September 16, 2026, 02:38:33 pm
Hoffman Amps Forum image Author Topic: 6AN8 PI  (Read 10865 times)
6AN8 PI
« on: November 29, 2013, 11:12:54 pm »
Hi guys, Rather than side track billcreller's Sunn post I thought I'd better start another. Looking for a build for my 18w iron (something different) and see that Sunn have a 6AN8 in the PI spot, well I just happened to have one.
What do you guy's think of using this PI with EL84s....... maybe 6V6s. Thanks
Re: 6AN8 PI
« Reply #1 on: November 30, 2013, 01:40:35 am »
Why not ?
RCF used that tube in PA amp driving el84 tubes (and also el503)
about 6v6 they require a bit more drive than el84, but I think is feasible
Ciao
« Last Edit: November 30, 2013, 01:43:44 am by kagliostro »
Re: 6AN8 PI
« Reply #2 on: November 30, 2013, 06:40:41 am »
Looks good to me. Looks like you found a guitar preamp. I'd probably prefer 6V6s since this is a clean sounding amp. Have you considered a UL OT or are you mainly looking to use your 18W OT?
You won't need series caps at the first B+ node with that PT.
« Last Edit: November 30, 2013, 06:48:37 am by sluckey »
Offline silverfox
Re: 6AN8 PI
« Reply #3 on: November 30, 2013, 12:59:14 pm »
I too have had questions regarding the 6AN8 used in this fashion. I've got that type circuit- Perhaps? in a Univox 1221.
What are the benefits of using a Pentode in the phase inverter section?
For reference: http://www.el34world.com/charts/Schematics/files/univox/univox1221.pdf
Silverfox.
Re: 6AN8 PI
« Reply #4 on: November 30, 2013, 01:15:21 pm »
Technically speaking, the pentode is not the PI. The triode is the actual split load (cathodyne) PI, very similar to that found in the Princeton Reverb. But since the cathodyne PI only has a gain of slightly less than one, it's common to consider the preceding voltage amp as part of the PI.
With that in mind, the pentode is capable of more gain than a triode. The pentode may have a different sound than a triode but I'm guessing that the extra gain was the main reason for choosing the pentode.
Re: 6AN8 PI
« Reply #5 on: November 30, 2013, 01:51:37 pm »
... I'm guessing that the extra gain was the main reason for choosing the pentode.
I notice in both schematics presented that feedback is applied from the OT secondary to the bottom-end of the 6AN8 pentode cathode resistor.
If you have more open-loop gain (i.e., use a pentode instead of a triode), you can apply more feedback and not make the input to the power amp so insensitive that it needs super-huge driving voltage.
Said another way, Sluckey's right: pentode is easier to drive while also providing extra gain that can be taken by the feedback loop to reduce distortion and output impedance.
Offline silverfox
Re: 6AN8 PI
« Reply #6 on: November 30, 2013, 02:26:38 pm »
Thanks for the information. I have noticed the Univox seems to have a Richer tone;  I'm guessing higher harmonic content from the Pentode; not to say, higher distortion content. hard to define the difference the Pentode seems to provide, (higher wave count?).
The use of a voltage doubler also may benefit from a high gain Pentode driving the power amp. Just a guess on that.
Silverfox.
Re: 6AN8 PI
« Reply #7 on: November 30, 2013, 03:13:55 pm »
looks cool. build it!
EL84 over-driven can sound fizzy. 6V6 usually sound smoother over-driven...
Re: 6AN8 PI
« Reply #8 on: November 30, 2013, 03:33:40 pm »
Thanks guys, All good info. Sluckey, the plan is to use the 18w OT and i'll still try the ELs first. The caps in series is that way cause I already had a board made up with the rectifier diodes and caps on it , just recycling  :icon_biggrin:
"CLEAN" you say, might need a bit guidance to dirty it up a bit, the NFB I'm guessing can be adjusted to suit???
When setting out the chassis for the tube placement I marked three holes, two for the preamp and PI but I was not going to drill the second preamp till I got this up and running, but in the frenzy of drilling I drilled the second hole  :BangHead: what an idiot, so two spare TRIODES. DO I hear OD circuit or extra gain stage/tremolo. thanks
Re: 6AN8 PI
« Reply #9 on: November 30, 2013, 03:51:31 pm »
"CLEAN" you say, might need a bit guidance to dirty it up a bit ...
Every Marshall amp I can think of has feedback around the output stage. Are Marshall amps clean only?
Re: 6AN8 PI
« Reply #10 on: November 30, 2013, 04:05:14 pm »
Thanks HBP, I'm getting better at putting these things together but I fail when it comes to how it all works. This build is like most of the others I do, a bit from here and a bit from there and a S**T load of luck. Thanks for your input, always appreciated.  :icon_biggrin:
Re: 6AN8 PI
« Reply #11 on: December 02, 2013, 03:36:46 am »
Hi guys, This one has fired up well, with nothing went bang.
At low volume (a bit late at night) sounds good.
With a standard 18w type PT is putting out 300v on the HT leads, this then after rect is 387v at node A. So at the plates of the EL84s (JJ) 379v. Again I have power tubes running way over there max limit, this is after adjusting the cathode resistor from 135r(2x270r in parallel) to 250r (100r and 150r in series) this giving 11w per tube.So i'll keep an eye on it. PT seems to be OK as well.
Re: 6AN8 PI
« Reply #12 on: December 04, 2013, 02:18:30 am »
Hi guys, Had a bit of time to tinker. Ed had posted that Sunn amps are loud and clean. Well he was right, with only a volume control, I was only able to get it to 3 on the dial and with the ELs now bias at 10w each this thing sounded like 50w and my old speaker box was vibrating across the room and with only a hint of breakup.
I tried a PPIMV but it didn't seem to work  :dontknow: When it was on 1 it was already very loud and when turned up just sounded crappy.
Just a thought.... would adding another gain stage (CF) to V1a add more volume as well as extra gain????
AND adding a volume pot between the TS and V3b control the volume????
Any other thoughts on controlling the volume. Thanks
Re: 6AN8 PI
« Reply #13 on: December 04, 2013, 02:39:13 am »
I've just find this in my archive
may be there is a solution for your problem
About the use of a CF, the CF has a gain of 1 max but acts as an impedance adapter
so if you insert it between V1b and the TS the response will be better
I'll give a try to the Plate and Cathode split resistor may be it is what you need
Ciao
Re: 6AN8 PI
« Reply #14 on: December 04, 2013, 08:00:10 am »
One of the simplest things to do would be put a 470K resistor between the top side of your volume control and that .01µF coupling cap. This creates a voltage divider and knocks down the signal reaching the volume control by about 50%.
I don't understand why the PPIMV didn't work.
Re: 6AN8 PI
« Reply #15 on: December 04, 2013, 12:44:03 pm »
Timbo, what value dual pot did you use for the PPMIV?  I have a similar setup (not exactly the same) using dual 250k that works well.  Mine has EL34's and v1 is bypassed a little differently, but the circuit is very similar.  Did you remove the 220k resistors when you installed the PPMIV?
Re: 6AN8 PI
« Reply #16 on: December 07, 2013, 04:51:18 pm »
Thanks ED, PPIMV is working well, it's just a little fuzzy at low level,1-2 on the dial.
Got a mate to give it a good thrashing and its a loud mean machine. Its at its best with dials at 9 giving a great crunch and overdrive. At 4-5 does clean very well at high volume.
BUT there is no best of both worlds when you lighten the attack on the strings the touch response is just not there.
The same guy also gave my TOS a workout with great success, in clean channel and kicking in the overdrive he was able to lighten the attack and have a sparkly clean and up the volume on the guitar and BAM full on crunch without touching the amp.
It was nice to finally get a treat when you put a REAL musio in front of your amp  :worthy1:
SO, what to do with this amp???
I have rebiased the ELs to 10w each but it sounds way louder than 20w but that could be because it was plugged into a 4x12 cab and even in a 2x12 it was the same.
Is this perceived loudness coming from the PENTODE as the preamp circuit doesn't appear to be much different to any other circuits.
Is my thinking right that the signal from the preamp is being amplified but not pushed into distortion by the pentode to make it sound louder and the only way to get it to distort the signal is to push the preamp with the volume pot at max this then loosing any touch response  :w2:
I like the different tonal qualities of the pentode and it does work well with the ELs, so to use it with a pair of 6L6s or 34s would be huge.
Is there a best of both worlds with this amp, touch sensitive and awesome crunch.Thanks
Just a few changes to the curcuit
