September 18, 2026, 01:20:00 pm
Hoffman Amps Forum image Author Topic: 6BR7 & 6BS7 pentodes.  (Read 7993 times)
« on: January 14, 2014, 11:50:16 pm »
do any here have any experience with the 6BR7 - a.k.a. CV2135 or 6059? it's small signal 9 pin pentode crafted for AF amplification with U.K. origins.
http://tubedata.milbert.com/sheets/155/6/6BR7.pdf
i picked up a small stash of them. impressed with the internal construction - looks to be very ridged.
how about the 6BS7? similar specs, but control grid is brought out to a cap. brimar (STC) claims lower input noise with the grid cap design. this one is a 9 pin as well with UK origins.
http://tubedata.milbert.com/sheets/184/6/6BS7.pdf
can't locate any in the con-us for a decent price. EURO market seems to be to the source for these at this time.
Re: 6BR7 & 6BS7 pentodes.
« Reply #1 on: January 15, 2014, 06:02:46 pm »
No experience with it. But I did notice this tube when I looked through a bunch of data sheets for non-typical tubes that could be good for guitar amps.
You should look up the tube at Frank's... they've got a 27-page application report for the 6BR7.
Offline Backwoods Joe
« Reply #2 on: January 15, 2014, 06:07:23 pm »
I have used the 6BR7. Much more like the EF86 than the 5879. Very nice, however most of the ones I have used are Brimar brand.
« Reply #3 on: January 15, 2014, 09:55:44 pm »
Same file. (Milbert is a mirror of Frank's.)
Not fully loading for me though. (Later: loads fine from Frank's; maybe Milbert is having a bad night.)
'Peers to be a funny-made 6J7. 6J7 is a sweet tame tube.
Offline zendragon63
  • Vacuum Packed Tone
« Reply #4 on: January 15, 2014, 10:11:17 pm »
+1 with Backwoods.  I have used a 6BR7--driven with a one section of 12AY7--and thought it sounded pretty sweet for preamp pentode dirt. IIRC, I used the similar values that sluckey uses with the 5879. Different pinout than either EF86 or 5879 though so kind of a pain to directly compare to either.
I am pretty sure nearly all of the 6BR7's were produced by/for Brimar. The two I have are dead quiet; me thinks that you will like this tube. Regards
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
