September 18, 2026, 12:54:28 pm
Hoffman Amps Forum image Author Topic: Industrial PT as PSE PT - is my solution correct ?  (Read 5757 times)
« on: January 05, 2014, 08:04:53 am »
A friend want to build a PSE amp with multiple preamp and a pair of GU50 tubes in PSE configuration
The preamps he chose requires voltage from 300v to 400v
the GU50 in SE require 300v anode - 250v G2
he has this big industrial PT
Primary
0-230v-400v
Secondary
0-12v 50VA = 4.166A
0-18v-24v 2.8A
0-55v-75v 2.0A
0-95v 70VA = 736mA
0-115v 80VA = 695mA
and I assume the transformer will supply a bit higher voltage as the consumption isn't so high
I've think about to arrange the required voltage and I've draw this schematic
(Tra B1 e massa = Between B1 and GND)
the 20v winding is the voltage I can take between the 55v and the 75v connection on the 0-55v-75v windind
The reservoir caps are omitted on the draw
Do you think there is a better arrangement to be used ?
« Last Edit: January 05, 2014, 08:09:39 am by kagliostro »
Re: Industrial PT as PSE PT - is my solution correct ?
« Reply #1 on: January 05, 2014, 11:40:49 am »
I think you've got it figured out the best it can be with that particular transformer.
Good job!!
« Reply #2 on: January 05, 2014, 11:57:19 am »
I don't like the connection between 20V and 55V. I'd have to re-draw that to be sure it isn't a dead-short when the rectifier is connected.
I think the GU50 will be happy at 400Vp 260Vs 100mA 4K load/tube.
Then we have this possible hook-up:
« Reply #3 on: January 05, 2014, 04:43:51 pm »
Thanks HotBluePlates & PRR
Also I was a bit confused about what PRR is saying
but I'm not 100% sure that the connection that way is sure wrong
I've draw the schematic in a way that is easier to be read
Can you confirm that in this way there is a short ?
Many Thanks Again
p.s.: I forgot to say that as data for the PSE of GU50 is used the EL152 datasheet
PRR the data you give about voltages and TU are for a PSE of 2 tubes or for a PP of two tubes ?
« Last Edit: January 05, 2014, 04:51:44 pm by kagliostro »
« Reply #4 on: January 05, 2014, 06:22:32 pm »
You have a half-wave dead-short:
« Reply #5 on: January 05, 2014, 06:30:17 pm »
A single-ended tube (or parallel tubes) can be run at "many" different voltages.
Re-adjust the current to stay below plate dissipation rating.
Re-adjust the load impedance for the new V/I ratio.
See attached suggestions for either 1,000V or 500V.
For GU-50:
Book:
300Vp, 250Vs, 130mA, 39W Pdiss, 2K load
New condition:
400Vp, 250Vs, 100mA, 40W Pdiss
Voltage is 1.33 times higher, current is 0.77 times lower, impedance changes 1.33/0.77= 1.73 times higher, 1.73* 2K is 3.5K.
« Reply #6 on: January 05, 2014, 06:41:49 pm »
Many Many Thanks PRR
that image is better than a lot of words :thumbsup:
Now I've read also your further post one thing isn't clear to me
I was thinking the data sheet say 18W for one tube - 39W refers to the consumption (input power) ?
EDIT: is late and my brain was confused - Sorry
meanwhile I had one other idea about to avoid the use of the 20v from the 0-55v-75v winding
what do you think about this ?
« Last Edit: January 06, 2014, 01:27:50 am by kagliostro »
« Reply #7 on: January 05, 2014, 06:45:19 pm »
You can avoid any such short by just series-connecting secondary windings until you get the input voltage you suspect you will need on the input of a single bridge rectifier, using dropping resistors in a normal way to get the lower and lower voltages for the low power stages. One thing you *might* achieve by such an arrangement, particularly if you can switch OUT a 20-30 volt winding, run the amp at a lower B+ for a lower power setting.
Only one bridge.
« Reply #8 on: January 05, 2014, 07:12:22 pm »
 :grin:
My friend want to use a pair of GU50 in PSE
he consider the 18W of one tube a too low power  :icon_biggrin:
He has listened a 40W PSE and he want one  :grin:
« Reply #9 on: January 07, 2014, 04:41:47 am »
My last choice is this (it is near at the proposal of PRR)
but I would like to know if you see contraindications in the use of a doubler like in my previous post
this schematic
« Reply #10 on: January 07, 2014, 02:07:34 pm »
Yes the 12v winding will be used for the heaters
Here in Italy isn't so common as in Australia
but also us have some difficulties about the availability of low cost transformers
PT and OT are cheaper in the USA than in this side of the pond
