September 14, 2026, 11:14:35 am
Hoffman Amps Forum image Author Topic: LED strip - tape lights  (Read 25062 times)
« on: December 04, 2013, 10:11:36 pm »
FWIW: WalMart is selling (in the Xmas tree lights aisle, AKA garden center) a "16' LED Tape Light" for about $15. Thin flat strip of White LEDs with a wall-plug.
I had an incandescent rope-light around the kitchen cabinets and door. It was dying. Also floppy and awkward.
I ran the Tape Light the same way, except flat to the trim and cabinet (with included straps and screws). Ran very neat. Is brighter than the inky rope-light. Probably far less power.
Drawback: STINKS of mold-release oils. Rubbed it down, little change. Hope that wears off.
« Last Edit: December 07, 2013, 09:03:19 am by EL34 »
Re: 15 Watt LED
« Reply #1 on: December 05, 2013, 05:02:35 am »
Nice PRR
I also have rope lights on top and under my cabinets
I was waiting for LED strips to come down in price a bit
That's not bad
I'll have to go have a look at them
Re: 15 Watt LED
« Reply #2 on: December 07, 2013, 08:54:20 am »
Found this LED strip light at Walmart that has sticky backing which would make installation quite a bit easier
http://www.walmart.com/ip/Northwest-72-60LED-Northwest-Waterproof-300-LED-Light-Strip-Kit-16/29416586#Item+Description
60 LEDS per meter, not bad
Quite a bit more $$ than the Xmas tree LED, but it's a one time install unlike my rope lights that have replaced twice in 10 years
I need to split it up into smaller sections and series them together like I did my rope lights, which is a bit of work, but the results are very nice
Have to go to walmart
« Last Edit: December 07, 2013, 09:06:33 am by EL34 »
Re: LED strip - tape lights
« Reply #3 on: December 08, 2013, 10:26:12 am »
My local Walmart did not have the LED strip light, but I found a deal on Amazon
$8.01 and free shipping for 5 meters
You can shorten the long strips by removing 3 LED segments
Each segment has a 150 ohm current limiter resistor
They run on 12 volts and you have to supply the wall wart which is no big deal. Or they also sell a 12 volt supply
They have 3m sticky tape backing so they attach easily
You can solder multiple strands together
If you look at the pics, each segment has copper pads
Not my favorite color. They seem to have a bit of a bluish tint
If you go into the merchants store you can find lots of other LED strips in different colors
See the link below for more info and pics
http://www.amazon.com/Generic-Waterproof-Flexible-Adhesive-Lighting/dp/B005EHHLD8
They now have have LED strips that you can change the colors with a remote control
LED Strip Lighting
« Last Edit: December 08, 2013, 10:55:56 am by EL34 »
« Reply #4 on: August 02, 2015, 05:23:55 pm »
Nice!
