September 15, 2026, 08:14:42 am
Hoffman Amps Forum image Author Topic: Question about Heather circuit configuration  (Read 6013 times)
« on: December 30, 2013, 12:58:57 am »
Some time ago we discussed about this argument but I'm not able to remember the conclusions
Having a PT that has only a 6.5v-0-6.5v Heather winding
which is the best way to connect the final tubes (a pair of 6V6) ?
is better to connect the CT of the winding to ground and the Heather of the tubes simply in series
or is better co connect to ground also the junction of the two Heathers (having a sort of virtual CT) ?
Many Thanks
« Last Edit: December 30, 2013, 02:59:28 pm by kagliostro »
stratele52
  • Guest
Re: Question about Heather configuration
« Reply #1 on: December 30, 2013, 04:57:17 am »
6.5-0-6.5  ???? You are sure of that ? None of your sketch are go to me .
Use only one side 6.5 and 0 . Boths tubes in parralel ,like any standard heater wiring . Floating heater wire.
Don't put the 0 to ground . Use two 100 ohms resistors to ground to make an artificial center tap
Re: Question about Heather circuit configuration
« Reply #2 on: December 30, 2013, 08:25:19 am »
The way you say 1/2 of the disposable current is lost
The transformer is from an Ibanez TSA15H
in that schematic Ibanez have the 6V6 tubes in series not connected at the junction to ground
but if you want to have all the disposable current you must use both windings and CT of the transformer
« Last Edit: December 30, 2013, 02:59:57 pm by kagliostro »
stratele52
  • Guest
« Reply #3 on: December 30, 2013, 12:47:59 pm »
Second sketch are better than the first one in you need full current.
« Reply #4 on: December 30, 2013, 10:26:13 pm »
is better to connect the CT ...
Both options are functionally the same.
If you connect the tube heaters in series and only connect the CT to ground, the junction of the tube heaters will float to approximately 0v. So it really doesn't matter if you make a wire connection from that point to ground, or if you connect only the CT to ground.
« Reply #5 on: December 31, 2013, 08:19:37 am »
Many Thanks
Offline spacelabstudio
  • Unable to leave well enough alone
« Reply #6 on: December 31, 2013, 08:21:32 am »
They look functionally identical to me.  Possibly one would have a different hum rejection than the other, but then again, this is the power section.  My vote is probably doesn't make any difference.
« Reply #7 on: December 31, 2013, 03:07:24 pm »
There is a difference if one of the 6V6 tubes falls out. (Or the heater burns open.)
« Reply #8 on: December 31, 2013, 05:06:41 pm »
And which will be your choice PRR ?
« Reply #9 on: December 31, 2013, 06:25:14 pm »
Well that's true...
In that case, if you had the junction of the 6V6 heaters grounded, the tube with the intact heater (or still in the socket) continue to function.
If you don't ground the junction of the 6V6 heaters, the remaining tube stops working because the circuit is opened (no path for heater current to go around the circuit). If the tubes are still in the sockets, that could be a good tip-off that the heater opened, which would be hard to suspect/troubleshoot otherwise. You'd check continuity of the tube from pin 2 to 7 to determine which tube has the open heater.
Maybe I've been lucky, but I've never encountered an open heater. I've seen tubes with almost no emission which still had an intact heater.
