September 14, 2026, 03:27:07 pm
Hoffman Amps Forum image Author Topic: Problem with tube rectifier  (Read 4176 times)
Offline Leevi
    • Rikstone
« on: April 12, 2014, 04:02:32 pm »
I'm using both tube and SS rectifier like in picture A
http://el34world.com/Forum/index.php?action=dlattach;topic=14469.0;attach=32505
Everything works fine with SS but when I switch to the tube rectifier the power supply
starts to crackle after a while and the rectifier tube flashes. Sometimes even the fuse has blown.
This happens randomly, sometimes it takes longer time before the problem occurs.
I have also tried with another rectifier tube (5Y3) without success.
Could some the following reasons cause this?
- The 5V filament wires are too close to high voltage secondary
- The PT is partly damaged
- I'm using the pin 7 of the rectifier tube socket for filter cap
Leevi
Re: Problem with tube rectifier
« Reply #1 on: April 12, 2014, 06:52:20 pm »
I'd vote for these 2 causes. Especially if you're using pin 7 as a ground lug for your filter cap (now a ground is right next to 2 high voltage points where a ground never exists in normal rectifier usage).
Offline Leevi
    • Rikstone
« Reply #2 on: April 13, 2014, 11:04:12 am »
It's pretty clear that the PT is damaged.
I used a separate 5V filament transformer and the amp worked without problems.
Thanks for your response HotBluePlates!
/Leevi
