August 29, 2026, 12:28:42 pm
Hoffman Amps Forum image Author Topic: Hoping for input....  (Read 24796 times)
Offline tylerrussell
« on: February 15, 2014, 04:49:06 pm »
Newbie (very) I built a 5E3, following the triode layout. Used a light bulb limiter to power up. Had to touch up some soldering. Everything worked, with a bad hum/buzz. Then I noticed that the 2-100 ohm resistors were not installed from pilot light to ground. After those were installed, the hum/buzz decreased to a very acceptable level. Then I noticed that, as I was playing, that it didn't clean up well~and all this time it's plugged into the light-bulb limiter. Plugged it into the wall and it sounds like a 100 watt marshall on 10 with the guitar cable unplugged. Extremely loud hum. Did I damage anything/something playing this through the limiter for half an hour? If so, what would it be? If not I'm listening. Seriously, I am a newbie; and can be safe with regard to checking things~ but things have to be way dumbed down for me to follow. Thank you for any help you may provide. I'll be staring at her tomorrow in the hopes that something clicks in my head. (You don't know how thrilled I was when she fired up without incidence....and sounded a little crunchy.... but worked!
Re: Hoping for input....
« Reply #1 on: February 15, 2014, 04:53:34 pm »
As a side note, it hums so loud that I haven't let it run like that. Afraid of some smoke getting out.
Offline Jack_Hester
  • Greybeard
« Reply #2 on: February 15, 2014, 05:12:12 pm »
Does it hum loud with your instrument plugged in?  Check your build against the schematic, to see if you have the inputs built like it's drawn.  You should have four closed circuit inputs.  And if wired correctly, your inputs are connected to signal ground.  Confirm this before looking further.
Jack
"We sleep safe in our beds
                                                   ---George Orwell
« Reply #3 on: February 15, 2014, 05:20:12 pm »
Yep, what Jack said, +1.
           Brad     :icon_biggrin:
« Reply #4 on: February 15, 2014, 05:53:00 pm »
... Did I damage anything/something playing this through the limiter for half an hour? If so, what would it be? ...
I can't think of anything you might have damaged by playing with the lamp limiter.
« Reply #5 on: February 17, 2014, 10:18:18 am »
Thank you all for your input. The hum is there with or/and without the guitar plugged in. Gets louder as amp volume increases. It is gone with the amp volume on "0". Checked the input wiring yet again; it is wired like the Triode layout.
« Reply #6 on: February 17, 2014, 10:31:57 am »
The ground wires from the volume pots (Y on the layout) are attached to a PT bolt; as are the other three "Y's"~the two Y's from the top of the board and the one Y from the speaker jack. Also, the two 100 ohm resistors from the pilot light are connected there.  The AC line white wire is connected to a bolt on the PT on an opposite corner. Is this correct? The PT is a Hammond 290AX. The input jacks are not isolated from the chassis~and the chassis is a bit microphonic. There is only one speaker jack currently. Hammond 1750E 8 ohm OT. I've been over the solder joints, compared my amp to the layout and don't believe anything is amiss. Just a HUMMMMMMMMMMMM. Obviously something is a tad goofy here. Thank you all for your time and input.
« Reply #7 on: February 17, 2014, 10:46:40 am »
Also, since the PT is different, it is wired: 2 Blacks/one to line white, one to fuse center.
                                                        2 Reds/to V5 5y3 pins 4 and 6
                                                        2 Yellow/to V5 5y3 pins 2 and 8
                                                        2 Greens/to pilot light
                                                        1 Red w yellow stripe to PT bolt along with Green from the line cord.
OT is as the layout pic, minus the yellow 4 ohm wire.
« Reply #8 on: February 17, 2014, 11:56:01 am »
It would help greatly at this point if you would post clear close up pictures of the inside of the chassis and the outside (PT, OT, tube sockets layout) so the guys can see if it's your lead dress wiring.
            Brad     :icon_biggrin:
« Reply #9 on: February 17, 2014, 12:50:53 pm »
The hum is gone when either volume is on zero? Or only when both are on zero? Or hums only when one volume is turned up?
« Reply #10 on: February 17, 2014, 12:54:07 pm »
Since it's my first effort  :l2: is expected, although drilling the holes in the chassis HAD to be the most nerve-racking part. (So far....)
Also, the hum is gone only with both volumes on zero.
Offline Jack_Hester
  • Greybeard
« Reply #11 on: February 17, 2014, 12:54:43 pm »
Like Brad stated, pictures of what you are describing will go a long way.  By your layout, it appears that a terminal strip is attached to the PT bolt, which should be above (not connected to) chassis ground.  The white should be attached to this terminal strip, if I'm seeing the drawing correctly.  If yours is indeed connected directly to the PT bolt, lift it and tie it directly to the PT wire.  Insulate it and give it a try.
I can't say that this is the hum fix, but just trying to fit your description with the drawing.
Jack
                                                   ---George Orwell
« Reply #12 on: February 17, 2014, 12:57:41 pm »
Pic
« Reply #13 on: February 17, 2014, 12:58:37 pm »
Pic
« Reply #14 on: February 17, 2014, 01:03:52 pm »
Jack~that ground on the PT, on my amp, is connected to the bolt where it enters through the chassis; then a washer and nut applied. So those wires touch both the chassis and the OT bolt. As a matter of face, the PT housing touches the chassis where it drops through the chassis.
« Reply #15 on: February 17, 2014, 01:12:31 pm »
Oh, the PT and OT in the layout pic are not the one's I used. On mine, the white 120 line is connected to the black line on the PT~lifted from the chassis.
« Reply #16 on: February 17, 2014, 02:01:19 pm »
The the source of the hum has to be before the volume controls, but not exclusive to only one channel.
Try unsoldering the wires that go to pins 2 & 7 of the input (V1) tube.
Probably unrelated: what is that tube you're using for V1?
« Reply #17 on: February 17, 2014, 02:18:32 pm »
That tube is a 12BH7A. I read it could be subbed for a 12AY7A. I also tried 12AX7A's in V1. What might unsoldering 2 and 7 tell me? (us).
[/quote]
« Reply #18 on: February 17, 2014, 02:29:31 pm »
Unsoldered 2 and 7 on V1. Hum is a lot louder now when turning the amp volume up; but there is no hum with the volume(s) set at "0".
Offline terminalgs
« Reply #19 on: February 17, 2014, 02:55:35 pm »
A 12BH7A has the same pinout as a 12AY7 but it has an Amplification Factor of 16.5 versus the 12AY7's factor of 44.
While it will function, you will have a lot less overall gain than a 12AY7 (or a 12AX7).  This can be dealt with later, after you sort out the noise issue, but long term,I don't think you want a 12BH7A in V1.
« Reply #20 on: February 17, 2014, 02:59:59 pm »
I only have that and some 12AX7's and a 12AY7. I've tried them all to the same end.
Offline terminalgs
« Reply #21 on: February 17, 2014, 03:05:28 pm »
HBP might have a different "next step",
But while the soldering iron is hot,  get a length of wire.  attach one side to ground, and one side to pin 2.  do the same with another wire for pin 7.
turn volumes up and see what happens.
« Reply #22 on: February 17, 2014, 03:19:08 pm »
Is this with the original wires off of pins 2 and 7?
Offline terminalgs
« Reply #23 on: February 17, 2014, 03:23:44 pm »
Tyler, you might have had a edit problem on your last post.
Did you trying grounding pins 2 and 7 ?
« Reply #24 on: February 17, 2014, 03:25:09 pm »
No, I have not tried grounding pins 2 and 7. Do that with the original pin wires on or off?
Offline terminalgs
« Reply #25 on: February 17, 2014, 03:28:28 pm »
try it with the original wiring off,  just two ground wires running from pin 2 and 7 to ground (somewhere).
turn volume up, see if its better, same, worse...
« Reply #26 on: February 17, 2014, 03:38:07 pm »
OK. Soldered wires to pins 2 and 7. Grounded to chassis. She's really buzzing and humming and sounds like she's gonna' blow up. I hit the power off real fast!
Offline terminalgs
« Reply #27 on: February 17, 2014, 04:11:14 pm »
So with grids (pins 2 and 7) grounded, it is actually louder -noise wise- than before, with original wiring attached.
if there was a wiring problem with the input jacks, it should be quiet.   Are you sure you have a good ground connection at the chassis?  maybe alligator clip the wires to the circuit ground?  ( "Y" in the diagram, the negative (-) side of one of the 16uf caps?
maybe time to post DC voltages for pins 1,2,3 and 6,7,8 on V1..   plus  the DC voltages across each of the three 16uf capacitors.  do this with the amp on.  you can reconnect the original wiring,  and perform the readings.
also, (with amp turned off, unplugged) ohm readings with a DMM from the negative (-) side of the 16uf filter caps to all the "Y" points on your pots, the input jacks, as well as the "Y" point on the cathode resistor and by-pass cap (820ohm and 225uf at far end of board)
« Reply #28 on: February 17, 2014, 04:45:38 pm »
No laughing, looks real good. Some of the wiring might need to be shortened a little and moved around a little but it's not bad at all.
Yeah, drilling out a chassis can be nerve wracking.
               Brad    :icon_biggrin:
Offline terminalgs
« Reply #29 on: February 17, 2014, 04:53:56 pm »
Tyler,
another thing I noticed is that the diagram has lime green wire connecting input jack grounds to the "Y" ground, which it looks like you recreated.  It also looks like you are using switchcraft jacks. Were there small phelonic and fiberboard spacers included with the jacks? so the sleeve portion of the jack is isolated from the chassis?
« Reply #30 on: February 17, 2014, 05:04:52 pm »
Ok. Thank you all for bearing through this  :help:
Voltages on V1: pin 1=109
                           2=0
                           3=1.78
                           6=101
                           7=0
                           8=1.78
Voltages across 16uf's starting closest to PT:
                                336
                                296
                                212
Ohms readings from 16uf's neg side to "Y" points and to the 820 resistor/25uf cap junction all start at 3 or 4 and immediately drop to .3 or .2 on the lowest scale on my meter, which is 200.
Hope that's everything.
« Reply #31 on: February 17, 2014, 05:07:30 pm »
Tyler,
There were are no type of washers/spacers on the input jacks
« Reply #32 on: February 17, 2014, 05:15:28 pm »
               Brad    :icon_biggrin:
I figure I could tidy things up if it actually worked! It does, and I'm relatively thrilled with this first effort. Once things are ironed out I'll clean it up. Got the chassis for $10. All bent up~~~but with no holes at all. Jeeesh.
« Reply #33 on: February 17, 2014, 05:22:06 pm »
Tyler,
I think the only way to isolate the sleeve portion of the jack from the chassis is with a bushing, no?
« Reply #34 on: February 17, 2014, 08:10:17 pm »
The 12BH7 is a high-dissipation 12AU7. Some people (like me) have old audio gear that needs that specific tube. I'd recommend sticking with the 12AY7 or a 12AX7/12AU7. The 12BH7 is too-nice & too-expensive IMO for the 5E3 input.
You need to have an organized, divide & conquer approach to sorting out this hum.
Right now, you say if you have both volumes on 0 you get no hum, but turning either volume above zero gives hum. That means the hum is common to both channels and is before the volume pots.
It's perhaps not obvious from the layout, but the schematic shows that ahead of the volume controls are each side of V1 and the input jacks. I wanted to eliminate input jack wiring error as a possible fault, so I told you to unsolder the wires from the input jacks to V1.
Pull V1 from its socket, and try adjusting the volumes. The hum should be gone. Is it?
If the hum is gone with V1 pulled from the socket, move to the 0.1uF caps which connect to V1 pins 1 & 6. One at a time, unsolder the leg of the 0.1uF caps that is not connected to the 100kΩ resistor). In other words, the end connecting to the volume pot and not V1.
Does unsoldering one of those stop the hum? Does it require unsoldering both to stop the hum?
Offline terminalgs
« Reply #35 on: February 17, 2014, 08:36:08 pm »
yep.
http://www.hoffmanamps.com/MyStore/perlshop.cgi?ACTION=enter&template&thispage=Screws
You need to drill your chassis holes slightly larger.
Without them, and with that lime-green indicated ground wire,  what you have is potential ground loop that travels from the jack to your intended ground lug at the transformer, in two directions (hence the loop).  you can remove that wire, or get isolation washers.  The later is probably most desirable (but even the former is preferred to a potential loop).
regarding the ohm readings, when you start it starts at 3 or 4 ohm and drops to 0 ohms, do you mean all tested points are 0ohms?  you just get a reading of 3 ohms at first contact?   Or are some connections consistently  3 or 4 ohms (that's not good, should be 0ohm).
with pin 2 and 7 on V1 grounded,  your amp should be quiet.
« Reply #36 on: February 17, 2014, 09:00:55 pm »
Respectfully, I think this is a side-show. Fender didn't have isolated jacks, and the tweed amps were as quiet as tubes & CC resistors will allow.
And since he proved the input jacks aren't the source of the hum (by disconnecting the from V1), it might be better to attack what's left.
Oh yeah, if I didn't say it before, leave the wires to V1 pins 2 & 7 unsoldered. Let's eliminate the jacks as the culprit while we keep attacking whatever is causing the hum @ V1 to the volume controls.
Offline terminalgs
« Reply #37 on: February 17, 2014, 09:11:03 pm »
I agree.  save that for later.  If grids aren't connected to the jacks, they are irrelevant to the noise issue.
« Reply #38 on: February 18, 2014, 08:25:07 am »
Sorry for the delay...things got hectic over here. I can't (once again) thank you guys enough.
12AX7 now available for V1.
Pulled V1  No Hum
Un-soldered 0.1  No hum with 1st volume pot up.  Hum with second volume pot up. 12AX7 in V1.
Un-soldered next 0.1. No hum with both volumes turned up.   12AX7 in V1.
This is with the wires back on pins 2 and 7 of V1. Was unclear if they should have been left off or not.
0.1 caps atill disconnected at one end.
edit by sluckey... fixed quote
« Last Edit: February 18, 2014, 10:47:40 am by sluckey »
« Reply #39 on: February 18, 2014, 10:35:29 am »
Are you saying you lifted the end of 1, 0.1 cap and then lifted the end of the 2nd 0.1 cap so then both caps were disconnected at the same time?
If so now try it with the 1st cap reconnected and leave the 2nd cap disconnected.
            Brad      :icon_biggrin:
« Reply #40 on: February 18, 2014, 10:53:07 am »
I dis-connected the caps one at a time. First cap leg disconnected: it's channel had no hum when raising the volume. The second channel did have hum when raising the volume. Second cap leg disconnected, first cap reconnected: Respective volume pot produced no hum. The channel that was reconnected did produce hum. Hope I explained OK.
« Reply #41 on: February 18, 2014, 10:55:32 am »
I also tried removing the wire from the inputs to the first volume pot with 0.1 caps connected. No difference. Hum was still there. Also, the hum appears to have the pitch of Bb, if that indicates anything. I did clean all the tube sockets and tube pins.
« Last Edit: February 18, 2014, 11:01:55 am by tylerrussell »
« Reply #42 on: February 18, 2014, 10:59:08 am »
Don't disconnect the wires from pins 2 and 7 to check for hum because with the wires removed, the tube cannot bias properly.
      Instead...
Connect pin 2 and pin 7 to chassis ground. It's OK to use gator clips. Does the hum go away?
« Reply #43 on: February 18, 2014, 11:04:53 am »
You mean: leave the connections to pin 2 and 7 intact; then add two wire from 2 and 7 to chassis ground? Just want to make sure I understand.
« Reply #44 on: February 18, 2014, 11:06:07 am »
Yes
« Reply #45 on: February 18, 2014, 11:10:32 am »
Both 0.1 caps connected?
« Reply #46 on: February 18, 2014, 11:24:27 am »
Tacked wires to pins 2 and 7. Grounded to chassis with alligator clips. Hum is the same; loud when volume is raised, no hum with volumes off. 0.1 caps were connected during this.
« Reply #47 on: February 18, 2014, 11:30:04 am »
It's probably the tube then, unless you have a poor ground connection in the V1 circuit. Try a real 12AY7 or a 5751.
« Reply #48 on: February 18, 2014, 11:41:19 am »
That's wrong. The AC line white wire connects to one of the transformer black wires as you said elsewhere, but it does not connect directly to a PT bolt. Probably not your hum issue but it needs to be corrected.
Offline terminalgs
« Reply #49 on: February 18, 2014, 12:09:28 pm »
Tyler, you tried a 12BH7 and a 12AX7, do you have other  tubes to try?
I suspect ground problem.  especially since both triodes share the same cathode resistor and bypass cap...
find the ground turret for the 820ohm R and the 25uf cap.  call it turret "A".  disconnect the ground wire to "A".,  take a jumper wire (hookup wire with two alligator clips if you have) connect to "A"  and connect the other side to the (-) negative ground side of the 16uf filter caps.  (you mentioned 3ohm to ground for some ground connections, it wasn't clear to me if that was 0ohm or 3ohm)...
If you can easily disconnect the ground wire to "A" (under the board?), its still can be a valid test to do the above jumper wire test from "A" the (-) turret of the filter caps.
this could be a cold solder joint somewhere.   If not on the ground circuit, then on the B+ side, (grid is ruled out, what else is left?  tube, ground, B+).
