September 18, 2026, 07:55:17 am
Hoffman Amps Forum image Author Topic: Bias Supply - Can be done this way ???  (Read 5061 times)
« on: January 18, 2014, 05:47:17 am »
With a 340v PT that has no CT but has a tap at 60v
which is the right way to do a bias supply ?
is possible to arrange a bias supply in this way ?
Re: Bias Supply - Can be done this way ???
« Reply #1 on: January 18, 2014, 09:30:54 am »
You can't do that! See pic. There is another diode short across the 60V section. See if you can spot it.
Forget about using that 60v tap and just copy the Marshall JCM900.
« Reply #2 on: January 18, 2014, 10:32:04 am »
What would be the point of the tranny manufacturer of providing that 60v tap considering it is unusable? Or is there another way it could be used like going to ground instead maybe as a half wave?
« Reply #3 on: January 18, 2014, 10:55:40 am »
It's not unusable. Just can't be used as K suggested.
But, think of it as a 280 or 340 secondary. You have a choice of one or the other. Kinda like an OT with a 4Ω and 8Ω tap. Just a bit more versatile.
« Reply #4 on: January 18, 2014, 10:56:06 am »
Thanks Steve
The transformer was self wrapped by a friend
he wasn't thinking that without the CT that tap could be unusable as bias tap
the JCM900 schematic was tested and all is fine
at the begin a try was given also connecting the cap of the JCM900 bias circuit to the 60v winding instead than to one HV branch, but seems that in that way there is no function
Grazie ancora
« Reply #5 on: January 18, 2014, 11:34:10 am »
I give up, where?
            Brad    :dontknow:
« Reply #6 on: January 18, 2014, 11:57:55 am »
This seems the way
