August 02, 2026, 04:15:38 pm
Hoffman Amps Forum image Author Topic: Noisy 12AY7 in Bassman 5F6-A  (Read 14586 times)
Offline vincenzo
« on: January 17, 2014, 11:37:37 am »
I open this new tread about a problem with my 5F6A Ceriatone clone. The amp is sounding very well, it has a very nice tone that I like very much but I’m not completely satisfied because of a breath that I think comes from V1, a 12AY7 tube
As a try I’ve put a 12AX7 tube in V1 and the amp was very silent, no noise, no breath so I’ve think that using a new 12AY7 the problem will be solved and I ordered a new selected TAD 12AY7 tube (which price is 3 times the normal price !!!)
When the tube arrived I put it in the amp and …. all was fine, only a very low breath no noise, the amp sounded very better than using the 12ax7 tube (in this amp I didn’t like the 12AX7 as V1)
The day after, when I used my amp, the breath was newly present
If I put on newly the 12AX7 tube I newly haven't breath
The voltage seems to be regular and I’m not able to understand what happen
A friend told me to change the plate resistor of V1 from 100k to 120k and from 820R to 1k, but using the 12AY7 the breath is still there, only a bit mitigated.
« Last Edit: January 17, 2014, 01:54:00 pm by vincenzo »
stratele52
  • Guest
Re: Noisy 12AY7 in Bassman 5F6-A
« Reply #1 on: January 17, 2014, 03:55:29 pm »
Did the input jacks use their shorting contact to keep noise away ?
Offline vincenzo
« Reply #2 on: January 17, 2014, 05:59:42 pm »
Yes, the imput jacks shorting to ground. But I have not a ground loop or hum. I have a great breath.
With or without the guitar cable I have the hiss.
If I change from 12AY7 to 12AX7 the hiss is lower.
stratele52
  • Guest
« Reply #3 on: January 18, 2014, 03:37:58 am »
If your shorting jacks are working , ( sure of that ? ) check your wiring from jacks to V1 grid , need a shield cable ? As a real Ceriatone kit you may not nee it if you do a good wiring job .
Picture of the amp may help .
Do you have heater center tap to ground ?
Do you built the Ceriatone 5F6 A like picture here ? Wiring dress is very important to keep amp noiseless.
http://www.ceriatone.com/productSubPages/AC5F6ABassman/AC5F6ACompleteAmpHead.htm
Offline vincenzo
« Reply #4 on: January 18, 2014, 05:34:05 pm »
I've a shield cable and the TA have a center tap. I think that the wiring is ok. I repeat that I haven't hum or ground loop but only a hiss that increase as I turn up the vol pot and only with 12ay7 tubes. With 12ax7 tubes tha amp is quieter.
stratele52
  • Guest
« Reply #5 on: January 19, 2014, 04:26:01 am »
And pictures ?
Photo will help
I know
Quieter  or as you write ; " If I change from 12AY7 to 12AX7 the hiss is lower" .?
IMO quieter with 12AX7 mean the 12AY7 is defective but the amp is ok , just need a new tube  . Lower (hiss ) you may have problem in the amp .
« Reply #6 on: January 19, 2014, 06:06:55 am »
Vincenzo had this problem with the first 12AY7 he tried
so he ordered a second one and the new tube present the same problem
As far as I can know some octal tubes are prone to have problems
Someone knows if this kind of problem is common to 12AY7 tubes ??
Offline vincenzo
« Reply #7 on: January 19, 2014, 06:37:38 am »
And pictures ?
Photo will help
I know
I think that my english is very bad!!! What is the difference between saying "quieter" and "lower" in english?
Anyway, I think that my 12ay7 is defective. I want to know why the 12ax7 is quieter than 12ay7? Can I find a 12ay7 as quiete as 12ax7? Is there anyone who has had same problems with 12ay7?
stratele52
  • Guest
« Reply #8 on: January 19, 2014, 06:46:03 am »
I'm french speaking , that is why I dont know quieter and lower are same  :w2:
12AX7 have more gain than 12AY7  .
12AY7 must quieter than 12AX7.  Which brand of tube do you use  ?
Many problem with today's tubes . I have a lot a home to find  the good one.
Offline vincenzo
« Reply #9 on: January 19, 2014, 07:47:50 am »
Oh, an Italian and a Canadian who speak English ... I do not think we ever would understand  :l2: :l2:
Anyway, I used 12AY7 and 12AX7 Electro Harmonics tube at preamp section.
I could think of having guessed one good 12AX7 and one bad 12AY7... but three good AX and three bad AY is a joke  :laugh:
I swear, my amp sound very great and I like much it... but this hiss  :sad2:
stratele52
  • Guest
« Reply #10 on: January 19, 2014, 08:00:35 am »
Electro H madew good tubes , I don't understand your hiss .
Wainting for some picture wich may help to see where is the issue .
And second question I do not read your answer (my poor english ? )  Did you buitl the amp exactly like on the picture on Ceriatone link ?
« Reply #11 on: January 19, 2014, 09:04:03 am »
So, there's your solution. Still does not answer why. You would think a lower gain tube would produce less hiss. Another tube to try would be a 5751. I've had good luck with those.
One more thing, did you use carbon comp resistors? If so, try changing to metal film, especially for the plate load resistors.
« Reply #12 on: January 19, 2014, 09:59:22 am »
I have a 12AY7 (or more) in all 3 of my amps.  They consistently have MUCH less hiss/noise than a 12AX7 or 5751.
I also use 12AV7's which I like. And they are not expensive.  However, occasionally one will be microphonic.
My guess is that you have had several problematic 12AY7's and maybe another one would likely be just fine. You could also try a 5751 or the 12AV7.
Offline vincenzo
« Reply #13 on: January 19, 2014, 11:39:00 am »
No, not your poor english, only my few time and carelessness.
I offer my apologies. I will post pics soon.
Anyway, the answer is no, I do not think I have built the amp exactly like Ceriatone, but I sure I make the possible to get a decent build. I have make it three time  :icon_biggrin:
« Last Edit: January 19, 2014, 11:43:07 am by vincenzo »
Offline vincenzo
« Reply #14 on: January 19, 2014, 11:46:01 am »
I use metal film resistor.
So it is very likely that I have a very bad 12AY7 and good 12AX7.
Offline vincenzo
« Reply #15 on: January 19, 2014, 11:49:55 am »
Where can I find good 12AY7? What brand I buy which is certainly good and low noise, with low hiss?
Offline vincenzo
« Reply #16 on: January 19, 2014, 02:58:46 pm »
Here are two mp3 files with sample of my amp hiss. Both are registered with my Samsung S4 at 1mt distance from amp.
https://hostr.co/GCPDtztXxqq0
https://hostr.co/VpJurLKkNEQ4
« Reply #17 on: January 19, 2014, 03:33:46 pm »
I have a couple of old stock 12AY7's.  However, I like the EH 12AY7's that Doug sells just as well & they've been fine for me. In fact, I think the only microphonic 12AY7 I've had is old stock.
Offline vincenzo
« Reply #18 on: January 20, 2014, 01:24:26 am »
You'll refer Doug's NOS tubes or current production? Do you sell your 12AY7?
stratele52
  • Guest
« Reply #19 on: January 20, 2014, 03:25:03 am »
You built 3  amps like this one ? Or you rebilt same amp 3 times ?
The way you built the amp could be an answer to your noise ; photo please
Offline vincenzo
« Reply #20 on: January 20, 2014, 02:16:00 pm »
Some pictures
stratele52
  • Guest
« Reply #21 on: January 20, 2014, 03:03:58 pm »
Thank's vincenzo , I wish to see more pictures like  the complete circuit too . Need to see all chassis ground , volume  wiring .....
To trouble shouting your amp we need all the information
« Reply #22 on: January 20, 2014, 04:44:25 pm »
I don't think you need to be troubleshooting this amp. I think you just need to find a tube that has less noise.
stratele52
  • Guest
« Reply #23 on: January 21, 2014, 02:26:44 am »
I think you don't understand what I write , if all tubes you put in the amp are noisy , maybe it is not the tubes ? Could be something else ?
« Reply #24 on: January 21, 2014, 05:16:42 am »
However, he stated several times that NOT all of the tubes are noisy. Just the 12AY7's. In light of that, I am like Sluckey thinking that trying another 12AY7 would be the next step.
« Reply #25 on: January 21, 2014, 07:41:09 am »
I do understand what you write. But I don't think you are listening to Vincenzo.
Offline vincenzo
« Reply #26 on: January 21, 2014, 08:08:51 am »
    I read that lower the input grid resistor from 68k to 33k or 10k reduce considerably the hiss. What do you think? I do not want to spend a lot of money on research of perfect tube.
« Reply #27 on: January 21, 2014, 08:13:52 am »
I've never heard that. Why are you opposed to using a 12AX7?
Offline vincenzo
« Reply #28 on: January 21, 2014, 08:26:54 am »
Because with the 12AX7 the amp is more gain. I love the sound of original Bassman 5F6A and i play blues.
some link:
http://ax84.com/bbs/dm.php?thread=466363
http://ax84.com/bbs/dm.php?thread=460755
http://ax84.com/bbs/dm.php?thread=470031
Anyway, if you search Google "hiss reduction grid resistor" you'll find a lot of information
« Reply #29 on: January 21, 2014, 09:01:50 am »
People write a lot of things on the internet. People also repeat a lot of bad info, because it is what they heard and they don't understand how it works (or doesn't work).
I agree with Sluckey that this is unlikely to reduce your hiss, but try it for yourself. Unsolder the wire from the jack to the 68kΩ resistor, and resolder it directly to the 12AY7 grid. That's zero series resistance. I think you'll find it doesn't solve the hiss.
Think for a moment: the 12AX7 has more gain from grid to plate than the 12AY7. If the source of the hiss was outside the tube and in the grid circuit (like the 68kΩ resistor), the 12AX7 would have louder hiss than the 12AY7.
Without an oscilloscope or a listening amp to determine where the hiss is happening (if it even is outside the tube), I don't know what to tell you. The only clues indicate the tube itself is the source of the noise, as the higher gain tube had less hiss.
« Reply #30 on: January 21, 2014, 09:08:44 am »
You KNOW that the 12AY7s you have are noisy and that's unfortunate. You proved it by using a higher gain 12AX7 that produced less hiss. I think you are chasing band aid solutions when you clearly understand what the real problem is. I think you will get no satisfaction.
Offline vincenzo
« Reply #31 on: January 21, 2014, 11:16:16 am »
So, what do you advise me to do? I'm sure that if I buy a lot of 12AY7 the only sure thing that will happen is to empty my pockets.
So, if there is a way for lower the gain of 12AX7 perhaps it is the best solution. Otherwise I am forced to hold the noisy 12AY7.
What would you do?
« Reply #32 on: January 21, 2014, 11:43:32 am »
I would try a few more tubes. But I think you have the correct idea: Your 12AY7 is noisy. It is possible to have more than one noisy tube.
I have a very nice pile of noisy 12AX7! I wish they were not! Wishing will not change this.
« Reply #33 on: January 21, 2014, 11:44:24 am »
Buy from a vendor that tests their tubes and guarantees low noise (which is funny, because the 12AY7 was originally designed to be a low noise tube for the input stage of audio amplifiers).
Make sure whoever you buy from has a return/exchange/money-back policy.
If you buy from a physical store, take your amp and see if you can try the tubes in your amp before buying (so you can select a low-noise tube).
Or use a 12AX7 and turn the volume control a few notches lower... in the end, that will be the same as using a 12AY7.
« Reply #34 on: January 21, 2014, 12:25:52 pm »
If it's really really important to you to use the 12AY7 because that's what the original used or for some perceived tone reason, then you'll have to buy another one. I'd definitely buy from a different vendor and probably buy a different brand.
However, I know I could not hear a difference between the 12AY7 and a 12AX7 in that socket. I suggest you compare the two tubes. Ignore the hiss and try to concentrate on the tone. You'll have to turn the volume down a bit when using the 12AX7. If you don't hear a significant tone difference, then just use the 12AX7 and take your true love out to dinner with the money you saved.   :wink:
The AX has a higher gain than the AY, but in this particular circuit that higher gain simply means you'll turn the volume down some. Higher gain in this case does not translate to crunchier or grittier or distorted sound, just a little more clean tone.
« Reply #35 on: January 21, 2014, 01:06:07 pm »
Steve my proposal is to use the 12ax7 tube with a split load resistor
what do you think about this and my be also lower only a bit the B+ to the plate of V1 ?
Offline vincenzo
« Reply #36 on: January 21, 2014, 01:07:24 pm »
If I decide to put a 12AX7, need I to change something in the circuit?
For example, the value of some resistance or capacitor.
« Reply #37 on: January 21, 2014, 01:23:35 pm »
IF ........... I were going to do that ...........  I'd change a 100k plate/1.5k cathode
to 100k plate and 2.2k or 2.7k cathode resistor and use a 5uf instead of a larger cathode cap.
Just an idea since you're considering sticking with the 12AX7.
Offline vincenzo
« Reply #38 on: January 21, 2014, 01:50:04 pm »
I do not understand!! V1 resistor cathode is 820R not 1.5K. What do you refer?
Anyway, increase the resistor cathode reduce gain, right?
Decrease bypass cap what do?
« Reply #39 on: January 21, 2014, 01:53:36 pm »
Is there a chance that the cathode resistor 820R is "shared"?  :icon_biggrin:
IF so, ........... then think 1.5k.
Yes, increase resistor and lower cathode cap value for less gain.
with respect, Tubenit
Offline vincenzo
« Reply #40 on: January 21, 2014, 05:59:09 pm »
 :icon_biggrin: So, if I think 1.5k (820*2), also 2.2k or 2.7k is shared? If yes, I will put a 1.1K or 1.35K?
« Reply #41 on: January 21, 2014, 06:43:00 pm »
Yes, you are thinking of this correctly.  IF shared,  use  1.2k or 1.5k.
And use a smaller cathode cap such as 5uf, 10uf or 2.2uf.  Experiment by paralleling them with insulated alligator clips. Try a 5uf and then parallel another 5uf or a 10uf .................... etc......    See what you like there.
Offline vincenzo
« Reply #42 on: January 23, 2014, 08:54:47 am »
Tubenit, what is the difference between change the resistor and cap cathode as you suggested and make a split load plate resistor as Kagliostro suggested?
p.s. I'm learning a lot on this forum and I want to thank all those who have written in this topic.
 :bravo1:  :worthy1:
« Reply #43 on: January 23, 2014, 09:03:44 am »
Changing the cathode resistor/cap actually changes the gain of the tube.
Using a split load plate resistor does not change the gain of the tube, but you only use part of the signal due to the voltage divider in the plate load.
Either way produces a smaller signal out of the preamp, just as if you had turned the volume control down a little.
