September 17, 2026, 03:55:43 am
Hoffman Amps Forum image Author Topic: DELUXE REVERB w/boost control  (Read 7527 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: February 11, 2014, 11:08:43 am »
I may as well take advantage of you all while I'm here.
A Fender deluxe reverb came in this morning. Point to point wiring. Fitted with two 6L6 's that I swapped for 6V6 as fitted originally. I've redone the bias. Very cool sounding amplifier.
( my favorite of all Fender's ). The issue is the reverb.  Reverb tank being unplugged, no cord in any input as well, a loud squeal is heard when the reverb volume is turned past 4 -5.
What could it be ?
thanks
Colas
P.S.: call me Alvin.
Re: DELUXE REVERB w/boost control
« Reply #1 on: February 11, 2014, 11:16:41 am »
Plug in the tank. Does the squeal go away?
  • MAKE LOVE NOT WAR
« Reply #2 on: February 11, 2014, 11:27:41 am »
when the reverb tank is plugged, same issue, no difference at all
Colas
  • MAKE LOVE NOT WAR
« Reply #3 on: February 11, 2014, 11:54:45 am »
the reverb volume acts as a presence, the more its been turned clockwise, the more trebly the tone becomes until the squeal appears
removing v4 solves the problem but the volume is considerably lowered , swapping v4 for a new tube doesn't cure the ill....
this thing upsets me and..my ears....
  • MAKE LOVE NOT WAR
« Reply #4 on: February 13, 2014, 07:04:26 pm »
trouble solved:
1 bad cap and one lead unsoldered...........6 hours............
Colas.
Offline HommeMarrBuckley
« Reply #5 on: February 14, 2014, 10:05:27 am »
Could you post a gutshot pic of the point to point wiring?  Just like to see.
Glad you got it resolved.
« Reply #6 on: February 14, 2014, 10:14:24 am »
Which cap? Was it in the reverb circuit?
             Brad     :dontknow:
  • MAKE LOVE NOT WAR
« Reply #7 on: February 15, 2014, 10:54:09 am »
Hi,
a white lead from the reverb 100k pot going to a 470k resistor was disconnected. I soldered it to its place but that didn't cure the issue. The problem went away when I replaced ( at the same time ) 5 cathode bypass caps.  But I still can't figure out which one caused the high pitch squeal. I replaced as well the 1/4w ( or is it 1/8 w ? ) phase inverter LTP resistors to BF values ( 470 and 1 M, 1/2w , see pic b4 the replacement ). The reverb input tube was microphonic ( although not causing audible noise except when tapping on it , and not causing the squeal), and the the output tubes were 6L6's, that I swapped for 6V6's and re biased using a 1 OHM 1 % resistor. The amp is a new one now !
Colas
« Reply #8 on: February 15, 2014, 03:58:14 pm »
I'm betting it was the verb return K bypass cap.
The amp is a new one now!
Good job Alvin!
           Brad     :icon_biggrin:
« Reply #9 on: February 15, 2014, 04:22:37 pm »
a white lead from the reverb 100k pot going to a 470k resistor was disconnected. ...
Someone wanted to kill the pull-boost function of this amp.
  • MAKE LOVE NOT WAR
« Reply #10 on: February 16, 2014, 05:40:52 pm »
Good job Alvin!
Thank you brother Will, I always do good jobs. Very seldom in amps, though hey hey !
« Reply #11 on: February 16, 2014, 06:45:52 pm »
You glad to be home and off the road?
Where'd you go?
          Brad     :m2
  • MAKE LOVE NOT WAR
« Reply #12 on: February 17, 2014, 11:16:43 am »
here, there and everywhere, with my blues band and the woodstock tribute, no international tour though just in Canada
Alvin
« Reply #13 on: February 17, 2014, 11:58:11 am »
Here, there and everywhere, Canada's a mighty big piece of land Alvin!
          Brad     :laugh:
« Last Edit: February 17, 2014, 12:01:39 pm by Willabe »
