September 18, 2026, 07:42:37 am
Hoffman Amps Forum image Author Topic: Marshall VBA 400 Bass Amp / No Power  (Read 55464 times)
Re: Marshall VBA 400 Bass Amp / No Power
« Reply #100 on: January 07, 2014, 08:41:59 pm »
Alright! Moving forward now...   :wink:
« Reply #101 on: January 07, 2014, 08:50:46 pm »
Wired up. Ready to flip on and see filament voltage. Any other thoughts before i proceed? Bon Voyagee!
« Reply #102 on: January 07, 2014, 08:52:52 pm »
Bringing up on Variac slowly/ Wont work unless i plug the AC cord to amp first/////
« Reply #103 on: January 07, 2014, 08:58:30 pm »
119 VAC. 6.53 filament voltage. All tubes are lit up. EUREKA!
Plugged in speaker and RL1 switch is working. Stop!
« Last Edit: January 07, 2014, 11:36:46 pm by plexi50 »
« Reply #104 on: January 07, 2014, 09:09:00 pm »
Power and Preamp tubes lit up. Have not flipped standby yet.
« Reply #105 on: January 07, 2014, 09:09:47 pm »
He didn't. He only had links 1, 3, 7, and 9 installed when he took those pics. That's the configuration for 230VAC operation.
Yes when he took those pictures but earlier he had a PT that was smoking hot. Could be why?
                 Brad     :dontknow:
« Reply #106 on: January 07, 2014, 09:10:00 pm »
PlugGed in speaker and RL1 switch is working. Stop!
Good stopping point. Now, do the world a favor. If you have a booklet of wire markers label all those transformer wires, ie, W15, W14, W12, etc. If you don't have wire markers then use a good permanent Sharpie and write the W# on the wire connector terminals.
Also, look at the wires for each transformer and tell me what color wire is on each W## terminal. I'll annotate the pdf and post it here. Might prevent some future frustration.
« Reply #107 on: January 07, 2014, 09:14:29 pm »
That's very likely. There's plenty of evidence that he had a jumper across every link at some time, maybe even at the same time.  :huh:
« Reply #108 on: January 07, 2014, 09:16:41 pm »
Ok will publish all the wire colors by W numbers. Wow man! You are all King Bee's in my book. I didnt understand the link like i thought i did. Ok posting info in 5 minutes/
« Reply #109 on: January 07, 2014, 09:39:46 pm »
That was when i had a jummper wire across RL1 W7 & W6
Edit:
Thermal Switch Wiring is W3 & W4
Dual (EDIT: (Orange) 10VAC low voltage wires W6 & W7
W10 - White
W11 - Red
W12 - Gray
W13 - Blue
W14 - Black
W15 - Brown
W16 - Purple
W17 - W22
W17 - White
W18 - Red
W19 - Gray
W20 - Blue
W21 - Black
W22 - Brown
« Last Edit: January 07, 2014, 11:45:06 pm by plexi50 »
Offline 6G6
« Reply #110 on: January 07, 2014, 09:46:54 pm »
OK, I can stop worrying about that.  :laugh:
I knew it would get sorted out.
I've been following the drama for days.
I do hope there are no other issuses, but they will be easier to tackle
if they show up now.
« Reply #111 on: January 07, 2014, 09:58:26 pm »
Wowza! LOUD Monster Is Alive!
640VDC 6550 Plates
270r Screens are 320VDC
-36.3 grid voltage @ 10K grid resistors
Does that screen voltage look right?
« Reply #112 on: January 07, 2014, 10:04:37 pm »
Screen voltage is OK.
I'M STILL WAITING ON THE REST OF THE TRANSFORMER WIRE COLORS!
So far you've only given me 6 wires for each transformer. I know there are 10 wires on the little transformer because I counted them. Don't know how many are on the big one. Give'em to me so I can go to bed.
« Reply #113 on: January 07, 2014, 10:23:51 pm »
Ok im doing it now
« Reply #114 on: January 07, 2014, 10:28:50 pm »
TI-65760C Filament Transformer
W12 & W13 are the (2) short black filament wires going to the power supply board
W6 & W7 are the (2) orange low voltage wires going over to the power supply board
EDITED: 1-8-2014
W17 - White
W18 - Red
W19 - Gray
W20 - Blue
W21 - Black
W22 - Brown
Total of 10 wires on the TI-65760C transformer
« Last Edit: January 08, 2014, 01:11:18 pm by plexi50 »
« Reply #115 on: January 07, 2014, 10:31:37 pm »
W12 & W13 are the (2) black filament wires going to the power supply board
W6 & W7 are the low voltage wires going over to the power supply board
OK. Now give me the rest of the wires for the big transformer.
« Reply #116 on: January 07, 2014, 10:32:26 pm »
Ok just a min
« Reply #117 on: January 07, 2014, 10:45:22 pm »
TI-65765B Transformer Wires / Total (9) Wires
Thin black wire to PS board W21
Thin Orange wire to PS board W15
Thin Red wire to PS board W16
W10 = White
W11 = Red
W12 = Gray
W13 = Blue
W14 = Black
W15 = Brown
I will do all the OT and some other wire connections tommorrow and Doc the entire amp.
Might as well. Likely wont get another chance at documenting this amplifier
Thankyou millions for your genius and patience!
« Last Edit: January 07, 2014, 10:52:58 pm by plexi50 »
« Reply #118 on: January 07, 2014, 11:10:24 pm »
I will do all the OT and some other wire connections tommorrow and Doc the entire amp. Might as well. Wont get another chance at doing this
Good idea. Here's the annotated pdf as promised. I'm done.
« Reply #119 on: January 07, 2014, 11:28:12 pm »
Fantastic! I will post the rest to complete the last remaining W connectors.
Long story but i kept looking at the links and wondering WHY? would you have to cut and remove bussed links to change the voltage on an amp. So i kept thinking of a different wiring senario itself. 2 days ago i was thinking should i cut and or add links together to make the changes like you and SILVERGUN were pointing me to. Turns out thats exactly what you all were saying. I think wire swapping would have been a more normal approach when they made the amp.
But seriously this has been fun and painful all at the same time. This is what it's all about and what drives me.
Doug needs to install a Toll Booth for overtime charges. Saving that PDF now. Goodnight until next time*
« Reply #120 on: January 07, 2014, 11:33:45 pm »
So are you saying that when you got the amp ALL of the likes where in place? Or was it set up for 230v with just those links in place?
            Brad     :think1:
« Reply #121 on: January 07, 2014, 11:50:32 pm »
When i got the amp the pic's i showed of the links were as i received it and it was linked for 230VAC. The later pic's from tonight (now yesterday) show the new links installed and the ones that were removed from the board. Man what a day. I did 4 amps total today. Im wiped out. This one was the real mind bender/
« Reply #122 on: January 08, 2014, 12:07:18 am »
There's plenty of evidence that he had a jumper across every link at some time...
Gents, I'm 99% sure Plexi didn't put jumpers in all those positions.
Given the way the leads look from the back of the board, they're bent inwards as they would if mechanically placed prior to wave soldering. I think Marshall installs all the links, then clips off the un-needed ones to set the operating voltage for the intended country of distribution.
I'm banking on the links having been set for 230v operation this entire time until he removed all and wired for 115v. And the amp magically worked once that was done, so...
« Reply #123 on: January 08, 2014, 12:19:45 am »
Yeah HBP thats why i wasnt understanding the link thing. There were several links that had already been cut and the ends bent over. I just didnt get the whole senario of the missing links that appeared to have been there at one time or another. Is this amp the missing link?  :laugh: Hell i cant sleep now. But i am very glad and thankful for learning something new and what i may expect in the future with other amps. Edit.
« Last Edit: January 08, 2014, 08:06:47 am by plexi50 »
Offline SILVERGUN
« Reply #124 on: January 08, 2014, 10:42:32 am »
:bravo1:
sluckey  :director:
I think your "people skills" are getting better  :icon_biggrin:
 :notworthy:
« Reply #125 on: January 08, 2014, 10:57:40 am »
HA! Just wait. I'll mess it up. You don't know how many times I have walked away from the computer in this thread to shake off my frustration.
Plexi50, if there's one thing to take away from this ordeal, it's this... LISTEN TO SILVERGUN!
He tried to steer you to the links early on, even colored them for you. But you didn't understand. It's OK to not understand. Especially when you're up against something you've never seen before. But instead of saying "I don't understand", you assured him the links were right. That sent us on a week long goose chase. And we would still be chasing if you had not finally taken the pics of the links.
So...    LISTEN TO SILVERGUN!   :wink:
« Reply #126 on: January 08, 2014, 11:26:12 am »
I should have pulled all the wires off the links from the start instead of peaking and looking through at the links. It may have become more obvious quicker what you all were saying. SILVERGUN you had it right all along. I see wild goose chase's in my future! Ha!
Offline SILVERGUN
« Reply #127 on: January 08, 2014, 12:12:50 pm »
Whoa, whoa, whoa, whoa, whoa......hold your horses there...
So far I've only proven that I can read a schematic.  :icon_biggrin:....and draw pretty pictures
I try to limit my posts to things that I actually know something about  :l2:
plexi, there is one other option to consider....
we could convert it to "auto-link" so it senses input voltage and then auto sets the links for you....kinda like this (just a snippet,,,,I don't want to give you "schematic shock")
Now you can see why I could relate to that schematic  :huh:
« Reply #128 on: January 08, 2014, 01:13:44 pm »
EDITED: 1-8-2014
W17 - White
W18 - Red
W19 - Gray
W20 - Blue
W21 - Black
W22 - Brown
I just edited the W numbers for the TI-65760C filament transformer.
« Reply #129 on: January 08, 2014, 01:16:51 pm »
Great eyeballs SILVERGUN. You know your stuff pretty good in my book
« Reply #130 on: January 08, 2014, 01:34:00 pm »
Huh? Nothing changed.
« Reply #131 on: January 08, 2014, 02:01:00 pm »
I saw this morning that both transformers has duplicate W numbers.
I Edited reply #114 as well and made a post earlier this morning
« Last Edit: January 08, 2014, 02:05:06 pm by plexi50 »
« Reply #132 on: January 08, 2014, 03:19:55 pm »
OT Primary Top Row & W Links
« Last Edit: January 08, 2014, 03:22:16 pm by plexi50 »
« Reply #133 on: January 08, 2014, 04:24:50 pm »
I've been following this thread right along. Plexi, way to stick with it! Sluckey, SG and everyone else who hung in with him, good on yinz!  :occasion14: :occasion14:
« Reply #134 on: January 08, 2014, 05:20:34 pm »
Thanks John! Credits go to the guys with more intel than me. Drama was mentioned. Talk about being on the edge! I was up until 1:45 a.m. this morning. It's hard to shut down after a major rush of info and making quick changes. The amp is done and sounds good. I had to retention all the 6550 sockets to keep the bottle pins in there socket. Speaking of sockets and pins these 6550 tubes have very thin pins on them. They are Marshall branded 6550's but i dont know who made them. Probably russia?
