September 17, 2026, 07:20:36 am
Hoffman Amps Forum image Author Topic: mid boost  (Read 4879 times)
Offline dscottguitars
mid boost
« on: February 15, 2014, 04:29:31 pm »
Hi,  I have a question about the resistor used in this mid boost circuit and if there is any reason it can be eliminated in mine.  I took the circuit from a Fender Concert I had, see the schematic.  It uses a 10 meg resistor across the switch, but I can't see any reason for it being there.  I also have my preamp schematic with and without the resistor and would like to know if it can be used without it.  It seems to me I am just switching in another capacitor in parallel with the one on the treble pot.  It would make the total capacitance 2270pF vs 2000pF.
Daniel
Offline zendragon63
  • Vacuum Packed Tone
Re: mid boost
« Reply #1 on: February 15, 2014, 05:08:11 pm »
You often see large resistor across switches to minimize the 'pop' that can occur when engaging or disengaging the switch. Discharges the adjacent capacitor. If you don't need it--you don't need it. You can get away with lower value--4.7M if you need though. Regards
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
Re: mid boost
« Reply #2 on: February 15, 2014, 05:28:18 pm »
Didn't think of that, thanks...
Re: mid boost
« Reply #3 on: February 15, 2014, 05:51:12 pm »
... It would make the total capacitance 2270pF vs 2000pF.
It makes the total capacitance 2270pF vs 250pF. Which is what gives the impression of mid-boost, as upper mids are passed along with treble.
Re: mid boost
« Reply #4 on: February 15, 2014, 07:08:56 pm »
I use this midboost for all 3 of my amps.  And I like it ALOT!
You can calculate the values here:  http://www.kusashi.com/series-capacitors.php
Re: mid boost
« Reply #5 on: February 15, 2014, 07:09:21 pm »
typo...
