currently have three of the Marshall 18 watt amps.(TMB, Lite IIB and Zaphode Phill's  Superlite TMB)So giving up one of them is no big deal. I can strip the Lite IIB and build the VOX for about $75 worth of resistors, caps and pots. I don't have to buy $230 worth of xformers, a chassis, speaker and Cab. I will build it with the intent of upgrading to the 30 watt at a later date if we like the sound. Thanks to  all for your help.
