September 15, 2026, 08:40:00 pm
Hoffman Amps Forum image Author Topic: AA864 Bassman ?  (Read 9587 times)
Offline floyd
AA864 Bassman ?
« on: December 24, 2013, 09:21:28 am »
When people rave about the great tone of the AA864 , are they referring to the normal or the bass channel , or the two channels jumpered? Because the normal channel is the same as any AB763... so it must not be that. Well , on second thought the AA864 must have more gain in the normal channel, since there's no trem, as opposed to the AB763... so maybe that's what's so desirable ?
« Last Edit: December 24, 2013, 09:30:14 am by floyd »
Re: AA864 Bassman ?
« Reply #1 on: December 24, 2013, 10:08:58 am »
Here's some good reading.....sluckey (I think) had pointed me to this site and there seems to be lots of good reading  :thumbsup:
http://fenderguru.com/amps/bassman
Re: AA864 Bassman ?
« Reply #2 on: December 24, 2013, 11:03:17 am »
It's the bass channel they like. It has an extra gain stage that they can use when they mod the amp.
           Brad     :icon_biggrin:
Re: AA864 Bassman ?
« Reply #3 on: December 25, 2013, 11:50:46 am »
When people rave about the great tone of the AA864 ...
I don't remember seeing people rave about the tone of the AA864. More that the AB165 and later Bassman amps have circuit changes people don't like.
Stock, the normal channel of the AA864 Bassman sounds basically like any other blackface Fender.
Willabe's right, though; I once took an AB165 Bassman and modified it so one channel was stock blackface Fender, and the other channel matched the 5F6-A Bassman circuit. Big volume difference between channels and some tone difference, too. I used an A/B/Y pedal to use that amp as a true two-channel amp.
Offline silverfox
Re: AA864 Bassman ?
« Reply #4 on: December 25, 2013, 03:06:52 pm »
floyd, you've got to check out the site recommended by Silvergun, it is fantastic. Thanks for the link.
So many people nowadays lack basic communication and follow through skills. A refreshing change and wonderful source. I'd recommend it to all seeking clear explanations and instruction. Not a dangling instructoid given on a whim.
Since I've chosen this endeavour through self study vs. attend one of the so called "Higher Learning Institutes", a meticulous search for good mentors is fundamental to a knowledge based outcome; Few and far between with inconsistent easily offended and at what I can't imagine, persona’s and "knowledgeable flakes", are ubiquitous to the landscape instead- So to speak.
Of course this is a great site too. Lots of old wisdom here.
Silverfox.
Oh and Merry Christmas All. It's been an amazing year but believe me, 2014 will be an unbelievable eye opener for everyone! I heard the term Reckoning associated with it and I get the feeling that will be the case... especially for the arrogant and aloof.
Offline floyd
Re: AA864 Bassman ?
« Reply #5 on: December 26, 2013, 09:36:19 am »
Sorry , should have been more clear. I meant to say that I hear about people loving the tone of the AA864  AS A GUITAR AMP without mods. And after thinking about it, the normal channel , with no trem circuit, would have more gain. Plus, according to the schematic , the plate voltage is considerably lower than most AB763s'
Re: AA864 Bassman ?
« Reply #6 on: December 26, 2013, 11:08:50 am »
... I meant to say that I hear about people loving the tone of the AA864  AS A GUITAR AMP without mods. ...
I've owned a number of blackface Fenders, mainly Princetons (with and without reverb), Super Reverbs and Bassman amps. I've also owned a lot of Fenders of other vintages, as well as various amps from other vintage makers (Marshall, Vox, Hiwatt, Gibson, etc).
The Bass channel of a non-modded AA864 Bassman sounds mostly like mud with a guitar, because it is voiced lower and has a number of treble roll-offs.
The Normal channel of the AA864 Bassman sounds like every other blackface Fender without reverb, because it has the exact same 2-triode circuit and tone stack, into the same phase inverter and (for 2-6L6 amps) output stage.
The AA864 Normal channel has less gain than the Bass channel, because it has 2 triode stages instead of 3. In the later Bassman amps, both channels share a triode so they each have 3 gain stages, but the shared stage has a local negative feedback loop that makes it contribute almost no gain.
The no-trem gain thing is generally very over-hyped. All blackface amps have essentially the same voice and similar gainy-ness, as long as you set aside the Champ/Vibro-Champ and Twin Reverb because their power outputs are very much different than the other Fender amps of the era. Meaning the Pro Reverb, Super Reverb, Bassman, Bandmaster, Vibrolux, etc sound largely the same except reverb channels (which also have trem in most of these amps) will tend to sound slightly gainy-er because the reverb circuit gives them an extra gain stage, even for the dry path. The differences between these and the Deluxe Reverb are mostly about tube type and speaker size/number.
So why the popularity?
I first started buying vintage guitar amps in the mid-90's. At that time, tweed amps had been so overhyped by Kendrick and others (and the fact that all the boutique amp makers were building tweed amp clones) that they were almost all $1500-2000 (or more). I bought a thrashed tweed Princeton at that time for $500. Blackface amps were relatively cheap, and silverface amps were largely considered undesired garbage.
By comparison to the thrashed '54 Princeton, a near-mint '67 Princeton Reverb only cost me $450. Blackface Twin Reverb's were highly desired because the association with Eric Johnson's clean tone, so they were ~$2200 in excellent condition at that time. Deluxe Reverbs were also acknowledged as great amps because compared to the Twin, they could be cranked for good distortion at club levels; they were selling for ~$1200-1500.
Super Reverb's were undiscovered gems then (probably because they were clumsy to carry), and you could buy a near-mint '67 for $800 or less. At the same time, a mid-60's AA864 Bassman head in near-mint shape could be bought for $350.
So the draw was they were a cheap way to buy the blackface Fender sound, and had a Bass channel begging for gain mods (since it sounded like crap for guitar, you were gonna tinker it anyway). They were so cheap and undesirable at the time you were unafraid to mod an AB165 if you bought one.
But the way this stuff works is that when the "desired stuff" becomes too expensive or too collected (few available for sale), then the market looks to the next later era or uncollected stuff; suddenly people find good qualities in items they wouldn't touch before. I'm surprised how much 70's Fender guitars (and amps) sell for now when in the 90's people would sooner burn it than buy it. Some silverface amps have gone way up in price because the market figured out the circuit is the same as the blackface model, while other amps can be converted to blackface specs.
This is a long way to say that what gets written is often hype or is driven by a force other than the actual performance of the amp/guitar. I found this out the hard way after buying a lot of the classic guitar amps to find that many of them sound remarkably similar (at least clean and with similar speakers).
« Last Edit: December 26, 2013, 12:21:47 pm by HotBluePlates »
Re: AA864 Bassman ?
« Reply #7 on: December 26, 2013, 11:50:09 am »
Yep.
     Brad     :icon_biggrin:
